    BSEC Arduino Library v1.4.7.3 compile error ESP32
    TGN
    When I compile the basic.ino example I get the folowing errors
    IDE Version 1.8.9
    ESP version v1.0.3-rc1
    libraries\BSEC-Arduino-library-master\bsec.cpp.o:(.literal._ZN4Bsec11beginCommonEv+0x0): undefined reference to `bsec_init'
    libraries\BSEC-Arduino-library-master\bsec.cpp.o:(.literal._ZN4Bsec11beginCommonEv+0x4): undefined reference to `bsec_get_version'
    libraries\BSEC-Arduino-library-master\bsec.cpp.o:(.literal._ZN4Bsec18updateSubscriptionEP21bsec_virtual_sensor_thf+0x0): undefined reference to `bsec_update_subscription'
    libraries\BSEC-Arduino-library-master\bsec.cpp.o:(.literal._ZN4Bsec15readProcessDataEx19bsec_bme_settings_t+0x8): undefined reference to `bsec_do_steps'
    libraries\BSEC-Arduino-library-master\bsec.cpp.o:(.literal._ZN4Bsec3runEv+0x0): undefined reference to `bsec_sensor_control'
    Any idea
    /Torben
    handytech
    Could you please confirm that you have followed the BSEC Arduino Library installation instructions, especially the changes to the platform.txt file?
    It seems like the compiler cannot find the library, therefore it could be useful to enable the compilation verbose (in the Preferences settings of the Arduino IDE). If still facing this issue, you could share/attach a log the compilation verbose here.
    shellywang
    Occasional Contributor
    Please check whether libalgobsec.a   linked in the setting.
    And go to Sensor tech website download page,find guide information inside:
    https://www.bosch-sensortec.com/bst/support_tools/downloads/overview_downloads
    Casio
    Linking everything together...
    "D:\\Documenti\\ArduinoData\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-gcc" -nostdlib "-LD:\\Documenti\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/lib" "-LD:\\Documenti\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/ld" -T esp32_out.ld -T esp32.common.ld -T esp32.rom.ld -T esp32.peripherals.ld -T esp32.rom.libgcc.ld -T esp32.rom.spiram_incompatible_fns.ld -u ld_include_panic_highint_hdl -u call_user_start_cpu0 -Wl,--gc-sections -Wl,-static -Wl,--undefined=uxTopUsedPriority -u __cxa_guard_dummy -u __cxx_fatal_exception -Wl,--start-group "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_595859\\sketch\\BMELora_3.ino.cpp.o" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_595859\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_595859\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_595859\\libraries\\Adafruit_Unified_Sensor\\Adafruit_Sensor.cpp.o" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_595859\\libraries\\Adafruit_BME680_Library\\bme680.c.o" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_595859\\libraries\\Adafruit_BME680_Library\\Adafruit_BME680.cpp.o" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_595859\\libraries\\Adafruit_BME280_Library\\Adafruit_BME280.cpp.o" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_595859\\libraries\\Heltec_ESP32_Dev-Boards\\heltec.cpp.o" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_595859\\libraries\\Heltec_ESP32_Dev-Boards\\lora\\LoRa.cpp.o" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_595859\\libraries\\Heltec_ESP32_Dev-Boards\\oled\\OLEDDisplay.cpp.o" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_595859\\libraries\\Heltec_ESP32_Dev-Boards\\oled\\OLEDDisplayUi.cpp.o" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_595859\\libraries\\Adafruit_VEML6075_Library\\Adafruit_VEML6075.cpp.o" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_595859\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp.o" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_595859\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp.o" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_595859\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp.o" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_cache_433198\\core\\core_8c9d0aa2c2c256db948d4589ce0b6317.a" -lgcc -lesp32 -lphy -lesp_http_client -lmbedtls -lrtc -lesp_http_server -lbtdm_app -lspiffs -lbootloader_support -lmdns -lnvs_flash -lfatfs -lpp -lnet80211 -ljsmn -lface_detection -llibsodium -lvfs -ldl_lib -llog -lfreertos -lcxx -lsmartconfig_ack -lxtensa-debug-module -lheap -ltcpip_adapter -lmqtt -lulp -lfd -lfb_gfx -lnghttp -lprotocomm -lsmartconfig -lm -lethernet -limage_util -lc_nano -lsoc -ltcp_transport -lc -lmicro-ecc -lface_recognition -ljson -lwpa_supplicant -lmesh -lesp_https_ota -lwpa2 -lexpat -llwip -lwear_levelling -lapp_update -ldriver -lbt -lespnow -lcoap -lasio -lnewlib -lconsole -lapp_trace -lesp32-camera -lhal -lprotobuf-c -lsdmmc -lcore -lpthread -lcoexist -lfreemodbus -lspi_flash -lesp-tls -lwpa -lwifi_provisioning -lwps -lesp_adc_cal -lesp_event -lopenssl -lesp_ringbuf -lfr -lstdc++ -Wl,--end-group -Wl,-EL -o "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_595859/BMELora_3.ino.elf"
    C:\Users\User\AppData\Local\Temp\arduino_build_595859\sketch\BMELora_3.ino.cpp.o:(.literal.startup._GLOBAL__sub_I_transmissiontime+0x14): undefined reference to `Bsec::Bsec()'
    C:\Users\User\AppData\Local\Temp\arduino_build_595859\sketch\BMELora_3.ino.cpp.o: In function `_GLOBAL__sub_I_transmissiontime':
    D:\Documenti\Arduino\BMELora_3/BMELora_3.ino:20: undefined reference to `Bsec::Bsec()'
    Uso la libreria Wire alla versione 1.0.1 nella cartella: D:\Documenti\ArduinoData\packages\esp32\hardware\esp32\1.0.4\libraries\Wire
    Uso la libreria SPI alla versione 1.0 nella cartella: D:\Documenti\ArduinoData\packages\esp32\hardware\esp32\1.0.4\libraries\SPI
    Uso la libreria Adafruit_Unified_Sensor alla versione 1.1.2 nella cartella: D:\Documenti\Arduino\libraries\Adafruit_Unified_Sensor
    Uso la libreria Adafruit_BME680_Library alla versione 1.0.7 nella cartella: D:\Documenti\Arduino\libraries\Adafruit_BME680_Library
    Uso la libreria Adafruit_BME280_Library alla versione 2.0.1 nella cartella: D:\Documenti\Arduino\libraries\Adafruit_BME280_Library
    Uso la libreria BSEC_Software_Library alla versione 1.5.1474 nella cartella: D:\Documenti\Arduino\libraries\BSEC_Software_Library
    Uso la libreria Heltec_ESP32_Dev-Boards alla versione 1.0.9 nella cartella: D:\Documenti\Arduino\libraries\Heltec_ESP32_Dev-Boards
    Uso la libreria Adafruit_VEML6075_Library alla versione 2.0.0 nella cartella: D:\Documenti\Arduino\libraries\Adafruit_VEML6075_Library
    Uso la libreria Adafruit_BusIO alla versione 1.2.1 nella cartella: D:\Documenti\Arduino\libraries\Adafruit_BusIO
    exit status 1
    Errore durante la compilazione per la scheda Heltec WiFi LoRa 32(V2).
