03-12-2024 05:57 PM
We use BSEC version 2.4.0.0 of januari.
Normally the library should send the com_gas_value with the other raw values ( see right below), but it does not.
The text in red ( see below) comes directly from the sensor. The command is get_bsec_data() with the blue mark 1.
The compensated gas, temp and RH values should come ditectly out of the library, but it does not work,
Anyone please, who can help us? Many thanks!
03-21-2024 02:38 PM - edited 03-21-2024 02:39 PM
Hi Kep73,
Currently, the compensated temperature and humidity are already supported in the BSEC output, and the compensated gas resistance is hidden in the BSEC output, so users cannot obtain the compensated gas resistance output. We are considering opening the compensated gas resistance output in the next BSEC version.
04-22-2024 12:55 PM
Dear Robin,
Thanks alot for your reply. When will the next BSEC version ready then?
Best regards,
Jeroen
