    Clarification required for three different accuracy values from bsx lite library
    janakiram
    Hello,   I am using BSX Lite library on BMF055.
    There are three different functions returning accuracy values related to orientation/magnetometer.
    - bsx_get_magcalibaccuracy
    - bsx_get_orient_datastatus
    - bsx_get_magcalibprofile  (returns a structure with 'accuracy' member)
    There are many instances where each of these accuracy values don't match.   All three with three different values.
    In one of the instances  -
    - value from bsx_get_orient_datastatus is 3
    - value from bsx_get_magcalibprofile is 0
    - value from bsx_get_magcalibaccuracy is 2
    My understanding is that all these values should match.     They are called around the same time.
    Can you please clarify?
    janakiram
    Any clarification/help would be appreciated.
    bsx_get_magcalibaccuracy and the accuracy from bsx_get_magcalibprofile should be the same. If it is less than 3/3, I would personally not trust this heading too much. Once it reaches 3/3, it should only get out of a calibrated state if there is a magnetic disturbance.
    bsx_get_orient_datastatus is a bit different since it takes into account also the gyroscope and accelerometer. This is more likely to be <3, but if you are interested in heading accuracy, the magnetometer accuracy indicator is what you need.
    "around the same time" doesn't really mean much. Like I said earlier, if the mag accuracy does not stay at 3/3, you should find a better placement for the sensor without disturbances.
