    Compile error ESP32+BME688 dev kit
    ArunSharma
    Hi , I am integrating Bosch BME688+ESP32 feather board dev kit (8 sensors) on Arduino. I have worked on it for last coupel of days and solved many issues but atlast stuck on few linker errors I believe. I have already updated the platform.txt file with ESP32 specific details. Added the path for -lalgobsec in platform.txt file along with it path.
    "-LD:\\Projects\\BME688_ESP32\\basic_config_state" -lalgobsec
    After all this I am getting the folowing errors w.r.t EEPROM and bme68x functions which are both found inside the directory.
    Arduino: 1.8.13
    BSEC: BSEC_2.0.6.1_Generic_Release_04302021
    ESP32 library: 2.0.2
    I have kept the libalgobsec.a file in teh path given above. However, I found additional instruction to add lalgobsec into eagle.app.v6.common.ld.h fro ESP8266 but cant find that file or equivalent in the ESP32/tools/sdk/ld folder. Not sure what I am missing. I have attached the platform.txt file here. Thank you.
    Note: Renamed the files to add.zip at the end to be able to upload. Please remove .zip from extn and file would be usable.
    Using built-in specs.
    COLLECT_GCC=C:\Users\aruns\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2/bin/xtensa-esp32-elf-g++
    COLLECT_LTO_WRAPPER=c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../libexec/gcc/xtensa-esp32-elf/8.4.0/lto-wrapper.exe
    Target: xtensa-esp32-elf
    Configured with: /builds/idf/crosstool-NG/.build/HOST-i686-w64-mingw32/xtensa-esp32-elf/src/gcc/configure --build=x86_64-build_pc-linux-gnu --host=i686-host_w64-mingw32 --target=xtensa-esp32-elf --prefix=/builds/idf/crosstool-NG/builds/xtensa-esp32-elf --with-local-prefix=/builds/idf/crosstool-NG/builds/xtensa-esp32-elf/xtensa-esp32-elf --with-headers=/builds/idf/crosstool-NG/builds/xtensa-esp32-elf/xtensa-esp32-elf/include --with-newlib --enable-threads=no --disable-shared --with-pkgversion='crosstool-NG esp-2021r2' --disable-__cxa_atexit --enable-cxx-flags=-ffunction-sections --disable-libgomp --disable-libmudflap --disable-libmpx --disable-libssp --disable-libquadmath --disable-libquadmath-support --with-gmp=/builds/idf/crosstool-NG/.build/HOST-i686-w64-mingw32/xtensa-esp32-elf/buildtools/complibs-host --with-mpfr=/builds/idf/crosstool-NG/.build/HOST-i686-w64-mingw32/xtensa-esp32-elf/buildtools/complibs-host --with-mpc=/builds/idf/crosstool-NG/.build/HOST-i686-w64-mingw32/xtensa-esp32-elf/buildtools/complibs-host --with-isl=/builds/idf/crosstool-NG/.build/HOST-i686-w64-mingw32/xtensa-esp32-elf/buildtools/complibs-host --enable-lto --enable-target-optspace --without-long-double-128 --disable-nls --enable-multiarch --enable-languages=c,c++ --disable-libstdcxx-verbose --enable-threads=posix --enable-gcov-custom-rtio --enable-libstdcxx-time=yes
    Thread model: posix
    gcc version 8.4.0 (crosstool-NG esp-2021r2)
    COMPILER_PATH=c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../libexec/gcc/xtensa-esp32-elf/8.4.0/;c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../libexec/gcc/;c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/
    LIBRARY_PATH=c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/no-rtti/;c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/lib/no-rtti/;c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/;c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/;c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/lib/
    COLLECT_GCC_OPTIONS='-LC:\Users\aruns\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.2/tools/sdk/esp32/lib' '-LC:\Users\aruns\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.2/tools/sdk/esp32/ld' '-T' 'esp32.rom.redefined.ld' '-T' 'memory.ld' '-T' 'sections.ld' '-T' 'esp32.rom.ld' '-T' 'esp32.rom.api.ld' '-T' 'esp32.rom.libgcc.ld' '-T' 'esp32.rom.newlib-data.ld' '-T' 'esp32.rom.syscalls.ld' '-T' 'esp32.peripherals.ld' '-mlongcalls' '-Wno-frame-address' '-fno-rtti' '-fno-lto' '-u' 'ld_include_hli_vectors_bt' '-u' '_Z5setupv' '-u' '_Z4loopv' '-u' 'esp_app_desc' '-u' 'pthread_include_pthread_impl' '-u' 'pthread_include_pthread_cond_impl' '-u' 'pthread_include_pthread_local_storage_impl' '-u' 'pthread_include_pthread_rwlock_impl' '-u' 'ld_include_highint_hdl' '-u' 'start_app' '-u' 'start_app_other_cores' '-u' '__ubsan_include' '-u' '__assert_func' '-u' 'vfs_include_syscalls_impl' '-u' 'app_main' '-u' 'newlib_include_heap_impl' '-u' 'newlib_include_syscalls_impl' '-u' 