11-15-2020 06:20 PM
Hello Bosch Sensortec team,
I am controlling the BNO055 with an external MCU and from the Bosch website I read that it is compatible with the BSXlite software. So is the software is integrated in the ARM cortex MCU inside the sensor or I have to manually put it in my external firmware?
Thanks and best regards,
Duy
11-16-2020 03:30 AM
if you use the fusion sensors in BNO055, you don't need to integrate the BSX lib. BNO055 has fusion sensors used by bsx full version lib.
