    Bosch User Guide Example
    TMunb
    I'm new to the BMA456 accelerometer and would like to better understand this example provided on the Bosch website. The website refers to BoschSensortec / BMA456-Sensor-API in GitHub from where source and header files can be downloaded as I have done. The same page includes a User Guide with the following recommended Initializing Sequence:
    uint16_t main(void) {
    uint16_t rslt = BMA4_OK;
    uint8_t init_seq_status = 0;
    /* Declare an instance of the BMA456 device */
    struct bma4_dev dev;
    /* Modify the parameters */
    dev.dev_addr = BMA4_I2C_ADDR_PRIMARY;
    dev.interface = BMA4_I2C_INTERFACE;
    dev.bus_read = USER_i2c_read;
    dev.bus_write = USER_i2c_write;
    dev.delay = USER_delay_ms;
    dev.read_write_len = 8;
    dev.resolution = 12;
    dev.feature_len = BMA456_FEATURE_SIZE;
    /* a. Reading the chip id. */
    rslt |= bma456_init(&dev);
    /* b. Performing initialization sequence.
    c. Checking the correct status of the initialization sequence.
    rslt |= bma456_write_config_file(&dev);
    return rslt;
    struct bma4_dev is defined in one of the associated header files, bma4_defs.h, but the struct in that file has no member named 'dev_addr'. And there are other similar examples where the examples in the User Guide don't match the provided files.
    How is this User Guide intended to be used ?
    Hello ,
    Sensor API included "bma4_defs.h, bma4.h, bma4.c, bma456.c and bma456.h" files, bma4_common.c called funtion from sensor API, demostrated how to use sensor API.
