Does anyone from Bosch monitor the github project https://github.com/BoschSensortec/BMI270-Sensor-API ? I opened an issue and PR with fix in https://github.com/BoschSensortec/BMI270-Sensor-API/issues/2 but haven't had any response?
Thank you for your feedback and sorry for the late response. We will investigate the BMI270 Github library and then get back to you.
How's that response coming?
Our team is looking into the issue right now and plan to fix it within the month
The new BMI270 API was just released on the github at https://github.com/BoschSensortec/BMI270-Sensor-API. Please check if the bug is fixed or not. If yes, then please click the button "Accept as Solution".
Thank you for your feedback again.
