    BNO055 not retaining given settings
    I am using the BNO055 9-DOF IMU in AMG mode to record data on a launched rocket. I have changed the settings to all it to sense up to 16G's but after launch, the data gets saturated at 4G's (I know the rocket is exceeding that). I have confirmed that the binary setting is correct per the BNO055 documentation and can't seem to figure out why I am getting my acceleration values clipped to 4G's. Below is where I set the value:
    def begin(self, mode=OPERATION_MODE_AMG):
            """Initialize the BNO055 sensor.  Must be called once before any other
            BNO055 library functions.  Will return True if the BNO055 was
            successfully initialized, and False otherwise.
            # Save the desired normal operation mode.
            self._mode = mode
            # First send a thow-away command and ignore any response or I2C errors
            # just to make sure the BNO is in a good state and ready to accept
            # commands (this seems to be necessary after a hard power down).
            try:
                self._write_byte(BNO055_PAGE_ID_ADDR, 0)
            except IOError:
                # Swallow an IOError that might be raised by an I2C issue.  Only do
                # this for this very first command to help get the BNO and board's
                # I2C into a clear state ready to accept the next commands.
                pass
            # Make sure we're in config mode and on page 1.
            self._config_mode()
            self._write_byte(BNO055_PAGE_ID_ADDR, 1)
            # Set G range of accel to 16Gs (page 27 of datasheet), other defaults remain the same.
            self._write_byte(ACC_CONFIG_ADDR, 0x0F) ## sets accelerometer max to 16Gs
            # Set Page to 0 for further configurations
    Please let me know if you see an error or if there is some other setting I must change to allow for +4G's of acceleration readings.
    -Brennan
    Re: BNO055 not retaining given settings
    Would it be possible to share the complete list of commands and values sent to the BNO055 until the data readout?
    In particular, the sensors' configurations are auto controlled and overwritten by the BNO055 in any Fusion Mode (or if the BNO055 is reset). Therefore if the BNO055 is switched to a Fusion Mode even temporarily, the accelerometer will be configured back to its default settings including ±4g range.
    Thank you for the response! Sorry for the late reply (I didn't notice a notification from the forum). I have attached two files: BNO055.py and imu.py to show how I use the library and how we call it in our threads. Please let me know if this is helpful.
    -Brennan
    # IMU.py
    # This thread handles communication between the BNO055 IMU sensor and the RaspberryPi
    # It takes raw sensor values and calibrates if necessary before passing it into
    # the autopilot.py threads
    # downloaded libraries
    import logging
    import BNO055
    import numpy as np
    import queue
    import time
    import sys
    class Imu(MyThread):
        def __init__(self, death_event):
            super().__init__(death_event)
            self.bno = BNO055.BNO055(serial_port='/dev/serial0', rst=18)
            while True:
                try:
                    if not self.bno.begin():
                        raise RuntimeError('Failed to initialize BNO055! Is the sensor connected?')
                    self.bno.set_external_crystal(True)
                    status, self_test, error = self.bno.get_system_status()
                    break
                except Exception as e:
                    print("Error from BNO: {}".format(e))
                    print("Trying again...")
                    time.sleep(1)
            # Print system status and self test result.
            self.logger.log(logging.INFO, 'System status: {0}'.format(status))
            self.logger.log(logging.INFO, 'Self test result (0x0F is normal): 0x{0:02X}'.format(self_test))
            # Print out an error if system status is in error mode.
            if status == 0x01:
                self.logger.log(logging.ERROR, 'System error: {0}'.format(error))
                self.logger.log(logging.ERROR, 'See datasheet section 4.3.59 for the meaning.')
            # Print BNO055 software revision and other diagnostic data.
            sw, bl, accel, mag, gyro = self.bno.get_revision()
            self.logger.log(logging.INFO, 'Software version:   {0}'.format(sw))
            self.logger.log(logging.INFO, 'Bootloader version: {0}'.format(bl))
            self.logger.log(logging.INFO, 'Accelerometer ID:   0x{0:02X}'.format(accel))
            self.logger.log(logging.INFO, 'Magnetometer ID:    0x{0:02X}'.format(mag))
            self.logger.log(logging.INFO, 'Gyroscope ID:       0x{0:02X}'.format(gyro))
        def _run(self):
            try:
                self.logger.log(logging.INFO, 'IMU thread started.')
