    BSEC BME680 output value
    chakey
    Dear guys,
    I think I have successfully import the BSEC library and now can get the data from I2C bus.
    Since I got the output value, but I am not sure if this is correct, so need your help to confirm.
    another question is how can I calculate the ethanol? not clear after reading the datasheet(especially Table 5).
    MCU chip is stm32g0b0ve, I use IAR IDE (version 9.20.1) to debug.
    below is the code that I modify based on the sample code.
    #include "target_config.h"
    #include "bsec_integration.h"
    #include "bsec_serialized_configurations_iaq.h"
    #include "i2c.h"
    #include "uart.h"
    /* functions */
    * @brief Write operation in either I2C or SPI
    * param[in] dev_addr I2C or SPI device address
    * param[in] reg_addr register address
    * param[in] reg_data_ptr pointer to the data to be written
    * param[in] data_len number of bytes to be written
    * @return result of the bus communication function
    int8_t bus_write(uint8_t reg_addr, uint8_t *reg_data_ptr, uint32_t data_len, void *dev_addr)
    // Please insert system specific function to write to the bus where BME680 is connected
    uint8_t slaveaddr = *(uint8_t *) dev_addr;
    //if((I2C_MasterSend(I2C_2,slaveaddr,reg_data_ptr,data_len,I2C_MEM_MUTEX_TIMEOUT))!= HAL_OK)
    if(I2C_Reg_MasterSend(I2C_2, reg_addr, slaveaddr, reg_data_ptr ,data_len, I2C_MUTEX_TIMEOUT) != HAL_OK)
    putstring("bus_write error for voc sensor.\r\n\0");
    return 0;//useless return value
    * @brief Read operation in either I2C or SPI
    * param[out] reg_data_ptr pointer to the memory to be used to store the read data
    * param[in] data_len number of bytes to be read
    int8_t bus_read(uint8_t reg_addr, uint8_t *reg_data_ptr, uint32_t data_len, void *dev_addr)
    // Please insert system specific function to read from bus where BME680 is connected
    //uint8_t slaveaddr = (0x76 <<1);
    int ret = I2C_Reg_MasterRead(I2C_2, reg_addr, slaveaddr, reg_data_ptr ,data_len, I2C_MUTEX_TIMEOUT);
    //int ret = I2C_MasterRead(I2C_2,slaveaddr,reg_data_ptr,data_len, I2C_MEM_MUTEX_TIMEOUT);
    if(ret != HAL_OK)
    putstring("bus_read error for voc sensor.\r\n\0");
    * @brief System specific implementation of sleep function
    * @param[in] t_us Time in microseconds
    * @param[in] intf_ptr Pointer to the interface descriptor
    * @return none
    void sleep_n(uint32_t t_us, void *intf_ptr)
    // Please insert system specific function sleep or delay for t_ms milliseconds
    osDelay(t_us/1000);
    * @brief Capture the system time in microseconds
    * @return system_current_time current system timestamp in microseconds
    uint32_t get_timestamp_us()
    uint32_t system_current_time = 0;
    // Please insert system specific function to retrieve a timestamp (in microseconds)
    system_current_time = xTaskGetTickCount() * 1000;
    return system_current_time;
    * @brief Handling of the ready outputs
    * @param[in] timestamp time in milliseconds
    * @param[in] iaq IAQ
    * @param[in] iaq_accuracy IAQ accuracy
    * @param[in] static_iaq static IAQ
    * @param[in] temperature raw temperature
    * @param[in] humidity raw humidity
    * @param[in] temperature temperature
    * @param[in] humidity humidity
    * @param[in] pressure pressure
    * @param[in] gas raw gas
    * @param[in] gas_percentage gas percentage
    * @param[in] co2_equivalent CO2 equivalent
    * @param[in] breath_voc_equivalent breath VOC equivalent
    * @param[in] stabStatus stabilization status
    * @param[in] runInStatus run in status
    * @param[in] bsec_status value returned by the bsec_do_steps() call
    * @return none
    void output_ready(int64_t timestamp, float iaq, uint8_t iaq_accuracy, float temperature, float humidity,
    float pressure, float raw_temperature, float raw_humidity, float gas, float gas_percentage, bsec_library_return_t bsec_status,
    float static_iaq, float stabStatus, float runInStatus, float co2_equivalent, float breath_voc_equivalent)
    // Please insert system specific code to further process or display the BSEC outputs
    char str[50];
    sprintf(str,"static_iaq===%f \r\n\0",breath_voc_equivalent);
    putstring(str);
    * @brief Load previous library state from non-volatile memory
    * @param[in,out] state_buffer buffer to hold the loaded state string
    * @param[in] n_buffer size of the allocated state buffer
    * @return number of bytes copied to state_buffer
    uint32_t state_load(uint8_t *state_buffer, uint32_t n_buffer)
    // Load a previous library state from non-volatile memory, if available.
