    Cannot connect to app3.0
    FAVetronics
    I cannot make Development Desktop 2.1 connect to app3.0 board.
    The board turns up in device manager as a USB device
    DD2.1 tries to connect
    but then gives up
    Iv'e tried to update fw without luck - I only get an error stating "No DFU capable USB device available":
    PS C:\COINES\v2.8.8\firmware\app3.0\coines_bridge> .\update_coines_bridge_flash_fw.bat
    dfu-util 0.9
    Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
    Copyright 2010-2019 Tormod Volden and Stefan Schmidt
    This program is Free Software and has ABSOLUTELY NO WARRANTY
    Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
    Invalid DFU suffix signature
    A valid DFU suffix will be required in a future dfu-util release!!!
    Press any key to continue . . .
    The problem is the same no matter if I connect my BMM350 module or not.
    What can I be missing?
    Hi FAVetronics,
    Have you tried the DD2.0 version on your computer?
    Could we know your Windows version and computer information(office computer or not)?
    Hi
    I've only tried DD2.1 - Where can I find DD2.0?
    I'm on an office computer, with a  i7-4790 CPU running 3,6GHz and 16GB RAM
    My OS is Windows 10 Home (22H2)
    Hi FAVetronics,
    After you install COINES to your computer, you can update the firmware to your application board 3.0 to enusre that the latest firmware is used. Refer to application note under "C:\COINES\v2.7.0\doc", run "C:\COINES\v2.7.0\firmware\app3.0\update_dd_fw.bat" to update firmware for application board 3.0.
    You can also install DD software to another computer and compare it again.
    If you have other shuttle boards(not BMM350), you can check  if other boards can connect to DD2.1 normally?
    I've tried to update FW:
    PS C:\COINES\v2.8.8\firmware\app3.0\bootloader_update> .\update_bootloader.bat
    dfu-util 0.9
    Match product ID from file: ab3d
    Opening DFU capable USB device...
    ID 108c:ab3d
    Run-time device DFU version 0110
    Claiming USB DFU Interface...
    Setting Alternate Setting #0 ...
    Determining device status: state = dfuIDLE, status = 0
    dfuIDLE, continuing
    DFU mode device DFU version 0110
    Device returned transfer size 64
    Copying data from PC to DFU device
    Download [=========================] 100% 22496 bytes
    Download done.
    state(5) = dfuDNLOAD-IDLE, status(0) = No error condition is present
    Done!
    can't detach
    Resetting USB to switch back to runtime mode
    PS C:\COINES\v2.8.8\firmware\app3.0\bootloader_update> cd..
    PS C:\COINES\v2.8.8\firmware\app3.0> .\update_dd_fw.bat
    dfu-util 0.9
    I've also installed DD2.1 my labtop (Windows 10 pro). Here I can't even open the program. When I launch it, the PC "thinks" for 1-2 seconds and then nothing else happens. I've tried to reinstall DD2.1 and to run as administrator, but nothing helps.
    I do not have other shuttle boards.
    I see some talk online that DD2.1 does not support BMM350 - can that be right? - does that mean that I've waisted my time and money?
