    BSEC BME680 measures 10 times then stops.
    acanthe
    I am attempting to get the BME680 up and running on the nrf52840dk board and I am using the iot example provided code.
    My problem is that after a certain amount of time (its the same timestamp), output_ready is no longer called and only bme680_get_sensor_mode is called every ~33 seconds despite being on LP mode.
    I'm hoping for some guidance in how to start troubleshooting this because I am a little lost as to what I can do without modifying the bsec library. The numbers at the end of the status values are tags I added for identification (so I knew which one was called).
    I have attached the .c file for the iot_example I am using and the main function is below (its just the stock code included):
    PROCESS_THREAD(env_test_process, ev, data)
    PROCESS_BEGIN();
    return_values_init ret;
    i2c_init();
    ret = bsec_iot_init(BSEC_SAMPLE_RATE_LP, 0.0f, bus_write, bus_read, sleep, state_load, config_load);
    if (ret.bme680_status)
    LOG_INFO_("Could not initialise BME680\n");
    else if (ret.bsec_status)
    LOG_INFO_("Could Not Initialise BSEC Library\n");
    bsec_iot_loop(sleep, get_timestamp_us, output_ready,state_save, 10000);
    PROCESS_END();
    LOG OUTPUT:
    __________________________
    ------------MEASUREMENTS----------x100--------
    bsec_status: 0
    timestamp: 24101562000
    IAQ index: 2500, Accuracy: 0
    Temperature: 2900
    Humidity: 4600
    Pressure: 10020800
    Gas: 2773500
    CO2 Equivalent: 0
    VOC Equivalent: 0
    bme680_status = 0 4
    bme680_status = 0 3
    bme680_status = 0 1
    bme680_status = 0 6
    bsec_status = 0 5
    bsec_status: 0
    timestamp: 27101562000
    Temperature: 2900
    Humidity: 4600
    Pressure: 10020400
    Gas: 2983900
    CO2 Equivalent: 0
    VOC Equivalent: 0
    bme680_status = 0 4
    bme680_status = 0 3
    bme680_status = 0 1
    bme680_status = 0 6
    bsec_status = 0 5
    bsec_status: 0
    timestamp: 30101562000
    Temperature: 2900
    Humidity: 4600
    Pressure: 10020800
    Gas: 3168200
    CO2 Equivalent: 0
    VOC Equivalent: 0
    bme680_status = 0 4
    bme680_status = 0 3
    bme680_status = 0 1
    bme680_status = 0 6
    bsec_status = 0 5
    bsec_status: 0
    timestamp: 33109375000
    Temperature: 2900
    Humidity: 4600
    Pressure: 10020800
    Gas: 3320700
    CO2 Equivalent: 0
    VOC Equivalent: 0
    bme680_status = 0 1
    bme680_status = 0 1
    bme680_status = 0 1
    bme680_status = 0 1
    bme680_status = 0 1
    bme680_status = 0 1
    bme680_status = 0 1
    bme680_status = 0 1
    bme680_status = 0 1
    12 REPLIES 12
    Does your clock time have 32 bits output or 64 bits?
    its 32 bits -> type is uint32_t
    get_timestamp_us is micro second unit. Why did you multiply 1000000 and devide clock_second?
    the output of clock_time is the system time in ticks, not ms or us which is why I've had to divide by CLOCK_SECOND which converts to s, and multiply before the divide to not lose resolution and get us.
    Minhwan
    Hello acanthe,
    I understood.
    If you don't have any system clock which is 64 bits, need to make it your own timestamp.
    Since, BSEC library checks it how long it BME688 can sleep.
    I managed to fix the problem, the cause was that I had divided by 128 to get the clock in seconds BEFORE i cast to int64_t. Casting afterwards allowed the clock the manage its max value as it normally would do. In other words, because the clock never reached the max value of a uint32_t the clock never knew it had reset.
    The sensor takes 10 or so minutes but it seems to be getting accuracy readings now (1/2/3) which is great.
    Thanks for your help Minhwan walking through the steps.