                while not self.should_stop.is_set():
                    # Read from IMU
                    gx, gy, gz = self.bno.read_gyroscope()
                    ax, ay, az = self.bno.read_accelerometer()
                    mx, my, mz = self.bno.read_magnetometer()
                print(e)
                self.logger.log(logging.ERROR, 'IMU Shutting Down')
                self.shutdown()
    # Adafruit BNO055 Absolute Orientation Sensor Library
    # Copyright (c) 2015 Adafruit Industries
    # Author: Tony DiCola
    # Permission is hereby granted, free of charge, to any person obtaining a copy
    # of this software and associated documentation files (the "Software"), to deal
    # in the Software without restriction, including without limitation the rights
    # to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
    # copies of the Software, and to permit persons to whom the Software is
    # furnished to do so, subject to the following conditions:
    # The above copyright notice and this permission notice shall be included in
    # all copies or substantial portions of the Software.
    # THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
    # IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
    # FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
    # AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
    # LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
    # OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
    # THE SOFTWARE.
    import binascii
    import logging
    import time
    import serial
    # I2C addresses
    BNO055_ADDRESS_A = 0x28
    BNO055_ADDRESS_B = 0x29
    BNO055_ID = 0xA0
    # Page id register definition
    BNO055_PAGE_ID_ADDR = 0X07
    # PAGE0 REGISTER DEFINITION START
    BNO055_CHIP_ID_ADDR = 0x00
    BNO055_ACCEL_REV_ID_ADDR = 0x01
    BNO055_MAG_REV_ID_ADDR = 0x02
    BNO055_GYRO_REV_ID_ADDR = 0x03
    BNO055_SW_REV_ID_LSB_ADDR = 0x04
    BNO055_SW_REV_ID_MSB_ADDR = 0x05
    BNO055_BL_REV_ID_ADDR = 0X06
    # Accel data register
    BNO055_ACCEL_DATA_X_LSB_ADDR = 0X08
    BNO055_ACCEL_DATA_X_MSB_ADDR = 0X09
    BNO055_ACCEL_DATA_Y_LSB_ADDR = 0X0A
    BNO055_ACCEL_DATA_Y_MSB_ADDR = 0X0B
    BNO055_ACCEL_DATA_Z_LSB_ADDR = 0X0C
    BNO055_ACCEL_DATA_Z_MSB_ADDR = 0X0D
    # Mag data register
    BNO055_MAG_DATA_X_LSB_ADDR = 0X0E
    BNO055_MAG_DATA_X_MSB_ADDR = 0X0F
    BNO055_MAG_DATA_Y_LSB_ADDR = 0X10
    BNO055_MAG_DATA_Y_MSB_ADDR = 0X11
    BNO055_MAG_DATA_Z_LSB_ADDR = 0X12
    BNO055_MAG_DATA_Z_MSB_ADDR = 0X13
    # Gyro data registers
    BNO055_GYRO_DATA_X_LSB_ADDR = 0X14
    BNO055_GYRO_DATA_X_MSB_ADDR = 0X15
    BNO055_GYRO_DATA_Y_LSB_ADDR = 0X16
    BNO055_GYRO_DATA_Y_MSB_ADDR = 0X17
    BNO055_GYRO_DATA_Z_LSB_ADDR = 0X18
    BNO055_GYRO_DATA_Z_MSB_ADDR = 0X19
    # Euler data registers
    BNO055_EULER_H_LSB_ADDR = 0X1A
    BNO055_EULER_H_MSB_ADDR = 0X1B
