    BSEC library for Azure Sphere
    I posted some of this earlier at the end of this thread https://community.bosch-sensortec.com/t5/MEMS-sensors-forum/BSEC-integration-problem-on-gcc-Cortex-A... but perhaps it was unnoticed as that thread is already marked as solved.
    I'm using a BME680 with an Azure Sphere kit. I want to use the BSEC library but I am getting a variety of linking errors.
    The Azure Sphere is based off a MT3260, which has a Cortex-A7 core and 2 x Cortex-M4 cores. I want to integrate the BSEC library into my Cortex-A7 application.
    I have tried the following versions of libalgosec.a:
    • algo\normal_version\bin\gcc\Cortex_A7\libalgosec.a from BSEC_1.4.7.4_Generic_Release.zip
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_interface.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_interface.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_interface.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_do_steps.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_do_steps.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_do_steps.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_get_configuration.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_get_configuration.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_get_configuration.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_get_state.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_get_state.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_get_state.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_get_version.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_get_version.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_get_version.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_init.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_init.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_init.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_reset_output.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_reset_output.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_reset_output.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_sensor_control.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_sensor_control.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_sensor_control.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_set_configuration.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_set_configuration.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_set_configuration.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_set_state.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_set_state.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_set_state.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_update_subscription.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_update_subscription.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_update_subscription.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(constructor_bsec.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(constructor_bsec.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(constructor_bsec.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(Bsec.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(Bsec.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(Bsec.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(ChannelHub.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(ChannelHub.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(ChannelHub.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(Entity.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(Entity.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(Entity.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(GasHumidityBaselineTracker.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(GasHumidityBaselineTracker.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(GasHumidityBaselineTracker.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(GasHumidityPreProcessor.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(GasHumidityPreProcessor.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(GasHumidityPreProcessor.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(HumidityTemperatureCorrector.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(HumidityTemperatureCorrector.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(HumidityTemperatureCorrector.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(IaqEstimator.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(IaqEstimator.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(IaqEstimator.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(SensorHeatCompensator.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(SensorHeatCompensator.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(SensorHeatCompensator.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(SensorStatusTracker.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(SensorStatusTracker.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(SensorStatusTracker.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(Serialization.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(Serialization.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(Serialization.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_data.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_data.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_data.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_rtwutil.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_rtwutil.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_rtwutil.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(convertHumidity.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(convertHumidity.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(convertHumidity.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(crcCcitt2.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(crcCcitt2.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(crcCcitt2.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(isequal.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(isequal.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(isequal.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(log.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(log.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(log.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(log10.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(log10.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(log10.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(polyval.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(polyval.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(polyval.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(sqrt.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(sqrt.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(sqrt.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(Channel.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(Channel.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(Channel.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(ExpSmoothing.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(ExpSmoothing.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(ExpSmoothing.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(ExpSmoothingBsec.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(ExpSmoothingBsec.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(ExpSmoothingBsec.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(applyScalarFunctionInPlace.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(applyScalarFunctionInPlace.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(applyScalarFunctionInPlace.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(sin.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(sin.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(sin.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_interface.o): relocation R_ARM_THM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_codegen_do_steps.o): relocation R_ARM_THM_MOVW_ABS_NC against `uv2' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_codegen_sensor_control.o): relocation R_ARM_THM_MOVW_ABS_NC against `uv2' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_codegen_update_subscription.o): relocation R_ARM_THM_MOVW_ABS_NC against `iv1' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(Bsec.o): relocation R_ARM_THM_MOVW_ABS_NC against `uv0' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(ChannelHub.o): relocation R_ARM_THM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(crcCcitt2.o): relocation R_ARM_THM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_codegen_update_subscription.o)(.text+0x54864700000376): unresolvable (null) relocation against symbol `R_ARM_THM_CALL'
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: final link failed: nonrepresentable section on output
    collect2.exe : error : ld returned 1 exit status​
    • algo\normal_version\bin\gcc\Cortex_A7\libalgosec.a from BSEC_1.4.7.2_GCC_CortexA7_20190225.zip
    • COINES\sensorAPI\bme680\BSEC\algo\bin\linux_armhf\libalgosec.a from COINES_v2.0_Linux.sh:
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_interface.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_codegen_do_steps.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_codegen_update_subscription.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(Bsec.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(ChannelHub.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(GasHumidityBaselineTracker.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(GasHumidityPreProcessor.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(SensorHeatCompensator.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(crcCcitt2.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(ChannelHub.o)(.text+0x5486470000086c): unresolvable (null) relocation against symbol `R_ARM_CALL'
    Can someone from Bosch help to provide a precompiled library to resolve these errors? The standard gcc options for the Azure Sphere toolchain are:
    -c -x c -I DRIVERS/BME680 -I LIBRARIES -I DRIVERS -I "C:\PROGRAM FILES (X86)\MICROSOFT AZURE SPHERE SDK\SYSROOTS\3+BETA1909\USR\INCLUDE" -I ..\HARDWARE\AVNET_MT3620_SK\INC -g2 -gdwarf-2 -Wall -W"strict-prototypes" -Wswitch -W"no-deprecated-declarations" -W"empty-body" -Wconversion -W"return-type" -Wparentheses -W"no-pointer-sign" -W"no-format" -Wuninitialized -W"unreachable-code" -W"unused-function" -W"unused-value" -W"unused-variable" -W"deprecated-declarations" -O0 -fno-strict-aliasing -fno-omit-frame-pointer -D_POSIX_C_SOURCE -fno-exceptions -std=c11 -fstack-protector-strong -Werror=implicit-function-declaration -B "C:\Program Files (x86)\Microsoft Azure Sphere SDK\Sysroots\3+Beta1909\tools\gcc" -march=armv7ve -mthumb -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 -ggdb -fPIC -ffunction-sections -fdata-sections --sysroot="C:\Program Files (x86)\Microsoft Azure Sphere SDK\Sysroots\3+Beta1909"
    I believe using the -fPIC -mfloat-abi=hard -fno-short-enums options when compiling BSEC will help resolve my errors.
    16 REPLIES 16
    Re: BSEC library for Azure Sphere
    We took note of your post in the other thread and triggered a request for the release of the latest BSEC version with such flags for the Cortex-A7  My guesstimate for such a release would be by the end of next week, therefore I will do my best to keep you posted here with the latest status update (if not with the release itself) by then.
    Great thanks very much!
    Sorry for the late update, but due to the current load of our team, the release target had to be postponed to the middle of next week.
    Thanks for the update, I'm looking forward to the release.
