    BSEC library for Azure Sphere
    jeremynz
    I posted some of this earlier at the end of this thread https://community.bosch-sensortec.com/t5/MEMS-sensors-forum/BSEC-integration-problem-on-gcc-Cortex-A... but perhaps it was unnoticed as that thread is already marked as solved.
    I'm using a BME680 with an Azure Sphere kit. I want to use the BSEC library but I am getting a variety of linking errors.
    The Azure Sphere is based off a MT3260, which has a Cortex-A7 core and 2 x Cortex-M4 cores. I want to integrate the BSEC library into my Cortex-A7 application.
    I have tried the following versions of libalgosec.a:
    • algo\normal_version\bin\gcc\Cortex_A7\libalgosec.a from BSEC_1.4.7.4_Generic_Release.zip
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_interface.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_interface.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_interface.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_do_steps.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_do_steps.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_do_steps.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_get_configuration.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_get_configuration.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_get_configuration.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_get_state.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_get_state.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_get_state.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_get_version.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_get_version.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_get_version.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_init.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_init.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_init.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_reset_output.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_reset_output.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_reset_output.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_sensor_control.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_sensor_control.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_sensor_control.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_set_configuration.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_set_configuration.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_set_configuration.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_set_state.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_set_state.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_set_state.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_update_subscription.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_update_subscription.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_update_subscription.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(constructor_bsec.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(constructor_bsec.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(constructor_bsec.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(Bsec.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(Bsec.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(Bsec.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(ChannelHub.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(ChannelHub.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(ChannelHub.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(Entity.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(Entity.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(Entity.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(GasHumidityBaselineTracker.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(GasHumidityBaselineTracker.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(GasHumidityBaselineTracker.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(GasHumidityPreProcessor.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(GasHumidityPreProcessor.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(GasHumidityPreProcessor.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(HumidityTemperatureCorrector.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(HumidityTemperatureCorrector.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(HumidityTemperatureCorrector.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(IaqEstimator.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(IaqEstimator.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(IaqEstimator.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(SensorHeatCompensator.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(SensorHeatCompensator.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(SensorHeatCompensator.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(SensorStatusTracker.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(SensorStatusTracker.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(SensorStatusTracker.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(Serialization.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(Serialization.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(Serialization.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_data.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_data.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_data.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_rtwutil.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_rtwutil.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_rtwutil.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(convertHumidity.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(convertHumidity.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(convertHumidity.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(crcCcitt2.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(crcCcitt2.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(crcCcitt2.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(isequal.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(isequal.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(isequal.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(log.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(log.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(log.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(log10.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(log10.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(log10.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(polyval.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(polyval.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(polyval.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(sqrt.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(sqrt.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(sqrt.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(Channel.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(Channel.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(Channel.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(ExpSmoothing.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(ExpSmoothing.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(ExpSmoothing.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(ExpSmoothingBsec.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(ExpSmoothingBsec.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(ExpSmoothingBsec.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(applyScalarFunctionInPlace.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(applyScalarFunctionInPlace.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(applyScalarFunctionInPlace.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(sin.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(sin.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(sin.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_interface.o): relocation R_ARM_THM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_codegen_do_steps.o): relocation R_ARM_THM_MOVW_ABS_NC against `uv2' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_codegen_sensor_control.o): relocation R_ARM_THM_MOVW_ABS_NC against `uv2' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_codegen_update_subscription.o): relocation R_ARM_THM_MOVW_ABS_NC against `iv1' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(Bsec.o): relocation R_ARM_THM_MOVW_ABS_NC against `uv0' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(ChannelHub.o): relocation R_ARM_THM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(crcCcitt2.o): relocation R_ARM_THM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_codegen_update_subscription.o)(.text+0x54864700000376): unresolvable (null) relocation against symbol `R_ARM_THM_CALL'
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: final link failed: nonrepresentable section on output
    collect2.exe : error : ld returned 1 exit status​
    • algo\normal_version\bin\gcc\Cortex_A7\libalgosec.a from BSEC_1.4.7.2_GCC_CortexA7_20190225.zip
    • COINES\sensorAPI\bme680\BSEC\algo\bin\linux_armhf\libalgosec.a from COINES_v2.0_Linux.sh:
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_interface.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_codegen_do_steps.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_codegen_update_subscription.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(Bsec.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(ChannelHub.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(GasHumidityBaselineTracker.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(GasHumidityPreProcessor.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(SensorHeatCompensator.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(crcCcitt2.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(ChannelHub.o)(.text+0x5486470000086c): unresolvable (null) relocation against symbol `R_ARM_CALL'
    Can someone from Bosch help to provide a precompiled library to resolve these errors? The standard gcc options for the Azure Sphere toolchain are:
    -c -x c -I DRIVERS/BME680 -I LIBRARIES -I DRIVERS -I "C:\PROGRAM FILES (X86)\MICROSOFT AZURE SPHERE SDK\SYSROOTS\3+BETA1909\USR\INCLUDE" -I ..\HARDWARE\AVNET_MT3620_SK\INC -g2 -gdwarf-2 -Wall -W"strict-prototypes" -Wswitch -W"no-deprecated-declarations" -W"empty-body" -Wconversion -W"return-type" -Wparentheses -W"no-pointer-sign" -W"no-format" -Wuninitialized -W"unreachable-code" -W"unused-function" -W"unused-value" -W"unused-variable" -W"deprecated-declarations" -O0 -fno-strict-aliasing -fno-omit-frame-pointer -D_POSIX_C_SOURCE -fno-exceptions -std=c11 -fstack-protector-strong -Werror=implicit-function-declaration -B "C:\Program Files (x86)\Microsoft Azure Sphere SDK\Sysroots\3+Beta1909\tools\gcc" -march=armv7ve -mthumb -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 -ggdb -fPIC -ffunction-sections -fdata-sections --sysroot="C:\Program Files (x86)\Microsoft Azure Sphere SDK\Sysroots\3+Beta1909"
    I believe using the -fPIC -mfloat-abi=hard -fno-short-enums options when compiling BSEC will help resolve my errors.
