    BSEC vs BSEC Lite
    biboc
    BSEC vs BSEC Lite
    As far as I understand and I test, BSEC and BSEC Lite differ in multiple way:
    * The BSEC lite version is an abbreviated version of BSEC with reduced code size & memory requirements. It does not include functions to save the state of BSEC, if the device powers down.
    At MEMS-sensors-forum/BME680-how-to-consider-the-gas-sensing-values,
    As BSEC seems to be running without any error, the described behavior doesn't seem to be linked to the usage of the Lite version. Note that using the Lite version does prevent you from loading any config string, and therefore from possibly increasing the history period considered for the background calibration.
    No save/load state and no config load.
    Using BSEC Lite, how do I tell the library that my chip is configured in 3.3V and I want not 4days but 28days historic?
    If I can't what is the default configuration used by BSEC Lite? 3.3V and 4days?
    Tags (2)
    handytech
    Re: BSEC vs BSEC Lite
    In BSEC Lite, neither the bsec_set_configuration() nor the bsec_get_state() functions are available to reduce code size. In BSEC's Integration Guide, it is said that "generic_18v_300s_4d" is the default confuration of BSEC, therefore it is also the fixed configuration used in BSEC Lite.