    BNO055_EULER_R_LSB_ADDR = 0X1C
    BNO055_EULER_R_MSB_ADDR = 0X1D
    BNO055_EULER_P_LSB_ADDR = 0X1E
    BNO055_EULER_P_MSB_ADDR = 0X1F
    # Quaternion data registers
    BNO055_QUATERNION_DATA_W_LSB_ADDR = 0X20
    BNO055_QUATERNION_DATA_W_MSB_ADDR = 0X21
    BNO055_QUATERNION_DATA_X_LSB_ADDR = 0X22
    BNO055_QUATERNION_DATA_X_MSB_ADDR = 0X23
    BNO055_QUATERNION_DATA_Y_LSB_ADDR = 0X24
    BNO055_QUATERNION_DATA_Y_MSB_ADDR = 0X25
    BNO055_QUATERNION_DATA_Z_LSB_ADDR = 0X26
    BNO055_QUATERNION_DATA_Z_MSB_ADDR = 0X27
    # Linear acceleration data registers
    BNO055_LINEAR_ACCEL_DATA_X_LSB_ADDR = 0X28
    BNO055_LINEAR_ACCEL_DATA_X_MSB_ADDR = 0X29
    BNO055_LINEAR_ACCEL_DATA_Y_LSB_ADDR = 0X2A
    BNO055_LINEAR_ACCEL_DATA_Y_MSB_ADDR = 0X2B
    BNO055_LINEAR_ACCEL_DATA_Z_LSB_ADDR = 0X2C
    BNO055_LINEAR_ACCEL_DATA_Z_MSB_ADDR = 0X2D
    # Gravity data registers
    BNO055_GRAVITY_DATA_X_LSB_ADDR = 0X2E
    BNO055_GRAVITY_DATA_X_MSB_ADDR = 0X2F
    BNO055_GRAVITY_DATA_Y_LSB_ADDR = 0X30
    BNO055_GRAVITY_DATA_Y_MSB_ADDR = 0X31
    BNO055_GRAVITY_DATA_Z_LSB_ADDR = 0X32
    BNO055_GRAVITY_DATA_Z_MSB_ADDR = 0X33
    # Temperature data register
    BNO055_TEMP_ADDR = 0X34
    # Status registers
    BNO055_CALIB_STAT_ADDR = 0X35
    BNO055_SELFTEST_RESULT_ADDR = 0X36
    BNO055_INTR_STAT_ADDR = 0X37
    BNO055_SYS_CLK_STAT_ADDR = 0X38
    BNO055_SYS_STAT_ADDR = 0X39
    BNO055_SYS_ERR_ADDR = 0X3A
    # Unit selection register
    BNO055_UNIT_SEL_ADDR = 0X3B
    BNO055_DATA_SELECT_ADDR = 0X3C
    # Mode registers
    BNO055_OPR_MODE_ADDR = 0X3D
    BNO055_PWR_MODE_ADDR = 0X3E
    BNO055_SYS_TRIGGER_ADDR = 0X3F
    BNO055_TEMP_SOURCE_ADDR = 0X40
    # Axis remap registers
    BNO055_AXIS_MAP_CONFIG_ADDR = 0X41
    BNO055_AXIS_MAP_SIGN_ADDR = 0X42
    # Axis remap values
    AXIS_REMAP_X = 0x00
    AXIS_REMAP_Y = 0x01
    AXIS_REMAP_Z = 0x02
    AXIS_REMAP_POSITIVE = 0x00
    AXIS_REMAP_NEGATIVE = 0x01
    # SIC registers
    BNO055_SIC_MATRIX_0_LSB_ADDR = 0X43
    BNO055_SIC_MATRIX_0_MSB_ADDR = 0X44
    BNO055_SIC_MATRIX_1_LSB_ADDR = 0X45
    BNO055_SIC_MATRIX_1_MSB_ADDR = 0X46
    BNO055_SIC_MATRIX_2_LSB_ADDR = 0X47
    BNO055_SIC_MATRIX_2_MSB_ADDR = 0X48
    BNO055_SIC_MATRIX_3_LSB_ADDR = 0X49
    BNO055_SIC_MATRIX_3_MSB_ADDR = 0X4A
    BNO055_SIC_MATRIX_4_LSB_ADDR = 0X4B
    BNO055_SIC_MATRIX_4_MSB_ADDR = 0X4C
    BNO055_SIC_MATRIX_5_LSB_ADDR = 0X4D
    BNO055_SIC_MATRIX_5_MSB_ADDR = 0X4E
    BNO055_SIC_MATRIX_6_LSB_ADDR = 0X4F
    BNO055_SIC_MATRIX_6_MSB_ADDR = 0X50
    BNO055_SIC_MATRIX_7_LSB_ADDR = 0X51
    BNO055_SIC_MATRIX_7_MSB_ADDR = 0X52
    BNO055_SIC_MATRIX_8_LSB_ADDR = 0X53
    BNO055_SIC_MATRIX_8_MSB_ADDR = 0X54
    # Accelerometer Offset registers
    ACCEL_OFFSET_X_LSB_ADDR = 0X55
    ACCEL_OFFSET_X_MSB_ADDR = 0X56
    ACCEL_OFFSET_Y_LSB_ADDR = 0X57
    ACCEL_OFFSET_Y_MSB_ADDR = 0X58
