05-10-2020 03:45 PM
I use a Bosch BMI160 sensor to measure the three-axis acceleration and orientation. This sensor is connected to a developer board. I read a total of 12 registers and expect 12 values each time (one LSB and MSB value per axis). The problem now is that in rare cases I have fewer or more values when I start the transmission, such as just now:
//output:
"178,62"
"178,62 211,255,246,255,241,255,253"
"178,62 211,255,246,255,241,255,253,1,94,7,200,62"
I would now like to know whether it is perhaps due to my code. Above all, the last two output lines show that there is a space in the second value ("62 211"), but I don't insert a space in the code. How can that be? Here is a piece of my code (the rest is just setting up the sensor and dev-board):
void initBMI160()
// Start I2C Transmission ACC to the BMI160 sensor
Wire.beginTransmission(AddrBMI160);
// Select data register
Wire.write(0x00);
// Stop I2C Transmission
Wire.endTransmission();
Serial.println(F("Send done"));
// Request 1 byte of data
Wire.requestFrom(AddrBMI160, 1);
// Read 6 bytes of data
// xAccl lsb, xAccl msb, yAccl lsb, yAccl msb, zAccl lsb, zAccl msb
if (Wire.available() == 1)
byte data = Wire.read();
Serial.println(F("data available"));
Serial.println(data, HEX);
else {
Serial.println(F("No data available"));
//PMU mode
// Set PMU for acc
Wire.write(0x7E);
// Set Acc to normal mode
Wire.write(0x11);
//"You need to wait for at least 5ms and then you can write value of 0x15 to command register 0x7E to bring gyro to normal mode"
delay(50);
// Set PMU for gyr
Wire.write(0x7E);
// Set Gyr to normal mode
Wire.write(0x15);
//"You also need to wait at least 80ms for gyro to be stablized before you perform I2C read or write action"
delay(200);
//Range
// Set ACC_RANGE
Wire.write(0x41);
// Set Acc range to +-2g
Wire.write(0x03);
// Set Range for Gyr
Wire.write(0x43);
// Set Gyr Range to 250dps
Wire.write(0x03);
//Read PMU
// PMU REG
Wire.write(0x03);
// Read PMU REG
Serial.println(F("PMU REG"));
else {
//Read Range
// ACC_RANGE
Wire.write(0x41);
// Read PMU REG
Serial.println(F("ACC_RANGE REG"));
else {
// GYR_RANGE
Wire.write(0x43);
// Read PMU REG
Serial.println(F("GYR_RANGE REG"));
else {
Serial.println(F("BMI160 init done"));
void loop() {
Wire.write(12);
Wire.endTransmission(true);
Wire.requestFrom(AddrBMI160, 12, true);
for (int i = 0; i < 12; i++) {
ble.print(Wire.read());
// Separator for further processing
if (i < 11) {
ble.print(",");
// A space so that the further program knows that the values can be plotted
ble.println();
delay(1000);
So I always expect 12 values, that are seperated with a comma for the further processing of the data on my PC.
05-11-2020 04:43 PM
It is correct that you write value of 0x11 to register 0x7E to bring BMI160 accel to normal mode and then add 50ms delay. It is also correct that you write value of 0x15 to register 0x7E to bring BMI160 gyro to normal mode and then add 200ms delay. If you read PMU_status register 0x03 and can get back the value of 0x14, then it means that BMI160 both accel and gyro are in normal mode. It also means that your I2C single byte read and write are working properly.
Now you should get 12 bytes data from register 0x0C to 0x17 for gyro data and accel data in your loop for I2C multi-byte burst reading. You can use Arduino serial monitor to check if you can always get 12 bytes data displayed there or not. If yes, then it means that your I2C burst read is working properly and your BLE link function "ble.print()" has some problem.
10-31-2020 01:32 PM
@FAE_CA1 wrote:Hi,
Hey, @FAE_CA1: Is there anywhere an official source, where I can find these information? I Did not find these information in the BMI160 datasheet, so how could a newbie know that he/she has to set these "setting"? Where is this written?
