10-18-2021 06:57 AM
I have used the BSEC library using v1.0.4 and changing the platform.txt file to the attached. This has worked well. The library is great btw so thankyou!
Since updating to ESP v1.0.6 and re-updating my platform.txt files (if you dont do this you get the same error as v1.0.4) I can no longer comile and I get the following error below when attempting to compile. I can repeat this with the basic script that comes with the library however my actual firmware requires some of the new features that come with v1.0.6. I looked through the forum and couldnt find anyone having this problem with v1.0.6.
10-19-2021 07:49 AM
Hello gcharlto,
ESP8266 platform has been supported in BSEC package: https://www.bosch-sensortec.com/media/boschsensortec/downloads/bsec/bsec1_binary_size_information.pd...
There was guide to modify the platform.txt file, could you refer it and try it again?
https://github.com/BoschSensortec/BSEC-Arduino-library/blob/master/README.md
10-19-2021 08:47 AM
Hi BSTRobin,
As per my message above, I am using the ESP32 rather than ESP8266 have followed the steps to modify the platform.txt using v1.0.4 (released october 2019) of the espressifs arduino-esp32 core when I update to v1.0.6 (released March 2021) the process no longer works and I get the error when comiling from my original message. Other libraries etc. have no problem with the newer esp32 core and there is some features within the later core that can aid in reducing power consumption which is critical for my application.
Any advice on getting the BSEC library to compile with the arduino-esp32 core(v1.0.6) would be much appreciated.
Kind Regards,
Glen
11-26-2021 07:21 AM
Hello gcharlto,
Judging from your compilation information, there is an error in the WiFi part, and haven't see the error message from BSEC.
11-29-2021 05:22 AM
Hi BSTRobin,
Yes, there is an error in the WiFi part when using the same modified platform.txt file which works with previous versions.
I guess the simple question is: have you got the BSEC library to work with ESP v1.0.6? Is it possible to get the steps to use the BSEC libary with this verison as I am only able to get it to work with v1.04.
Thank you in advance for your help.
Glen
