04-02-2023 08:43 AM
The example "bme68x_demo_sample" does not compile.
Out of RAM: "dram0_0_seg" overflowed by 9256 bytes.
Each instance is allocated in memory: BSEC_INSTANCE_SIZE 3272
There are two conflicting defines:
NUM_OF_SENS 4
NUM_BME68X_UNITS 8
Where to specify the number of sensors, and where is multi instance? How to run this version at least on a standard board with 8 sensors? The new version is very demanding on memory and cannot be applied to a large number of sensors > 8.
04-26-2023 09:12 PM
After uploading the demo from the 1.4 BSEC2 library, the (latest) Android app now complains about missing bsec config, but it's on the sd card.
This thread suggests matching the right version of AI studio. I'm currently on the latest, but not sure how to get older versions from Bosch.
Do you happen to have the matching versions and wouldn't mind uploading here?
04-27-2023 10:08 AM
05-31-2023 05:06 AM
Hi all,
bme68x_demo_sample is the code implement of bme68x_demo_sample.ino.bin under folder "BME688_x8Board_v1.5.0\BME688_x8Board_v1.5.0".
If you would like to run BSEC and get IAQ, CO2, estimate output, you should run the example code generic_examples https://github.com/boschsensortec/Bosch-BSEC2-Library/tree/master/examples/generic_examples
