    BSEC_E_CONFIG_VERSIONMISMATCH
    Highlighted
    Re: BSEC_E_CONFIG_VERSIONMISMATCH
    I update as requested (previously I commented  /* Load previous library state, if available */  bsec_state_len = state_load(bsec_state, sizeof(bsec_state));)
    Now error is at :
    /* Call bsec_update_subscription() to enable/disable the requested virtual sensors */
    status = bsec_update_subscription(requested_virtual_sensors, n_requested_virtual_sensors, required_sensor_settings,
    &n_required_sensor_settings);
    debug_str("status ");
    debug_dec16(status);
    debug_str("\r\n");
    => status -16
    => BSEC_E_SU_SAMPLINTVLINTEGERMULT = -16, /*!< The sample_rate of the requested output (virtual) sensor passed to bsec_update_subscription() is not correct */
    Highlighted
    Please let me see the sample_rate in your configurate.
    Example, the sample rate is BSEC_SAMPLE_RATE_LP in example code
    bme680_bsec_update_subscription(float sample_rate)
    You could find the value in this function.
    /* Call to the function which initializes the BSEC library
    * Switch on low-power mode and provide no temperature offset */
    ret_bsec = bsec_iot_init(BSEC_SAMPLE_RATE_LP, 0.0f, bus_write, bus_read, sleep, state_load, config_load);
    Highlighted
    I did as you suggested:
    ret = bsec_iot_init(BSEC_SAMPLE_RATE_LP, 0.0f, bus_write, bus_read, sleep, state_load, config_load);
    The I2C link is OK because the first test is to read the Chip id and the value read is 0x61
    Highlighted
    How about current state, any other error or still error -0x16?
    Highlighted
    yes, -16 when config_load is empty and -34 when config_load set bsec_config_iaq