'newlib_include_pthread_impl' '-u' 'newlib_include_assert_impl' '-u' '__cxa_guard_dummy' '-v' '-D' 'ESP32' '-D' 'CORE_DEBUG_LEVEL=0' '-D' 'ARDUINO_USB_CDC_ON_BOOT=0' '-LD:\\Projects\\BME688_ESP32\\basic_config_state' '-o' 'C:\Users\aruns\AppData\Local\Temp\arduino_build_352374/basic_config_state.ino.elf'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../libexec/gcc/xtensa-esp32-elf/8.4.0/collect2.exe -fno-lto -o C:\Users\aruns\AppData\Local\Temp\arduino_build_352374/basic_config_state.ino.elf -u ld_include_hli_vectors_bt -u _Z5setupv -u _Z4loopv -u esp_app_desc -u pthread_include_pthread_impl -u pthread_include_pthread_cond_impl -u pthread_include_pthread_local_storage_impl -u pthread_include_pthread_rwlock_impl -u ld_include_highint_hdl -u start_app -u start_app_other_cores -u __ubsan_include -u __assert_func -u vfs_include_syscalls_impl -u app_main -u newlib_include_heap_impl -u newlib_include_syscalls_impl -u newlib_include_pthread_impl -u newlib_include_assert_impl -u __cxa_guard_dummy c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/lib/no-rtti/crt0.o c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/no-rtti/crti.o c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/no-rtti/crtbegin.o -LC:\Users\aruns\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.2/tools/sdk/esp32/lib -LC:\Users\aruns\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.2/tools/sdk/esp32/ld -LD:\\Projects\\BME688_ESP32\\basic_config_state -Lc:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/no-rtti -Lc:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/lib/no-rtti -Lc:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0 -Lc:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc -Lc:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/lib --Map=C:\Users\aruns\AppData\Local\Temp\arduino_build_352374/basic_config_state.ino.map --cref --gc-sections --wrap=longjmp --undefined=uxTopUsedPriority --start-group sketch\bsec_serialized_configurations_iaq.c.o sketch\bsec_serialized_configurations_selectivity.c.o sketch\basic_config_state.ino.cpp.o sketch\bsec.cpp.o sketch\commMux.cpp.o libraries\Wire\Wire.cpp.o libraries\SPI\SPI.cpp.o C:\Users\aruns\AppData\Local\Temp\arduino_cache_621254\core\core_55445baf5cdfa86bae1b4ef5cf296536.a -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lasio -lbt -lcbor -lunity -lcmock -lcoap -lnghttp -lesp-tls -lesp_adc_cal -lesp_hid -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lesp_lcd -lprotobuf-c -lprotocomm -lmdns -lesp_local_ctrl -lsdmmc -lesp_serial_slave_link -lesp_websocket_client -lexpat -lwear_levelling -lfatfs -lfreemodbus -ljsmn -ljson -llibsodium -lmqtt -lopenssl -lperfmon -lspiffs -lulp -lwifi_provisioning -lbutton -ljson_parser -ljson_generator -lesp_schedule -lesp_rainmaker -lqrcode -lws2812_led -lesp-dsp -lesp32-camera -lesp_littlefs -lfb_gfx -lasio -lcbor -lcmock -lunity -lcoap -lesp_lcd -lesp_local_ctrl -lesp_websocket_client -lexpat -lfreemodbus -ljsmn -llibsodium -lperfmon -lesp_adc_cal -lesp_hid -lfatfs -lwear_levelling -lopenssl -lspiffs -lesp_rainmaker -lmqtt -lwifi_provisioning -lprotocomm -lbt -lbtdm_app -lprotobuf-c -lmdns -ljson -ljson_parser -ljson_generator -lesp_schedule -lqrcode -lcat_face_detect -lhuman_face_detect -lcolor_detect -lmfn -ldl -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lphy -lrtc -lesp_phy -lphy -lrtc -lesp_phy -lphy -lrtc -lxt_hal -lnewlib -lstdc++ -lpthread -lgcc -lcxx -lapp_trace -lgcov -lapp_trace -lgcov -lalgobsec --end-group -EL -lstdc++ -lm -lc -lgcc -lc -lnosys -lc -lgcc c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/no-rtti/crtend.o c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/no-rtti/crtn.o -T esp32.rom.redefined.ld -T memory.ld -T sections.ld -T esp32.rom.ld -T esp32.rom.api.ld -T esp32.rom.libgcc.ld -T esp32.rom.newlib-data.ld -T esp32.rom.syscalls.ld -T esp32.peripherals.ld
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\basic_config_state.ino.cpp.o:(.literal._Z9loadStateR4Bsec+0x0): undefined reference to `EEPROM'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\basic_config_state.ino.cpp.o:(.literal._Z9loadStateR4Bsec+0xc): undefined reference to `EEPROMClass::read(int)'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\basic_config_state.ino.cpp.o:(.literal._Z9loadStateR4Bsec+0x10): undefined reference to `EEPROMClass::write(int, unsigned char)'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\basic_config_state.ino.cpp.o:(.literal._Z9loadStateR4Bsec+0x14): undefined reference to `EEPROMClass::commit()'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\basic_config_state.ino.cpp.o:(.literal._Z5setupv+0x3c): undefined reference to `EEPROMClass::begin(unsigned int)'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\basic_config_state.ino.cpp.o: in function `loadState(Bsec&)':
