    BSEC BME680 measures 10 times then stops.
    acanthe
    I am attempting to get the BME680 up and running on the nrf52840dk board and I am using the iot example provided code.
    My problem is that after a certain amount of time (its the same timestamp), output_ready is no longer called and only bme680_get_sensor_mode is called every ~33 seconds despite being on LP mode.
    I'm hoping for some guidance in how to start troubleshooting this because I am a little lost as to what I can do without modifying the bsec library. The numbers at the end of the status values are tags I added for identification (so I knew which one was called).
    I have attached the .c file for the iot_example I am using and the main function is below (its just the stock code included):
    PROCESS_THREAD(env_test_process, ev, data)
    PROCESS_BEGIN();
    return_values_init ret;
    i2c_init();
    ret = bsec_iot_init(BSEC_SAMPLE_RATE_LP, 0.0f, bus_write, bus_read, sleep, state_load, config_load);
    if (ret.bme680_status)
    LOG_INFO_("Could not initialise BME680\n");
    else if (ret.bsec_status)
    LOG_INFO_("Could Not Initialise BSEC Library\n");
    bsec_iot_loop(sleep, get_timestamp_us, output_ready,state_save, 10000);
    PROCESS_END();
    LOG OUTPUT:
    __________________________
    ------------MEASUREMENTS----------x100--------
    bsec_status: 0
    timestamp: 24101562000
    IAQ index: 2500, Accuracy: 0
    Temperature: 2900
    Humidity: 4600
    Pressure: 10020800
    Gas: 2773500
    CO2 Equivalent: 0
    VOC Equivalent: 0
    bme680_status = 0 4
    bme680_status = 0 3
    bme680_status = 0 1
    bme680_status = 0 6
    bsec_status = 0 5
    bsec_status: 0
    timestamp: 27101562000
    Temperature: 2900
    Humidity: 4600
    Pressure: 10020400
    Gas: 2983900
    CO2 Equivalent: 0
    VOC Equivalent: 0
    bme680_status = 0 4
    bme680_status = 0 3
    bme680_status = 0 1
    bme680_status = 0 6
    bsec_status = 0 5
    bsec_status: 0
    timestamp: 30101562000
    Temperature: 2900
    Humidity: 4600
    Pressure: 10020800
    Gas: 3168200
    CO2 Equivalent: 0
    VOC Equivalent: 0
    bme680_status = 0 4
    bme680_status = 0 3
    bme680_status = 0 1
    bme680_status = 0 6
    bsec_status = 0 5
    bsec_status: 0
    timestamp: 33109375000
    Temperature: 2900
    Humidity: 4600
    Pressure: 10020800
    Gas: 3320700
    CO2 Equivalent: 0
    VOC Equivalent: 0
    bme680_status = 0 1
    bme680_status = 0 1
    bme680_status = 0 1
    bme680_status = 0 1
    bme680_status = 0 1
    bme680_status = 0 1
    bme680_status = 0 1
    bme680_status = 0 1
    bme680_status = 0 1
    12 REPLIES 12
    EmiQS
    Hello acanthe, I'm experiencing similar issues. In my case the regular cycle takes 10.6seconds, but some times BSEC takes as long as 120seconds to give me a IAQ value.
    I see in your logs IAQ is always 25. Are you having problems with IAQ not moving from 25 (acc = 0) too?
    I'll follow your topic!
    Regards.
    At the moment I am just trying to get it to continually get measurements (I assumed its not having time to calibrate/settle) but I can imagine once this is solved I may have that problem.
    Nice to know I am not the only one with this issue!
    NOTE: the device isn't hanging, from what I have gathered so far it looks like sensor_settings->trigger_measurement and sensor_settings->process_data are both 0 after a minute or so and do not change.
    Minhwan
    Hello Acanthe,
    Are you using BSEC 1 or 2?
    If you are using BME680, you have to use BSEC 1. If you pursue to use BSEC 2, please use BME688.
    And if you are using BME680 and BSEC 1 and facing this issue, please let me know which example you are using.
    Hi Minhwan,
    I have checked version and I am using BSEC 1.4.8.0.
    As for which example, its the bsec_iot_example.c file. I have filled in the functions except for config_load (arduino example doesnt seem to need this to run)
