04-10-2022 02:55 PM
04-11-2022 07:48 AM
Hi ilcnet,
To detect H2S, you should following BME688 application note and record H2S, import & label data, train and evaluate the algorithm, etc. with BME AI Studio.
H2S is a dangerous gas. As long as there is no open fire and high heat energy in the test environment, it will not cause combustion and explosion.
04-11-2022 08:56 AM
04-11-2022 09:09 AM - edited 04-11-2022 09:10 AM
Hi ilcnet,
Usually, the detected gas should be placed in a closed environment when you record gas data.
05-02-2022 03:25 PM