    ACCEL_OFFSET_Z_LSB_ADDR = 0X59
    ACCEL_OFFSET_Z_MSB_ADDR = 0X5A
    # Magnetometer Offset registers
    MAG_OFFSET_X_LSB_ADDR = 0X5B
    MAG_OFFSET_X_MSB_ADDR = 0X5C
    MAG_OFFSET_Y_LSB_ADDR = 0X5D
    MAG_OFFSET_Y_MSB_ADDR = 0X5E
    MAG_OFFSET_Z_LSB_ADDR = 0X5F
    MAG_OFFSET_Z_MSB_ADDR = 0X60
    # Gyroscope Offset registers
    GYRO_OFFSET_X_LSB_ADDR = 0X61
    GYRO_OFFSET_X_MSB_ADDR = 0X62
    GYRO_OFFSET_Y_LSB_ADDR = 0X63
    GYRO_OFFSET_Y_MSB_ADDR = 0X64
    GYRO_OFFSET_Z_LSB_ADDR = 0X65
    GYRO_OFFSET_Z_MSB_ADDR = 0X66
    # Radius registers
    ACCEL_RADIUS_LSB_ADDR = 0X67
    ACCEL_RADIUS_MSB_ADDR = 0X68
    MAG_RADIUS_LSB_ADDR = 0X69
    MAG_RADIUS_MSB_ADDR = 0X6A
    # Power modes
    POWER_MODE_NORMAL = 0X00
    POWER_MODE_LOWPOWER = 0X01
    POWER_MODE_SUSPEND = 0X02
    # Operation mode settings
    OPERATION_MODE_CONFIG = 0X00
    OPERATION_MODE_ACCONLY = 0X01
    OPERATION_MODE_MAGONLY = 0X02
    OPERATION_MODE_GYRONLY = 0X03
    OPERATION_MODE_ACCMAG = 0X04
    OPERATION_MODE_ACCGYRO = 0X05
    OPERATION_MODE_MAGGYRO = 0X06
    OPERATION_MODE_AMG = 0X07
    OPERATION_MODE_IMUPLUS = 0X08
    OPERATION_MODE_COMPASS = 0X09
    OPERATION_MODE_M4G = 0X0A
    OPERATION_MODE_NDOF_FMC_OFF = 0X0B
    OPERATION_MODE_NDOF = 0X0C
    # Page 1 Registers
    MAG_CONFIG_ADDR = 0X09
    ACC_CONFIG_ADDR = 0X08
    GYR_CONFIG_1_ADDR = 0X0B
    GYR_CONFIG_0_ADDR = 0X0A
    logger = logging.getLogger(__name__)
    class BNO055(object):
        def __init__(self, rst=None, address=BNO055_ADDRESS_A, i2c=None, gpio=None,
                     serial_port=None, serial_timeout_sec=5, **kwargs):
            # If reset pin is provided save it and a reference to provided GPIO
            # bus (or the default system GPIO bus if none is provided).
            self._rst = rst
            if self._rst is not None:
                if gpio is None:
                    import Adafruit_GPIO as GPIO
                    gpio = GPIO.get_platform_gpio()
                self._gpio = gpio
                # Setup the reset pin as an output at a high level.
                self._gpio.setup(self._rst, GPIO.OUT)
                self._gpio.set_low(self._rst)
                time.sleep(0.2)
                self._gpio.set_high(self._rst)
                # Wait a 650 milliseconds in case setting the reset high reset the chip.
                time.sleep(0.65)
            self._serial = None
            self._i2c_device = None
            if serial_port is not None:
                # Use serial communication if serial_port name is provided.
                # Open the serial port at 115200 baud, 8N1.  Add a 5 second timeout
                # to prevent hanging if device is disconnected.
                self._serial = serial.Serial(serial_port, 115200, timeout=serial_timeout_sec,
                                             writeTimeout=serial_timeout_sec)
            else:
                # Use I2C if no serial port is provided.
                # Assume we're using platform's default I2C bus if none is specified.
                if i2c is None:
                    import Adafruit_GPIO.I2C as I2C
                    i2c = I2C
                # Save a reference to the I2C device instance for later communication.
                self._i2c_device = i2c.get_i2c_device(address, **kwargs)
        def _serial_send(self, command, ack=True, max_attempts=5):
            # Send a serial command and automatically handle if it needs to be resent
            # because of a bus error.  If ack is True then an ackowledgement is
            # expected and only up to the maximum specified attempts will be made
            # to get a good acknowledgement (default is 5).  If ack is False then
            # no acknowledgement is expected (like when resetting the device).
            attempts = 0
            while True:
                # Flush any pending received data to get into a clean state.
                self._serial.flushInput()
                # Send the data.
                self._serial.write(command)
                logger.debug('Serial send: 0x{0}'.format(binascii.hexlify(command)))
                # Stop if no acknowledgment is expected.
                if not ack:
                    return
                # Read acknowledgement response (2 bytes).
                resp = bytearray(self._serial.read(2))
                logger.debug('Serial receive: 0x{0}'.format(binascii.hexlify(resp)))
                if resp is None or len(resp) != 2:
                    raise RuntimeError('Timeout waiting for serial acknowledge, is the BNO055 connected?')
                # Stop if there's no bus error (0xEE07 response) and return response bytes.
                if not (resp[0] == 0xEE and resp[1] == 0x07):
                    return resp
                # Else there was a bus error so resend, as recommended in UART app
                # note at:
                #   http://ae-bst.resource.bosch.com/media/products/dokumente/bno055/BST-BNO055-AN012-00.pdf
                attempts += 1
                if attempts >= max_attempts:
                    raise RuntimeError('Exceeded maximum attempts to acknowledge serial command without bus error!')
        def _write_bytes(self, address, data, ack=True):
            # Write a list of 8-bit values starting at the provided register address.
            if self._i2c_device is not None:
                # I2C write.
                self._i2c_device.writeList(address, data)
            else:
                # Build and send serial register write command.
                command = bytearray(4 + len(data))
                command[0] = 0xAA  # Start byte
                command[1] = 0x00  # Write
                command[2] = address & 0xFF
                command[3] = len(data) & 0xFF
                command[4:] = map(lambda x: x & 0xFF, data)
                resp = self._serial_send(command, ack=ack)
                # Verify register write succeeded if there was an acknowledgement.
                if resp[0] != 0xEE and resp[1] != 0x01:
                    raise RuntimeError('Register write error: 0x{0}'.format(binascii.hexlify(resp)))
        def _write_byte(self, address, value, ack=True):
            # Write an 8-bit value to the provided register address.  If ack is True
            # then expect an acknowledgement in serial mode, otherwise ignore any
            # acknowledgement (necessary when resetting the device).
                # I2C write.
                self._i2c_device.write8(address, value)
            else:
                command = bytearray(5)
                command[3] = 1  # Length (1 byte)
                command[4] = value & 0xFF
                if ack and resp[0] != 0xEE and resp[1] != 0x01:
        def _read_bytes(self, address, length):
            # Read a number of unsigned byte values starting from the provided address.
                # I2C read.
                return bytearray(self._i2c_device.readList(address, length))
            else:
                # Build and send serial register read command.
                command = bytearray(4)
                command[1] = 0x01  # Read
                command[3] = length & 0xFF
                resp = self._serial_send(command)
                # Verify register read succeeded.
                if resp[0] != 0xBB:
                    raise RuntimeError('Register read error: 0x{0}'.format(binascii.hexlify(resp)))
                # Read the returned bytes.
                length = resp[1]
                resp = bytearray(self._serial.read(length))
                logger.debug('Received: 0x{0}'.format(binascii.hexlify(resp)))
                if resp is None or len(resp) != length:
                    raise RuntimeError('Timeout waiting to read data, is the BNO055 connected?')
