    BSEC_E_CONFIG_VERSIONMISMATCH
    Re: BSEC_E_CONFIG_VERSIONMISMATCH
    I will try to record the SPI data and to create a IAR project in simulation mode.
    If I succeed, you will be able to test the project in the simulation mode with IAR without hardware. Do you think it will help?
    Best regards
    Mich
    Hi Mich,
    Please send your integrate code for me, need further analysis.
    Best regards.
    I just had the same error message -34 version mismatch, although it worked several days ago.
    I am using a different hardware configuration (ESP32, Adruino-IDE respectively Visual Studio) but maybe the solution is the same.
    There was an update of the BSEC-library, but in case of the Arduino-IDE you have to copy manually the compiled binary library file to a different directory, what I forgot to do.
    At the end the error message means wat it says: the new .h header-files did not match with the old library file I forgot to replace with the new library file.
    Best regards, Martin
