    Compile error ESP32+BME688 dev kit
    ArunSharma
    Re: Compile error ESP32+BME688 dev kit
    I am using BSEC_2.0.6.1_Generic_Release_04302021.
    I dont see a file BSEC2 .cpp file here in the dwonloaded package. I see only BSEC.cpp its version 1.5.0 dated 23 April 2021.
    I downloaded the package from : https://www.bosch-sensortec.com/software-tools/software/bme688-software/
    ArunSharma
    I am using the platform text that you provided in the previous messages. However, I am attaching the platform.txt file I got as part of the 1.0.6 library when I installed it.
    Please use this one in
    C:\Users\omi1syv\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6
    I'm using same one.
    Please let me know and post your error if you have.
    ArunSharma
    Hi
    I tried the platform.txt file you shared now and still see same errors.  I am running on Arduino 1.8.13 IDE. Any impact and should I upgrade it?
    sketch\basic_config_state.ino.cpp.o:(.literal._Z5setupv+0x2c): undefined reference to `bsec_get_version'
    sketch\basic_config_state.ino.cpp.o: In function `Bsec::getVersion()':
    sketch/bsec.h:186: undefined reference to `bsec_get_version'
    sketch\bsec.cpp.o:(.literal._ZN4Bsec11beginCommonEv+0x0): undefined reference to `bsec_init'
    sketch\bsec.cpp.o:(.literal._ZN4Bsec18updateSubscriptionEP21bsec_virtual_sensor_thf+0x0): undefined reference to `bsec_update_subscription'
    sketch\bsec.cpp.o:(.literal._ZN4Bsec18updateSubscriptionEP21bsec_virtual_sensor_thf+0x4): undefined reference to `bme68x_init'
    sketch\bsec.cpp.o:(.literal._ZN4Bsec8getStateEPh+0x0): undefined reference to `bsec_get_state'
    sketch\bsec.cpp.o:(.literal._ZN4Bsec8setStateEPh+0x0): undefined reference to `bsec_set_state'
    sketch\bsec.cpp.o:(.literal._ZN4Bsec9setConfigEPKh+0x10): undefined reference to `bsec_set_configuration'
    sketch\bsec.cpp.o:(.literal._ZN4Bsec11processDataExRK11bme68x_data+0x0): undefined reference to `bsec_do_steps'
    sketch\bsec.cpp.o:(.literal._ZN4Bsec21setBme68xConfigForcedEv+0x0): undefined reference to `bme68x_set_conf'
    sketch\bsec.cpp.o:(.literal._ZN4Bsec21setBme68xConfigForcedEv+0x4): undefined reference to `bme68x_set_heatr_conf'
    sketch\bsec.cpp.o:(.literal._ZN4Bsec21setBme68xConfigForcedEv+0x8): undefined reference to `bme68x_set_op_mode'
    sketch\bsec.cpp.o:(.literal._ZN4Bsec23setBme68xConfigParallelEv+0x4): undefined reference to `bme68x_get_meas_dur'
    sketch\bsec.cpp.o:(.literal._ZN4Bsec3runEv+0x0): undefined reference to `bsec_sensor_control'
    sketch\bsec.cpp.o:(.literal._ZN4Bsec3runEv+0x4): undefined reference to `bme68x_get_data'
    sketch\bsec.cpp.o: In function `Bsec::beginCommon()':
    sketch/bsec.cpp:114: undefined reference to `bsec_init'
    sketch/bsec.cpp:114: undefined reference to `bsec_get_version'
    sketch\bsec.cpp.o: In function `Bsec::updateSubscription(bsec_virtual_sensor_t*, unsigned char, float)':
    sketch/bsec.cpp:151: undefined reference to `bsec_update_subscription'
    sketch/bsec.cpp:155: undefined reference to `bme68x_init'
    sketch\bsec.cpp.o: In function `Bsec::getState(unsigned char*)':
    sketch/bsec.cpp:244: undefined reference to `bsec_get_state'
    sketch\bsec.cpp.o: In function `Bsec::setState(unsigned char*)':
    sketch/bsec.cpp:257: undefined reference to `bsec_set_state'
    sketch\bsec.cpp.o: In function `Bsec::setConfig(unsigned char const*)':
    sketch/bsec.cpp:274: undefined reference to `bsec_set_configuration'
    sketch\bsec.cpp.o: In function `Bsec::processData(long long, bme68x_data const&)':
    sketch/bsec.cpp:335: undefined reference to `bsec_do_steps'
    sketch\bsec.cpp.o: In function `Bsec::setBme68xConfigForced()':
    sketch/bsec.cpp:358: undefined reference to `bme68x_set_conf'
    sketch/bsec.cpp:372: undefined reference to `bme68x_set_heatr_conf'
    sketch/bsec.cpp:376: undefined reference to `bme68x_set_op_mode'
    sketch\bsec.cpp.o: In function `Bsec::setBme68xConfigSleep()':
    sketch/bsec.cpp:388: undefined reference to `bme68x_set_op_mode'
    sketch\bsec.cpp.o: In function `Bsec::setBme68xConfigParallel()':
    sketch/bsec.cpp:408: undefined reference to `bme68x_set_conf'
    sketch/bsec.cpp:414: undefined reference to `bme68x_get_meas_dur'
    sketch/bsec.cpp:422: undefined reference to `bme68x_set_heatr_conf'
    sketch/bsec.cpp:426: undefined reference to `bme68x_set_op_mode'
    sketch\bsec.cpp.o: In function `Bsec::run()':
    sketch/bsec.cpp:173: undefined reference to `bsec_sensor_control'
    sketch/bsec.cpp:201: undefined reference to `bme68x_get_data'
    collect2.exe: error: ld returned 1 exit status
    exit status 1
    Error compiling for board Adafruit ESP32 Feather.
    I tested 1.8.15, but I think 1.8.13 should be okay. It's more like library registration problem.
    Please follow my steps.
    1) Make zip file bsec2.zip as below folder
    \bsec_2-0-6-1_generic_release_04302021\BSEC_2.0.6.1_Generic_Release_04302021\examples\bsec2
    2) Sketch -> Include Library -> Add .Zip library (Choose the zip file)
    3) Build example code
    \bsec2\examples\basic_config_state\basic_config_state.ino
