    Bsx lite arm5 compiler error
    IAnab123
    I am getting a  Error: L6242E: Cannot link object BsxFusionLibrary.o as its attributes are incompatible with the image attributes.
    ... wchart-16 clashes with wchart-32.
    Every time i use the bsx lib
    I am using the arm5 compiler
    any ideas why is that hapenning ??
    8 REPLIES 8
    Hello IAnab123,
    After you got BSXlite library, you could see library file under folder "BSXlite_Cortex_M3_M4_M4F\algo\algo_bsx\Lib". The library supported CortexM3, CortexM4, CortexM4F.
    Could we know your host MCU part number?
    zgg
    Long-established Member
    Hi
    in your ARM compiler 5 / IDE, Go to Project => Options for Target => C/C++ (AC6) tab. Make sure short enums/wchar is enabled. This is equivalent to the command line option, -fshort-enums -fshort-wchar. Using the smaller sizes will help conserve memory in the application, and the last option agrees with the size of wchar_t in the prebuild libraries.
    more could be found here: https://www.keil.com/support/docs/3975.htm
    Hello zgg,
    Host paltform and compiler must patch with BSXLite library, otherwise it will not work. Could you tell me your host platform?
    I am using keil V5.25.2.0
    My MCU is the nrf52832
    I cant compile my project with ARM 6 simply because nordic doesnt support that yet
    Best regards
    Ibrahim