    D:\Projects\BME688_ESP32\basic_config_state/basic_config_state.ino:172: undefined reference to `EEPROMClass::read(int)'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:\Projects\BME688_ESP32\basic_config_state/basic_config_state.ino:174: undefined reference to `EEPROMClass::read(int)'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:\Projects\BME688_ESP32\basic_config_state/basic_config_state.ino:185: undefined reference to `EEPROMClass::write(int, unsigned char)'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:\Projects\BME688_ESP32\basic_config_state/basic_config_state.ino:188: undefined reference to `EEPROMClass::commit()'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\basic_config_state.ino.cpp.o: in function `setup()':
    D:\Projects\BME688_ESP32\basic_config_state/basic_config_state.ino:41: undefined reference to `EEPROMClass::begin(unsigned int)'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\basic_config_state.ino.cpp.o: in function `saveState(Bsec&)':
    D:\Projects\BME688_ESP32\basic_config_state/basic_config_state.ino:205: undefined reference to `EEPROMClass::write(int, unsigned char)'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:\Projects\BME688_ESP32\basic_config_state/basic_config_state.ino:204: undefined reference to `EEPROMClass::write(int, unsigned char)'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:\Projects\BME688_ESP32\basic_config_state/basic_config_state.ino:209: undefined reference to `EEPROMClass::commit()'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\bsec.cpp.o:(.literal._ZN4Bsec18updateSubscriptionEP21bsec_virtual_sensor_thf+0x0): undefined reference to `bme68x_init'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\bsec.cpp.o:(.literal._ZN4Bsec21setBme68xConfigForcedEv+0x0): undefined reference to `bme68x_set_conf'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\bsec.cpp.o:(.literal._ZN4Bsec21setBme68xConfigForcedEv+0x4): undefined reference to `bme68x_set_heatr_conf'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\bsec.cpp.o:(.literal._ZN4Bsec21setBme68xConfigForcedEv+0x8): undefined reference to `bme68x_set_op_mode'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\bsec.cpp.o:(.literal._ZN4Bsec23setBme68xConfigParallelEv+0x4): undefined reference to `bme68x_get_meas_dur'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\bsec.cpp.o:(.literal._ZN4Bsec3runEv+0x0): undefined reference to `bme68x_get_data'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\bsec.cpp.o: in function `Bsec::updateSubscription(bsec_virtual_sensor_t*, unsigned char, float)':
    sketch/bsec.cpp:152: undefined reference to `bme68x_init'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\bsec.cpp.o: in function `Bsec::setBme68xConfigForced()':
    sketch/bsec.cpp:358: undefined reference to `bme68x_set_conf'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch/bsec.cpp:372: undefined reference to `bme68x_set_heatr_conf'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch/bsec.cpp:376: undefined reference to `bme68x_set_op_mode'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\bsec.cpp.o: in function `Bsec::setBme68xConfigSleep()':
    sketch/bsec.cpp:388: undefined reference to `bme68x_set_op_mode'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\bsec.cpp.o: in function `Bsec::setBme68xConfigParallel()':
    sketch/bsec.cpp:408: undefined reference to `bme68x_set_conf'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch/bsec.cpp:414: undefined reference to `bme68x_get_meas_dur'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch/bsec.cpp:422: undefined reference to `bme68x_set_heatr_conf'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch/bsec.cpp:426: undefined reference to `bme68x_set_op_mode'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\bsec.cpp.o: in function `Bsec::run()':
    sketch/bsec.cpp:201: undefined reference to `bme68x_get_data'
    exit status 1
    Error compiling for board Adafruit ESP32 Feather.
