04-13-2021 06:57 PM
Hi everyone ,
Present i am working with BMX160 IMU, as part of my application i need Acc, Gyro and Mag data for this i want to use BSXLite library.
Here is my questions,
1) How can i add BSXLite compiles library to my project(My working enviroment is in keil v5.33)?
2) Can i directly add it to my project?
3) BSXLite library is compiled for GCC?
4) Is BSXLite library is compatible with Keil?
5) Can i get acc, gyro and mag data from Library?
Thank you in advanve
Regards,
amarr
04-13-2021 10:19 PM
Hello Amar,
As far as your MCU is covered by our library, it should work.
It doesn't matter which IDE ( IAR, Keil) you are using, the problem is your MCU core.
Regarding integration work, please check 5.3.1 BSXlite integration document and below community questions.
https://community.bosch-sensortec.com/t5/MEMS-sensors-forum/BSX-Lite-Integration/td-p/7814