    // Return zero if loading was unsuccessful or no state was available,
    // otherwise return length of loaded state string.
    return 0;
    * @brief Save library state to non-volatile memory
    * @param[in] state_buffer buffer holding the state to be stored
    * @param[in] length length of the state string to be stored
    * @return none
    void state_save(const uint8_t *state_buffer, uint32_t length)
    // Save the string some form of non-volatile memory, if possible.
    * @brief Load library config from non-volatile memory
    * @param[in,out] config_buffer buffer to hold the loaded state string
    * @return number of bytes copied to config_buffer
    uint32_t config_load(uint8_t *config_buffer, uint32_t n_buffer)
    // Load a library config from non-volatile memory, if available.
    // Return zero if loading was unsuccessful or no config was available,
    // otherwise return length of loaded config string.
    memcpy(config_buffer,bsec_config_iaq,sizeof(bsec_config_iaq));
    return sizeof(bsec_config_iaq);
    * @brief Main function which configures BSEC library and then reads and processes the data from sensor based
    * on timer ticks
    * @return result of the processing
    int start_voc(void)
    return_values_init ret;
    /* Call to the function which initializes the BSEC library
    * Switch on low-power mode and provide no temperature offset */
    ret = bsec_iot_init(BSEC_SAMPLE_RATE_CONT, 0.0f, bus_write, bus_read, sleep_n, state_load, config_load);
    if (ret.bme68x_status)
    /* Could not intialize BME68x */
    return (int)ret.bme68x_status;
    else if (ret.bsec_status)
    /* Could not intialize BSEC library */
    return (int)ret.bsec_status;
    /* Call to endless loop function which reads and processes data based on sensor settings */
    /* State is saved every 10.000 samples, which means every 10.000 * 3 secs = 500 minutes */
    bsec_iot_loop(sleep_n, get_timestamp_us, output_ready, state_save, 1);
    return 0;
    and here is the output value in output_ready().
    Hi chakey,
    You could print output value with following reference code on STM32.
    float pressure, float raw_temperature, float raw_humidity, float gas, bsec_library_return_t bsec_status,
    float static_iaq, float co2_equivalent, float breath_voc_equivalent)
    PDEBUG("timestamp=%lld, iaq=%f, iaq_accuracy=%d, temperature=%f, humity=%f, pressure=%f, \
    raw_temperature=%f, raw_humity=%f, gas=%f, bsec_status=%d, static_iaq=%f, co2_equivalent=%f, \
    breath_voc_equivalent=%f\r\n", timestamp, iaq, iaq_accuracy, temperature, humidity, pressure, \
    raw_temperature, raw_humidity, gas, bsec_status, static_iaq, co2_equivalent, breath_voc_equivalent);
    BSEC does not output calculations of ethanol, you could refer the supported BSEC output value from integration guide.
    The calibration status value iaq accuracy must reach 3 to obtain a high-precision output value.
    Hi BSTRobin
    Thanks for the update!
    Regarding to calculations of ethanol, is there any formula I can refer to calculate ethanol value?
    Regarding to calibration status value iaq accuracy, how can I configure to get a high-precision output value? or just wait some time(if yes, how long)?
    Thanks again.
    Hi chakey,
    BME680 is a metal-oxide based chemical sensor. The sensor output is created by interaction of volatile organic compounds (VOCs) with the sensitive layer of BME680. Unlike a physical sensor (e.g. pressure sensor like BMP), chemical sensors are thus influenced by a plethora of parameters and their response is very complex. On the one hand, this implies that quantification of VOCs is not possible in a random VOC mixture like the one the sensor faces in a real world environment.
    Take LP mode as an example:
    The IAQ value obtained within 8 hours is not credible, and it can be obtained after more than 8 hours.
    After 7 days, the output value of different sensors under the same environment should be within the scope of the specification, ± 15+± 15%.
    Thanks BSTRobin for the clarification!