    15 REPLIES 15
    Minhwan
    Hello Arun,
    Here are two things.
    1. You need to buy BME688 shuttle board for BSEC 2.
    2. Need to update esp32 platform.txt
    The BME688 8 array dev kit is for AI studio to gather AI studio data.
    You can't use it for BSEC 2 test. Please consider below boards.
    https://create.arduino.cc/projecthub/dragos-iosub/bme688-first-ai-gas-sensor-arduino-how-to-b8a0a6
    https://www.adafruit.com/product/5046?gclid=Cj0KCQiAip-PBhDVARIsAPP2xc24x-jOC5xE9Pw-ilsbp32weChF_RgS...
    However, still your platform.txt is the reason why you got the error.
    Please check and update the platform.txt below path.
    C:\Users\<user>\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6
    Thanks Minhwan for the file. I have bought the adafruit BME688 sensor board with me. I have two ESP32 library folders in my PC as below. I am not sure which one the compiler is reading from. I have replaced platform.txt files you shared in both both these locations and got the below errors. Not sure which version of ESP32 library should I remove to make it not-confusing. Looks like its reading platform .txt file from both places.
    First I replaced here:
    D:\Projects\BME688_ESP32\libraries\esp32\hardware\esp32\1.0.6
    error when compiled:
    Thread model: posix
    COLLECT_GCC_OPTIONS='-LC:\Users\aruns\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.2/tools/sdk/esp32/lib' '-LC:\Users\aruns\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.2/tools/sdk/esp32/ld' '-T' 'esp32.rom.redefined.ld' '-T' 'memory.ld' '-T' 'sections.ld' '-T' 'esp32.rom.ld' '-T' 'esp32.rom.api.ld' '-T' 'esp32.rom.libgcc.ld' '-T' 'esp32.rom.newlib-data.ld' '-T' 'esp32.rom.syscalls.ld' '-T' 'esp32.peripherals.ld' '-mlongcalls' '-Wno-frame-address' '-fno-rtti' '-fno-lto' '-u' 'ld_include_hli_vectors_bt' '-u' '_Z5setupv' '-u' '_Z4loopv' '-u' 'esp_app_desc' '-u' 'pthread_include_pthread_impl' '-u' 'pthread_include_pthread_cond_impl' '-u' 'pthread_include_pthread_local_storage_impl' '-u' 'pthread_include_pthread_rwlock_impl' '-u' 'ld_include_highint_hdl' '-u' 'start_app' '-u' 'start_app_other_cores' '-u' '__ubsan_include' '-u' '__assert_func' '-u' 'vfs_include_syscalls_impl' '-u' 'app_main' '-u' 'newlib_include_heap_impl' '-u' 'newlib_include_syscalls_impl' '-u' 'newlib_include_pthread_impl' '-u' 'newlib_include_assert_impl' '-u' '__cxa_guard_dummy' '-v' '-D' 'ESP32' '-D' 'CORE_DEBUG_LEVEL=0' '-D' 'ARDUINO_USB_CDC_ON_BOOT=0' '-LD:\\Projects\\BME688_ESP32\\basic_config_state' '-o' 'C:\Users\aruns\AppData\Local\Temp\arduino_build_236739/basic_config_state.ino.elf'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../libexec/gcc/xtensa-esp32-elf/8.4.0/collect2.exe -fno-lto -o C:\Users\aruns\AppData\Local\Temp\arduino_build_236739/basic_config_state.ino.elf -u ld_include_hli_vectors_bt -u _Z5setupv -u _Z4loopv -u esp_app_desc -u pthread_include_pthread_impl -u pthread_include_pthread_cond_impl -u pthread_include_pthread_local_storage_impl -u pthread_include_pthread_rwlock_impl -u ld_include_highint_hdl -u start_app -u