    BNO055 power on reset issues
    Highlighted
    Re: BNO055 power on reset issues
    Hi, I believe we might be experiencing this issue as well.
    We have 4 custom boards using the BNO055 (no external crystal) and 2 of them seem to be having the reset issue while the rest behave just fine.
    Is this clock issue consistent or intermittent?
    Highlighted
    It is currently unclear if the issue is consistent or not. The text from the official Microchip Errata is not very precise. See section 1.5.7
    Highlighted
    We've updated our design to include an external crystal to mitigate the power on reset issue.
    We did not use the same crystal as the bosch bno055 shuttle board since it was too large for our design but instead went with a smaller  2 pin crystal oscillator (32.678khz) with PN: FC-135R32.7680KA-AG3
    Is there a particular reason Bosch went with the large tuning fork oscillator? PN: MS1V-T1K 32.768kHz 7pF +/-20PPM TA.
    Attached is our schematic for the BNO055. We would really like to get this right the second time around so any help verifying this design would be greately appreciated!
    Highlighted
    jbthompson,
    Crystal selection is up to you, there are no particular reasons for the selection of that specific part number other than general availability and cost at the time.
    -Pin #10 is a digital output that indicates when the part is executing bootloader code. Connecting it to GND will effectively create a short-circuit at every power-on.
    -Pin #4 is required to be connected to your MCU for firmware upgrade in the field. At the moment Bosch does have an updated firmware available, but this is likely to change in the future.
    -Pin #9 Atmel changed the recommendation for capacitance on the CAP pin to >800nF. We have yet to update our own datasheet, but the recommended value is now 1uF
    -Make sure that your 3V3 net have enough capacitance somewhere else on the PCB. The capacitors in your snapshot are good enough for local decoupling, but >1uF total capacitance is also required.
    Highlighted
    I see, ok this is great feedback. Thank you very much 🙂
