    BNO055 select I2C address
    Justina
    Hi, I use BNO055 for my application.  In the datasheet, I only find the typical resistance (40kOhm) to VDDIO for I2C address as 0x29.
    If I want to choose 0x28 as my I2C address, how many ohm resistor do I need to combine COM3 (PIN17) with GND? Is it OK with 0 Ohm?
    Thanks a lot.
    o_o
    Contributor
    Yes, a 0 ohm resistor can be used to change the i2c address
    Ok, thanks for your reply.
    Hi, I have one more question. Is there also the value area for resistance to GND like the resistance to VDDIO? From 0 Ohm to how many kOhm will be fine for selecting the I2C address as 0x28? Thank you.
    You have to make sure the voltage on the pin is less than VDDIO_VIL.
    The worst case being that the pull-up is 20k, and you must ensure a voltage lower than 0.3 * VDDIO, Therefore the the pull-down MUST be less than ~6.66kOhm.
    I personally would not use any resistor higher than 4.7kOhm, to be safe.
