    Blocking behavior when intergrating BME688 to Nucleo board
    huytyskland
    Hello everyone,
    Currently, I am working with an IoT application on the board Nucleo-WL55JC1 with the sensor BME688. The example I am using is LoRaWAN_End_Node downloaded from STM32Cube MX.
    What I did: I initialized the the BME688 and set up some configuration after the initialization of MX_LoRaWAN_Init(). I, then, set up some configuration outside the while loop. I "extern"ed the variables below so that I can used them elsewhere:
    struct bme68x_dev bme;
    struct bme68x_conf conf;
    struct bme68x_heatr_conf heatr_conf;
    Order of initialization are below:
      /* Initialize all configured peripherals */
      MX_GPIO_Init();
      MX_LoRaWAN_Init();
      MX_I2C3_Init();
      /* USER CODE BEGIN 2 */
      int8_t rslt = bme68x_interface_init(&bme, BME68X_I2C_INTF);
      //bme68x_check_rslt("bme68x_interface_init", rslt);
          // UART_Transmit_IT("/init\n");
      rslt = bme68x_init(&bme);
      //Set up the measurement
      conf.filter = BME68X_FILTER_OFF;
      conf.odr = BME68X_ODR_NONE;
      conf.os_hum = BME68X_OS_16X;
      conf.os_pres = BME68X_OS_1X;
      conf.os_temp = BME68X_OS_2X;
      rslt = bme68x_set_conf(&conf, &bme);
      heatr_conf.enable = BME68X_ENABLE;
      heatr_conf.heatr_temp = 300;
      heatr_conf.heatr_dur = 100;
      rslt = bme68x_set_heatr_conf(BME68X_SEQUENTIAL_MODE, &heatr_conf, &bme);
      rslt = bme68x_set_op_mode(BME68X_SEQUENTIAL_MODE, &bme);
    For obtaining the temperature/pressure/humidity/gas level, I got the data of the sensor in the function SendTxData in the file lora_app.c:
      struct bme68x_data data;
      uint32_t del_period;
      uint8_t n_fields;
    #ifdef CAYENNE_LPP
      uint8_t channel = 0;
    #else
      uint16_t pressure = 0;
      int16_t temperature = 0;
      uint16_t humidity = 0;
      uint32_t i = 0;
      int32_t latitude = 0;
      int32_t longitude = 0;
      uint16_t altitudeGps = 0;
    #endif /* CAYENNE_LPP */
      //EnvSensors_Read(&sensor_data);
      del_period = bme68x_get_meas_dur(BME68X_SEQUENTIAL_MODE, &conf, &bme) + (heatr_conf.heatr_dur * 1000);
      bme.delay_us(del_period, bme.intf_ptr);
      int8_t rslt = bme68x_get_data(BME68X_SEQUENTIAL_MODE, &data, &n_fields, &bme);
      float senTemp = data.temperature;
      float senPres = data.pressure;
      float senHumid = data.humidity;
    The problem: as in the code, I set the sensor to work in sequential mode, however, the whole setup stopped working after the first measurement. The same thing happened when I set the sensor to work in parallel mode. Sleep mode worked okay and for Forced mode, I could achieve the first measurement before the sensor turned to sleep mode (correct).
    (the end device started the first measurement and stopped at that point).
    Question: Where should I start tracking the problem or how do I fix this problem?
    I hope to have responses from you.
    Thank you very much, Huy Nguyen.
    Hi huytyskland,
    One task is enough for BME688 sensor data read. You could refer previous attached example code on STM32 which run same platform with your's.