start_app_other_cores -u __ubsan_include -u __assert_func -u vfs_include_syscalls_impl -u app_main -u newlib_include_heap_impl -u newlib_include_syscalls_impl -u newlib_include_pthread_impl -u newlib_include_assert_impl -u __cxa_guard_dummy c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/lib/no-rtti/crt0.o c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/no-rtti/crti.o c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/no-rtti/crtbegin.o -LC:\Users\aruns\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.2/tools/sdk/esp32/lib -LC:\Users\aruns\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.2/tools/sdk/esp32/ld -LD:\\Projects\\BME688_ESP32\\basic_config_state -Lc:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/no-rtti -Lc:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/lib/no-rtti -Lc:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0 -Lc:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc -Lc:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/lib --Map=C:\Users\aruns\AppData\Local\Temp\arduino_build_236739/basic_config_state.ino.map --cref --gc-sections --wrap=longjmp --undefined=uxTopUsedPriority --start-group sketch\bsec_serialized_configurations_iaq.c.o sketch\bsec_serialized_configurations_selectivity.c.o sketch\basic_config_state.ino.cpp.o sketch\bsec.cpp.o sketch\commMux.cpp.o libraries\Wire\Wire.cpp.o libraries\SPI\SPI.cpp.o core\core.a -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lasio -lbt -lcbor -lunity -lcmock -lcoap -lnghttp -lesp-tls -lesp_adc_cal -lesp_hid -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lesp_lcd -lprotobuf-c -lprotocomm -lmdns -lesp_local_ctrl -lsdmmc -lesp_serial_slave_link -lesp_websocket_client -lexpat -lwear_levelling -lfatfs -lfreemodbus -ljsmn -ljson -llibsodium -lmqtt -lopenssl -lperfmon -lspiffs -lulp -lwifi_provisioning -lbutton -ljson_parser -ljson_generator -lesp_schedule -lesp_rainmaker -lqrcode -lws2812_led -lesp-dsp -lesp32-camera -lesp_littlefs -lfb_gfx -lasio -lcbor -lcmock -lunity -lcoap -lesp_lcd -lesp_local_ctrl -lesp_websocket_client -lexpat -lfreemodbus -ljsmn -llibsodium -lperfmon -lesp_adc_cal -lesp_hid -lfatfs -lwear_levelling -lopenssl -lspiffs -lesp_rainmaker -lmqtt -lwifi_provisioning -lprotocomm -lbt -lbtdm_app -lprotobuf-c -lmdns -ljson -ljson_parser -ljson_generator -lesp_schedule -lqrcode -lcat_face_detect -lhuman_face_detect -lcolor_detect -lmfn -ldl -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lphy -lrtc -lesp_phy -lphy -lrtc -lesp_phy -lphy -lrtc -lxt_hal -lnewlib -lstdc++ -lpthread -lgcc -lcxx -lapp_trace -lgcov -lapp_trace -lgcov -lalgobsec --end-group -EL -lstdc++ -lm -lc -lgcc -lc -lnosys -lc -lgcc c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/no-rtti/crtend.o c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/no-rtti/crtn.o -T esp32.rom.redefined.ld -T memory.ld -T sections.ld -T esp32.rom.ld -T esp32.rom.api.ld -T esp32.rom.libgcc.ld -T esp32.rom.newlib-data.ld -T esp32.rom.syscalls.ld -T esp32.peripherals.ld
    exit status 1
    Next I replaced the platform.text file here.