                return resp
        def _read_byte(self, address):
            # Read an 8-bit unsigned value from the provided register address.
                # I2C read.
                return self._i2c_device.readU8(address)
            else:
                return self._read_bytes(address, 1)[0]
        def _read_signed_byte(self, address):
            # Read an 8-bit signed value from the provided register address.
            data = self._read_byte(address)
            if data > 127:
                return data - 256
            else:
                return data
        def _config_mode(self):
            # Enter configuration mode.
            self.set_mode(OPERATION_MODE_CONFIG)
        def _operation_mode(self):
            # Enter operation mode to read sensor data.
            self.set_mode(self._mode)
            self._mode = mode
            try:
            except IOError:
                pass
            self._config_mode()
            # Check the chip ID
            bno_id = self._read_byte(BNO055_CHIP_ID_ADDR)
            logger.debug('Read chip ID: 0x{0:02X}'.format(bno_id))
            if bno_id != BNO055_ID:
                return False
            # Reset the device.
                # Use the hardware reset pin if provided.
                # Go low for a short period, then high to signal a reset.
                time.sleep(0.1)  # 100ms
            else:
                # Else use the reset command.  Note that ack=False is sent because
                # the chip doesn't seem to ack a reset in serial mode (by design?).
                self._write_byte(BNO055_SYS_TRIGGER_ADDR, 0x20, ack=False)
            # Wait 650ms after reset for chip to be ready (as suggested
            # in datasheet).
            time.sleep(0.65)
            # Set to normal power mode.
            self._write_byte(BNO055_PWR_MODE_ADDR, POWER_MODE_NORMAL)
            # Default to internal oscillator.
            self._write_byte(BNO055_SYS_TRIGGER_ADDR, 0x0)
            # Enter normal operation mode.
            self._operation_mode()
            return True
        def set_mode(self, mode):
            """Set operation mode for BNO055 sensor.  Mode should be a value from
            table 3-3 and 3-5 of the datasheet:
              http://www.adafruit.com/datasheets/BST_BNO055_DS000_12.pdf
            self._write_byte(BNO055_OPR_MODE_ADDR, mode & 0xFF)
            # Delay for 30 milliseconds (datsheet recommends 19ms, but a little more
            # can't hurt and the kernel is going to spend some unknown amount of time
            # too).
            time.sleep(0.03)
        def get_revision(self):
            """Return a tuple with revision information about the BNO055 chip.  Will
            return 5 values:
              - Software revision
              - Bootloader version
              - Accelerometer ID
              - Magnetometer ID
              - Gyro ID
            # Read revision values.
            accel = self._read_byte(BNO055_ACCEL_REV_ID_ADDR)
            mag = self._read_byte(BNO055_MAG_REV_ID_ADDR)
            gyro = self._read_byte(BNO055_GYRO_REV_ID_ADDR)
            bl = self._read_byte(BNO055_BL_REV_ID_ADDR)
            sw_lsb = self._read_byte(BNO055_SW_REV_ID_LSB_ADDR)
            sw_msb = self._read_byte(BNO055_SW_REV_ID_MSB_ADDR)
            sw = ((sw_msb << 😎 | sw_lsb) & 0xFFFF
            # Return the results as a tuple of all 5 values.
            return (sw, bl, accel, mag, gyro)
        def set_external_crystal(self, external_crystal):
            """Set if an external crystal is being used by passing True, otherwise
            use the internal oscillator by passing False (the default behavior).
            # Switch to configuration mode.
            self._config_mode()
            # Set the clock bit appropriately in the SYS_TRIGGER register.
            if external_crystal:
                self._write_byte(BNO055_SYS_TRIGGER_ADDR, 0x80)
            else:
                self._write_byte(BNO055_SYS_TRIGGER_ADDR, 0x00)
            # Go back to normal operation mode.
        def get_system_status(self, run_self_test=True):
            """Return a tuple with status information.  Three values will be returned:
              - System status register value with the following meaning:
                  0 = Idle
                  1 = System Error
                  2 = Initializing Peripherals
                  3 = System Initialization
                  4 = Executing Self-Test
                  5 = Sensor fusion algorithm running
                  6 = System running without fusion algorithms
              - Self test result register value with the following meaning:
                  Bit value: 1 = test passed, 0 = test failed
                  Bit 0 = Accelerometer self test
                  Bit 1 = Magnetometer self test
                  Bit 2 = Gyroscope self test
                  Bit 3 = MCU self test
                  Value of 0x0F = all good!
