03-13-2022 07:12 PM
Hi. I am trying to implement BSEC library to my project but I am getting hard times how to change measurement settings like IIR filter, oversampling rates of temperature, humidity or pressure. I assume I should change it here:
03-14-2022 07:54 AM
Hello domko99,
You could download BSEC1.4.8.0 package, refer attachment example code.
03-14-2022 08:26 AM
I did but there is nothing about setting measurement. I was trying to call sensor struct and change parameters but sensor is ignoring it. So I dont know.
03-29-2022 04:40 AM
Hi domko99,
You can manually set the measurement parameters, as shown in the code. However, if you use BSEC, you are not recommended to modify it. We are not sure what impact any modification of measurement parameters will have on BSEC.