    In file included from sketch\basic_config_state.ino.cpp:1:
    C:\Users\aruns\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.2\cores\esp32/Arduino.h:33:10: fatal error: freertos/FreeRTOS.h: No such file or directory
    #include "freertos/FreeRTOS.h"
    compilation terminated.
    exit status 1
    Minhwan
    The path should be as below.
    C:\Users\<Your name>\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6
    I downloaded and am using it below version.
    Could you test it with version 1.0.6?
    Hi Minhwan, I did as you asked.. I removed both 1.0.6 and 2.0.2 ESP32 libraries from my computer and installed 1.0.6 fresh in the location you suggested under Appdata folder. The I replaced teh platform.txt that you copied here. I am still getting error. Here is teh snapshot. Also, no, I am using the default example code of BSEC2 package given by Bosch (attached here). Any other difference that I should check. Only difference could I am using Arduino 1.8.13, if you are using a different IDE?
    I am planning to try it on another windows PC from scratch. Will keep you upated. Let me know if you think of any other checks for me.
    sketch\basic_config_state.ino.cpp.o:(.literal._Z5setupv+0x2c): undefined reference to `bsec_get_version'
    sketch\basic_config_state.ino.cpp.o: In function `Bsec::getVersion()':
    sketch/bsec.h:186: undefined reference to `bsec_get_version'
    sketch\bsec.cpp.o:(.literal._ZN4Bsec11beginCommonEv+0x0): undefined reference to `bsec_init'
    sketch\bsec.cpp.o:(.literal._ZN4Bsec18updateSubscriptionEP21bsec_virtual_sensor_thf+0x0): undefined reference to `bsec_update_subscription'
    sketch\bsec.cpp.o:(.literal._ZN4Bsec18updateSubscriptionEP21bsec_virtual_sensor_thf+0x4): undefined reference to `bme68x_init'
    sketch\bsec.cpp.o:(.literal._ZN4Bsec8getStateEPh+0x0): undefined reference to `bsec_get_state'
    sketch\bsec.cpp.o:(.literal._ZN4Bsec8setStateEPh+0x0): undefined reference to `bsec_set_state'
    sketch\bsec.cpp.o:(.literal._ZN4Bsec9setConfigEPKh+0x10): undefined reference to `bsec_set_configuration'
    sketch\bsec.cpp.o:(.literal._ZN4Bsec11processDataExRK11bme68x_data+0x0): undefined reference to `bsec_do_steps'
    sketch\bsec.cpp.o:(.literal._ZN4Bsec3runEv+0x0): undefined reference to `bsec_sensor_control'
    sketch\bsec.cpp.o:(.literal._ZN4Bsec3runEv+0x4): undefined reference to `bme68x_get_data'
    sketch\bsec.cpp.o: In function `Bsec::beginCommon()':
    sketch/bsec.cpp:114: undefined reference to `bsec_init'
    sketch/bsec.cpp:114: undefined reference to `bsec_get_version'
    sketch\bsec.cpp.o: In function `Bsec::updateSubscription(bsec_virtual_sensor_t*, unsigned char, float)':
    sketch/bsec.cpp:151: undefined reference to `bsec_update_subscription'
    sketch/bsec.cpp:155: undefined reference to `bme68x_init'
    sketch\bsec.cpp.o: In function `Bsec::getState(unsigned char*)':
    sketch/bsec.cpp:244: undefined reference to `bsec_get_state'
    sketch\bsec.cpp.o: In function `Bsec::setState(unsigned char*)':
    sketch/bsec.cpp:257: undefined reference to `bsec_set_state'
    sketch\bsec.cpp.o: In function `Bsec::setConfig(unsigned char const*)':
    sketch/bsec.cpp:274: undefined reference to `bsec_set_configuration'
    sketch\bsec.cpp.o: In function `Bsec::processData(long long, bme68x_data const&)':
    sketch/bsec.cpp:335: undefined reference to `bsec_do_steps'
    sketch\bsec.cpp.o: In function `Bsec::setBme68xConfigForced()':
    sketch\bsec.cpp.o: In function `Bsec::setBme68xConfigSleep()':
    sketch\bsec.cpp.o: In function `Bsec::setBme68xConfigParallel()':
    sketch\bsec.cpp.o: In function `Bsec::run()':
    sketch/bsec.cpp:173: undefined reference to `bsec_sensor_control'
    exit status 1