    16 REPLIES 16
    handytech
    Unfortunately due to the current team's load and the fact that we will need to setup this new toolchain, we cannot guarantee any timeline for this new release.
    In the meantime, we could eventually offer if possible with the default release to try running BSEC in of the M4 cores mentioned in your originial post. Alternatively, I would note that it would still be possible to first collect raw sensor data in the appropriate BME680 configuration, and run BSEC offline/away from the edge  (e.g. using the BSEC dll over your datalog).
    Thanks for the reply.
    I have been looking into to using the the M4 (and M4F) versions of BSEC on the Azure Sphere, but at present I am getting different linking errors:
    >------ Build started: Project: CMakeLists, Configuration: Debug ------
      [1/4] cmd.exe /C "cd . && C:\PROGRA~2\MICROS~1\2019\COMMUN~1\Linux\gcc_arm\bin\ARM-NO~4.EXE -mcpu=cortex-m4 -g  -nostartfiles -Wl,--no-undefined -Wl,-n -T "C:/AzureSphere/RealTimeCore/linker.ld" CMakeFiles/AzureSphere_RealTimeCore.dir/main.c.obj CMakeFiles/AzureSphere_RealTimeCore.dir/mt3620-intercore.c.obj CMakeFiles/AzureSphere_RealTimeCore.dir/mt3620-timer-poll.c.obj CMakeFiles/AzureSphere_RealTimeCore.dir/mt3620-uart-poll.c.obj CMakeFiles/AzureSphere_RealTimeCore.dir/mt3620-adc.c.obj CMakeFiles/AzureSphere_RealTimeCore.dir/bsec_serialized_configurations_iaq.c.obj  -o AzureSphere_RealTimeCore.out  -lm ../../libalgobsec.a && cd ."
      FAILED: AzureSphere_RealTimeCore.out
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: ../../libalgobsec.a(bsec_codegen_update_subscription.o): in function `bsec_codegen_update_subscription':
      bsec_codegen_update_subscription.c:(.text+0x222): undefined reference to `roundf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: ../../libalgobsec.a(Bsec.o): in function `bsec_Bsec_getModHeatingDuration':
      Bsec.c:(.text+0x520): undefined reference to `powf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: Bsec.c:(.text+0x52a): undefined reference to `powf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: Bsec.c:(.text+0x580): undefined reference to `roundf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: ../../libalgobsec.a(ChannelHub.o): in function `bsec_ChannelHub_do':
      ChannelHub.c:(.text+0x204): undefined reference to `roundf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: ChannelHub.c:(.text+0x27e): undefined reference to `roundf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: ChannelHub.c:(.text+0x324): undefined reference to `roundf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: ChannelHub.c:(.text+0x3be): undefined reference to `roundf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: ../../libalgobsec.a(ChannelHub.o):ChannelHub.c:(.text+0x3e8): more undefined references to `roundf' follow
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: ../../libalgobsec.a(GasHumidityBaselineTracker.o): in function `bsec_GasHumidityBaselineTracker_filterRobustMaxMin':
      GasHumidityBaselineTracker.c:(.text+0xf0): undefined reference to `expf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: ../../libalgobsec.a(GasHumidityBaselineTracker.o): in function `bsec_GasHumidityBaselineTracker_doStep':
      GasHumidityBaselineTracker.c:(.text+0x2ca): undefined reference to `expf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: GasHumidityBaselineTracker.c:(.text+0x436): undefined reference to `fminf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: GasHumidityBaselineTracker.c:(.text+0x5d6): undefined reference to `log10f'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: GasHumidityBaselineTracker.c:(.text+0x66a): undefined reference to `expf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: GasHumidityBaselineTracker.c:(.text+0x676): undefined reference to `roundf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: ../../libalgobsec.a(GasHumidityBaselineTracker.o): in function `bsec_GasHumidityBaselineTracker_updateInterfaceDependency':
      GasHumidityBaselineTracker.c:(.text+0x92e): undefined reference to `log10f'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: GasHumidityBaselineTracker.c:(.text+0x932): undefined reference to `fabsf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: GasHumidityBaselineTracker.c:(.text+0x964): undefined reference to `floorf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: GasHumidityBaselineTracker.c:(.text+0x968): undefined reference to `roundf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: ../../libalgobsec.a(GasHumidityPreProcessor.o): in function `bsec_GasHumidityPreProcessor_doStep':
