05-08-2023 09:59 PM
I am working on a BME680 project which uses BSEC2.4.0.0_Generic_Release_23012023 .
I am getting BSEC_E_SU_SAMPLERATELIMITS error while initializing the BSec library from the following function
ret = bsec_iot_init(BSEC_SAMPLE_RATE_ULP, 0.0f, bus_write, bus_read, sleep_n, state_load, config_load, bme_dev);
MY plateform detail is as follow
Device: STM32WB5MMGH6 (cortex M4FPU).
Compiler:GCC
I have used the correct libalogobsec.a file for cortex M4F With GCC.
Additionally ,Changing sample rate does not make any difference.
Please help me out with the above problem
05-10-2023 10:08 AM
Hi JimitP,
You need to modify sampel rate from BSEC_SAMPLE_RATE_ULP toBSEC_SAMPLE_RATE_SCAN if you run reference code without any modification.
