06-08-2022 01:25 PM
BNO055 unreliable calibration & heading readings
I'm having difficulty with reliable heading in DNOF mode. I find it can drifts as much as +/- 20 degrees.
There are many questions I have regarding this. But, as they are all related, I will put them all here in a number list:
1. Power cycling calibration status
I find power cycling effects the accuracy / reliability of the calibration status.
2. Power cycling heading reading
I find power cycling effects the accuracy / reliability of the heading reading.
Always powered-up
I have changed my design to try the compass always powered-up while the battery is connected. This makes an improvement in both cases above, but this is not how I want the design.
I even put the compass into suspend mode on power-down & then back into normal mode at power-up.
3. When / how often should the calibration data to read / restored?
If I have to adopt the always powered-up approach, then the compass will be powered for long periods of time. How often should I read the OFFSET & RADIUS registers into NV storage?
4. Heading drift
I find that the heading drifts. IF I orient the compass in one direction, not change any compass settings, but just turn thru 360 degrees, or move the compass in some random way, the heading can be up to 30 degrees wrong.
5. Absolute heading
I find that the compass does not point north to match my magnetic compass, of my iPhone compass. (NB my magnetic compass & iPhone compass match each other photos attached)
This is was a fully calibrated BNO055 with all 4 CALIB STAT read 3’s
08-12-2022 10:42 AM
Hi Digisolve,
After our internal discussion, for your feedback "but I still do not get reliable/ repeatable heading results.", could you provide your test log to us for analysis? The log contain timestamp, accel RAW data, gyro RAW data, mag RAW data, euler data.
If you expect to get on site support, your need to apply for the request through distrbutor first.
08-12-2022 10:45 AM
I will try to get you some useful data.
I'm not expecting on site support. I'm more than happy to come to your offices which my system. It's a small & portable product I very easy to show you the symptoms.
08-12-2022 11:01 AM
Hi Digisolve,
I'm happy to support you. I located in China.
If you would like to visit Europe lab and get support, you also need to apply to distributor first for your request.
08-12-2022 11:15 AM
Sorry I didn't realise you were in China. I will contact Future Electronics
08-30-2022 10:22 AM
Hi Digisolve,
Has your problem improved?
