08-26-2019 04:05 PM
I'm trying to use ICM20948 with Fusion Library provided by Bosch. My concern is :
If yes then how. I have looked at the documentation of integration up the Fusion library and it has accel_spec , gyro_spec and mag_spec values which I suppose will be different for every sensor. How can I generate this sensor specification file?
08-26-2019 04:35 PM
HI Bale11,
It is explicitely stated in the Licensing terms that the software can only be used "in combination with BST absolute orientation sensor devices"
Please refer to the Scope of use of the software. The short answer is : no, it is exclusive to Bosch Sensortec products