      GasHumidityPreProcessor.c:(.text+0xd2): undefined reference to `log10f'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: GasHumidityPreProcessor.c:(.text+0x13a): undefined reference to `log10f'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: ../../libalgobsec.a(HumidityTemperatureCorrector.o): in function `bsec_HumidityTemperatureCorrector_updateInterfaceDependency':
      HumidityTemperatureCorrector.c:(.text+0x132): undefined reference to `fminf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: HumidityTemperatureCorrector.c:(.text+0x13e): undefined reference to `sinf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: ../../libalgobsec.a(IaqEstimator.o): in function `bsec_IaqEstimator_doStep':
      IaqEstimator.c:(.text+0xb4): undefined reference to `fmaxf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: IaqEstimator.c:(.text+0xbc): undefined reference to `fminf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: IaqEstimator.c:(.text+0xca): undefined reference to `fmaxf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: IaqEstimator.c:(.text+0x124): undefined reference to `fmaxf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: IaqEstimator.c:(.text+0x14c): undefined reference to `powf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: IaqEstimator.c:(.text+0x154): undefined reference to `fmaxf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: IaqEstimator.c:(.text+0x15c): undefined reference to `fminf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: ../../libalgobsec.a(IaqEstimator.o): in function `bsec_IaqEstimator_updateInterfaceDependency':
      IaqEstimator.c:(.text+0x390): undefined reference to `log10f'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: IaqEstimator.c:(.text+0x394): undefined reference to `fabsf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: IaqEstimator.c:(.text+0x3a4): undefined reference to `log10f'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: IaqEstimator.c:(.text+0x3ac): undefined reference to `log10f'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: IaqEstimator.c:(.text+0x3c2): undefined reference to `log10f'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: ../../libalgobsec.a(convertHumidity.o): in function `bsec_convertHumidity':
      convertHumidity.c:(.text+0x2a): undefined reference to `logf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: convertHumidity.c:(.text+0xa4): undefined reference to `expf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: ../../libalgobsec.a(normalizeFilterBw.o): in function `bsec_normalizeFilterBw':
      normalizeFilterBw.c:(.text+0x22): undefined reference to `fminf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: normalizeFilterBw.c:(.text+0x32): undefined reference to `fminf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: ../../libalgobsec.a(sin.o): in function `bsec_b_sin':
      sin.c:(.text+0xc): undefined reference to `sinf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: ../../libalgobsec.a(sin.o): in function `bsec_sin':
      sin.c:(.text+0x1e): undefined reference to `sinf'
      c:/progra~2/micros~1/2019/commun~1/linux/gcc_arm/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: sin.c:(.text+0x26): undefined reference to `sinf'
    C:\AzureSphere\RealTimeCore\collect2.exe : error : ld returned 1 exit status
      ninja: build stopped: subcommand failed.
    Build failed.
    I'm not sure why I'm getting those errors, as -lm is already specified when compiling. In fact I am using some of those "undefined" functions in my code already, but BSEC can't seem to find them.
    What about the chance of getting the Linux armhf build (from COINES) re-compiled with the -fPIC option. Is it possible to have that this week?
    handytech
    Unfortunately we also cannot commit on this right now.
    I believe the order of the arguments in your linking command is important for dependencies to be found. Can you confirm if the compilation error persists after placing -lm last (or at least after -lalgobsec)?
    Thanks for that suggestion: I can confirm that moving the -lm to the end of the library list did resolve those undefined references.
    I will continue to look at using the BSEC library on the M4F core, although this is really not ideal. There's no official support/documentation for using I2C on that core, so I need to do the BME680 measurements on the A7, then shift the data to the M4F for BSEC processing and then shift the BSEC output back up to the A7 for dispatch.
    gtmehrer
    Occasional Visitor
    @handytech wrote:
    Could you please try the attached release compiled with the requested flasgs (-fPIC -mfloat-abi=hard -fno-short-enums)?
    https://community.bosch-sensortec.com/varuj77995/attachments/varuj77995/bst_community-mems-forum/44/...
    Thanks!  This is exactly what I needed for my application.  Can this be included in future releases?
