    Cannot get chip ID BHA260
    Minh
    I'm trying to communicate nrF52832 and  BHA260AB shuttle board but I cannot get the chip ID. I checked with the logic analyzer and saw the ACK is returned.
    this is I2C read function:
    int8_t twi_read(uint8_t sl_addr, uint8_t reg_addr, uint8_t* output, uint8_t len)
    ret_code_t err_code;
    err_code = nrf_drv_twi_tx(&m_twi, sl_addr, &reg_addr, 1, false);
    APP_ERROR_CHECK(err_code);
    nrf_delay_us(300); //not work if no delay
    NRF_LOG_FLUSH();
    err_code = nrf_drv_twi_rx(&m_twi, sl_addr, output, len);
    nrf_delay_us(500); //delay to wait for the response
    if(rx_done)
    return 0;
    else
    return -1;
    Please tell me what is the problem here? thanks.
    15 REPLIES 15
    Hello Minh,
    You should check host I2C read function, there was two I2C stop signal in your waveform.
    It works well on my side.
    Hi BSTRobin,
    Thanks for your response. I removed a stop signal but the result is still 0.
    In writing case, I received NACK like this so I cannot write data.
    BHA260 shuttle board is new and is the first time I use it. Is the firmware already uploaded to the BHA260 chipset? I feel like the chip is blocked and I cannot access it.
    Hello Minh,
    The chip ID can be read before the firmware is loaded.
    In your SW code, you need to shift one bit to the right your device address(sl_addr) to 0x50, and try it again.
    Hi BSTRobin,
    I tried with slave address 0x50 but received NACK.
    I selected the address 0x28. My hardware setup:
