    BNO055 and Attiny817 I2C communication
    Cos_j
    I have some wierd issues with getting readings from the BNO055 sensor using an atmel attiny 817 mcu.
    Whenever i start reading the sensor data from 1A the operation  mode mysteriously turns back to config mode and all I get is 0.
    here is my code:
    bool check_connection(){
    	while (1) {
    		if (I2C_0_read1ByteRegister(0x28, 0x00) == 0xA0)
    			return true;
    		else
    			 return false;
    void setup_imu(){
    	// set operating mode: config.
    	I2C_0_write1ByteRegister(0x28, 0x3D, 0x00);
    	_delay_ms(20);
    	  /* Set to normal power mode */
    	I2C_0_write1ByteRegister(0x28, 0x3E, 0x00);
    	// switch to register page 0
    	I2C_0_write1ByteRegister(0x28, 0x07, 0x00);
    	// run self test
    	I2C_0_write1ByteRegister(0x28, 0x3F, 0x00);
    	// read self test.
    	I2C_0_read1ByteRegister(0x28, 0x36); // pass if 0x0F
    	//activate external crystal
    	I2C_0_write1ByteRegister(0x28, 0x3F, 0x80);
    	// set operating mode: OPERATION_MODE_NDOF.
    	I2C_0_write1ByteRegister(0x28, 0x3D, 0x0C);
    	_delay_ms(20);
    void getData(){
    I2C_0_read1ByteRegister(0x28, 0x3D);
    	I2C_0_readDataBlock(0x28,0x1A,data,6);
    	printf("data> %x \r\n", data[0]);
    int main(void)
    	memset (data, 0, 6);
    	/* Initializes MCU, drivers and middleware */
    	atmel_start_init();
    	ENABLE_INTERRUPTS();
    	/* Replace with your application code */
    	_delay_ms(500);
    	while (!check_connection());
    	setup_imu();
    	while (1) {
    		getData();
    		_delay_ms(1000);
    and here is the i2c communication (marked with where the change happens):
    Start, Error!!! Stop
    Error!!!
    Error!!!
    Error!!!
    Error!!!
    Start, h50 [ h28 | WR ], h00,
    Restart, h51 [ h28 | RD ], hA0 NAK,
    Restart, h50 [ h28 | WR ], h3D, h00, Stop
    Error!!!
    Start, h50 [ h28 | WR ], h3E, h00, Stop
    Error!!!
    Start, h50 [ h28 | WR ], h07, h00, Stop
    Error!!!
    Start, h50 [ h28 | WR ], h3F, h00, Stop
    Error!!!
    Start, h50 [ h28 | WR ], h36,
    Restart, h51 [ h28 | RD ], h0F NAK, Error!!! Stop
    Error!!!
    Start, h50 [ h28 | WR ], h3F, h80, Stop
    Error!!!
    Start, h50 [ h28 | WR ], h3D, h0C, Stop
    Error!!!
    Restart, h51 [ h28 | RD ], h0C NAK, Error!!! Stop
    Error!!!
    Start, h50 [ h28 | WR ], h1A,
    Restart, h51 [ h28 | RD ], h00, h00, h00, h00, h00, h00 NAK, Error!!! Stop
    Error!!!
    Error!!!
    Restart, h51 [ h28 | RD ], h00, h00, h08, h00, h2B, h00 NAK, Error!!! Stop
    Error!!!
    Restart, h51 [ h28 | RD ], h00 NAK, Error!!! Stop
    Error!!!
    Error!!!
    Error!!!
    Error!!!
    Error!!!
    Error!!!
    Error!!!
    Error!!!
    Error!!!
    o_o
    Contributor
    Re: BNO055 and Attiny817 I2C communication
    your I2C seems to have a lot of error. The beginning caught my attention:
    Error!!!
    There is a double i2c restart. I do not believe that the protocol allows for this. It should be one of these cases:
    1: Start -> WADDR -> ACK -> REG -> ACK -> RESTART -> RADDR -> DATA [ -> ACK -> DATA ]*n -> NACK -> STOP
    2: Start -> WADDR -> ACK -> REG -> ACK-> STOP -> START -> RADDR -> DATA [ -> ACK -> DATA ]*n -> NACK -> STOP
    3: Start -> WADDR -> ACK -> REG -> ACK -> DATA [ -> ACK -> DATA ]*n -> ACK -> STOP
    Does you host configuration support clock streching ?