              - System error register value with the following meaning:
                  0 = No error
                  1 = Peripheral initialization error
                  2 = System initialization error
                  3 = Self test result failed
                  4 = Register map value out of range
                  5 = Register map address out of range
                  6 = Register map write error
                  7 = BNO low power mode not available for selected operation mode
                  8 = Accelerometer power mode not available
                  9 = Fusion algorithm configuration error
                 10 = Sensor configuration error
            If run_self_test is passed in as False then no self test is performed and
            None will be returned for the self test result.  Note that running a
            self test requires going into config mode which will stop the fusion
            engine from running.
            self_test = None
            if run_self_test:
                # Switch to configuration mode if running self test.
                self._config_mode()
                # Perform a self test.
                sys_trigger = self._read_byte(BNO055_SYS_TRIGGER_ADDR)
                self._write_byte(BNO055_SYS_TRIGGER_ADDR, sys_trigger | 0x1)
                # Wait for self test to finish.
                time.sleep(1.0)
                # Read test result.
                self_test = self._read_byte(BNO055_SELFTEST_RESULT_ADDR)
                # Go back to operation mode.
            # Now read status and error registers.
            status = self._read_byte(BNO055_SYS_STAT_ADDR)
            error = self._read_byte(BNO055_SYS_ERR_ADDR)
            # Return the results as a tuple of all 3 values.
            return (status, self_test, error)
        def get_calibration_status(self):
            """Read the calibration status of the sensors and return a 4 tuple with
            calibration status as follows:
              - System, 3=fully calibrated, 0=not calibrated
              - Gyroscope, 3=fully calibrated, 0=not calibrated
              - Accelerometer, 3=fully calibrated, 0=not calibrated
              - Magnetometer, 3=fully calibrated, 0=not calibrated
            # Return the calibration status register value.
            cal_status = self._read_byte(BNO055_CALIB_STAT_ADDR)
            sys = (cal_status >> 6) & 0x03
            gyro = (cal_status >> 4) & 0x03
            accel = (cal_status >> 2) & 0x03
            mag = cal_status & 0x03
            return (sys, gyro, accel, mag)
        def get_calibration(self):
            """Return the sensor's calibration data and return it as an array of
            22 bytes. Can be saved and then reloaded with the set_calibration function
            to quickly calibrate from a previously calculated set of calibration data.
            # Switch to configuration mode, as mentioned in section 3.10.4 of datasheet.
            self._config_mode()
            # Read the 22 bytes of calibration data and convert it to a list (from
            # a bytearray) so it's more easily serialized should the caller want to
            # store it.
            cal_data = list(self._read_bytes(ACCEL_OFFSET_X_LSB_ADDR, 22))
            return cal_data
        def set_calibration(self, data):
            """Set the sensor's calibration data using a list of 22 bytes that
            represent the sensor offsets and calibration data.  This data should be
            a value that was previously retrieved with get_calibration (and then
            perhaps persisted to disk or other location until needed again).
            # Check that 22 bytes were passed in with calibration data.
            if data is None or len(data) != 22:
                raise ValueError('Expected a list of 22 bytes for calibration data.')
            self._config_mode()
            # Set the 22 bytes of calibration data.
            self._write_bytes(ACCEL_OFFSET_X_LSB_ADDR, data)
        def get_axis_remap(self):
            """Return a tuple with the axis remap register values.  This will return
            6 values with the following meaning:
              - X axis remap (a value of AXIS_REMAP_X, AXIS_REMAP_Y, or AXIS_REMAP_Z.
                              which indicates that the physical X axis of the chip
                              is remapped to a different axis)
              - Y axis remap (see above)
              - Z axis remap (see above)
              - X axis sign (a value of AXIS_REMAP_POSITIVE or AXIS_REMAP_NEGATIVE
                             which indicates if the X axis values should be positive/
                             normal or negative/inverted.  The default is positive.)
              - Y axis sign (see above)
              - Z axis sign (see above)
            Note that by default the axis orientation of the BNO chip looks like
            the following (taken from section 3.4, page 24 of the datasheet).  Notice
            the dot in the corner that corresponds to the dot on the BNO chip:
                               | Z axis
                               |   / X axis
                           ____|__/____
              Y axis     / *   | /    /|
              _________ /______|/    //
                       /___________ //
                      |____________|/
            # Get the axis remap register value.
            map_config = self._read_byte(BNO055_AXIS_MAP_CONFIG_ADDR)
