05-24-2022 03:54 PM
Bosh Sensortec Community,
We are looking for a replacement for BNO055 as it has been discontinued. One of the forums here suggested the BHIxy series of IMUs. The current programmable sensor systems options listed on your webpage are:
BHI260AB
BHI160BP
BHI160B
BHA260AB
According to DigiKey, the BHI260AB has also been discontinued or will shortly, thereby leaving the latter three IMUs.
For our application, we have a strong preference to be able to develop our own sensor fusion/Kalman algorithm if required at a later date. We require that the sensor fusion algorithm is capable to operate with the accelerometer limits set at 6g or higher. We are insensitive to SWAP (Size, Weight, Area, Power) implications. Our optimization strongly favors resistance to gyro drift. Low noise sensors are preferred.
Which IMU do you recommend from your catalog?
Regards,
05-24-2022 06:27 PM
Hi bkris,
BHI260AB haven't discontinued. You could choose BHI160B, BHI260AB, BHI260AP.