            z = (map_config >> 4) & 0x03
            y = (map_config >> 2) & 0x03
            x = map_config & 0x03
            # Get the axis remap sign register value.
            sign_config = self._read_byte(BNO055_AXIS_MAP_SIGN_ADDR)
            x_sign = (sign_config >> 2) & 0x01
            y_sign = (sign_config >> 1) & 0x01
            z_sign = sign_config & 0x01
            return (x, y, z, x_sign, y_sign, z_sign)
        def set_axis_remap(self, x, y, z,
                           x_sign=AXIS_REMAP_POSITIVE, y_sign=AXIS_REMAP_POSITIVE,
                           z_sign=AXIS_REMAP_POSITIVE):
            """Set axis remap for each axis.  The x, y, z parameter values should
            be set to one of AXIS_REMAP_X, AXIS_REMAP_Y, or AXIS_REMAP_Z and will
            change the BNO's axis to represent another axis.  Note that two axises
            cannot be mapped to the same axis, so the x, y, z params should be a
            unique combination of AXIS_REMAP_X, AXIS_REMAP_Y, AXIS_REMAP_Z values.
            The x_sign, y_sign, z_sign values represent if the axis should be positive
            or negative (inverted).
            See the get_axis_remap documentation for information on the orientation
            of the axises on the chip, and consult section 3.4 of the datasheet.
            self._config_mode()
            # Set the axis remap register value.
            map_config = 0x00
            map_config |= (z & 0x03) << 4
            map_config |= (y & 0x03) << 2
            map_config |= x & 0x03
            self._write_byte(BNO055_AXIS_MAP_CONFIG_ADDR, map_config)
            # Set the axis remap sign register value.
            sign_config = 0x00
            sign_config |= (x_sign & 0x01) << 2
            sign_config |= (y_sign & 0x01) << 1
            sign_config |= z_sign & 0x01
            self._write_byte(BNO055_AXIS_MAP_SIGN_ADDR, sign_config)
        def _read_vector(self, address, count=3):
            # Read count number of 16-bit signed values starting from the provided
            # address. Returns a tuple of the values that were read.
            data = self._read_bytes(address, count * 2)
            result = [0] * count
            for i in range(count):
                result[i] = ((data[i * 2 + 1] << 😎 | data[i * 2]) & 0xFFFF
                if result[i] > 32767:
                    result[i] -= 65536
            return result
        def read_euler(self):
            """Return the current absolute orientation as a tuple of heading, roll,
            and pitch euler angles in degrees.
            heading, roll, pitch = self._read_vector(BNO055_EULER_H_LSB_ADDR)
            return (heading / 16.0, roll / 16.0, pitch / 16.0)
        def read_magnetometer(self):
            """Return the current magnetometer reading as a tuple of X, Y, Z values
            in micro-Teslas.
            x, y, z = self._read_vector(BNO055_MAG_DATA_X_LSB_ADDR)
            return (x / 16.0, y / 16.0, z / 16.0)
        def read_gyroscope(self):
            """Return the current gyroscope (angular velocity) reading as a tuple of
            X, Y, Z values in degrees per second.
            x, y, z = self._read_vector(BNO055_GYRO_DATA_X_LSB_ADDR)
        def read_accelerometer(self):
            """Return the current accelerometer reading as a tuple of X, Y, Z values
            in meters/second^2.
            x, y, z = self._read_vector(BNO055_ACCEL_DATA_X_LSB_ADDR)
            return (x / 100.0, y / 100.0, z / 100.0)
        def read_linear_acceleration(self):
            """Return the current linear acceleration (acceleration from movement,
            not from gravity) reading as a tuple of X, Y, Z values in meters/second^2.
            x, y, z = self._read_vector(BNO055_LINEAR_ACCEL_DATA_X_LSB_ADDR)
        def read_gravity(self):
            """Return the current gravity acceleration reading as a tuple of X, Y, Z
            x, y, z = self._read_vector(BNO055_GRAVITY_DATA_X_LSB_ADDR)
        def read_quaternion(self):
            """Return the current orientation as a tuple of X, Y, Z, W quaternion
            values.
            w, x, y, z = self._read_vector(BNO055_QUATERNION_DATA_W_LSB_ADDR, 4)
            # Scale values, see 3.6.5.5 in the datasheet.
            scale = (1.0 / (1 << 14))
            return (x * scale, y * scale, z * scale, w * scale)
        def read_temp(self):
            """Return the current temperature in Celsius."""
            return self._read_signed_byte(BNO055_TEMP_ADDR)
