    Compile error ESP32+BME688 dev kit
    ArunSharma
    Hi , I am integrating Bosch BME688+ESP32 feather board dev kit (8 sensors) on Arduino. I have worked on it for last coupel of days and solved many issues but atlast stuck on few linker errors I believe. I have already updated the platform.txt file with ESP32 specific details. Added the path for -lalgobsec in platform.txt file along with it path.
    "-LD:\\Projects\\BME688_ESP32\\basic_config_state" -lalgobsec
    After all this I am getting the folowing errors w.r.t EEPROM and bme68x functions which are both found inside the directory.
    Arduino: 1.8.13
    BSEC: BSEC_2.0.6.1_Generic_Release_04302021
    ESP32 library: 2.0.2
    I have kept the libalgobsec.a file in teh path given above. However, I found additional instruction to add lalgobsec into eagle.app.v6.common.ld.h fro ESP8266 but cant find that file or equivalent in the ESP32/tools/sdk/ld folder. Not sure what I am missing. I have attached the platform.txt file here. Thank you.
    Note: Renamed the files to add.zip at the end to be able to upload. Please remove .zip from extn and file would be usable.
    Using built-in specs.
    COLLECT_GCC=C:\Users\aruns\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2/bin/xtensa-esp32-elf-g++
    COLLECT_LTO_WRAPPER=c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../libexec/gcc/xtensa-esp32-elf/8.4.0/lto-wrapper.exe
    Target: xtensa-esp32-elf
    Configured with: /builds/idf/crosstool-NG/.build/HOST-i686-w64-mingw32/xtensa-esp32-elf/src/gcc/configure --build=x86_64-build_pc-linux-gnu --host=i686-host_w64-mingw32 --target=xtensa-esp32-elf --prefix=/builds/idf/crosstool-NG/builds/xtensa-esp32-elf --with-local-prefix=/builds/idf/crosstool-NG/builds/xtensa-esp32-elf/xtensa-esp32-elf --with-headers=/builds/idf/crosstool-NG/builds/xtensa-esp32-elf/xtensa-esp32-elf/include --with-newlib --enable-threads=no --disable-shared --with-pkgversion='crosstool-NG esp-2021r2' --disable-__cxa_atexit --enable-cxx-flags=-ffunction-sections --disable-libgomp --disable-libmudflap --disable-libmpx --disable-libssp --disable-libquadmath --disable-libquadmath-support --with-gmp=/builds/idf/crosstool-NG/.build/HOST-i686-w64-mingw32/xtensa-esp32-elf/buildtools/complibs-host --with-mpfr=/builds/idf/crosstool-NG/.build/HOST-i686-w64-mingw32/xtensa-esp32-elf/buildtools/complibs-host --with-mpc=/builds/idf/crosstool-NG/.build/HOST-i686-w64-mingw32/xtensa-esp32-elf/buildtools/complibs-host --with-isl=/builds/idf/crosstool-NG/.build/HOST-i686-w64-mingw32/xtensa-esp32-elf/buildtools/complibs-host --enable-lto --enable-target-optspace --without-long-double-128 --disable-nls --enable-multiarch --enable-languages=c,c++ --disable-libstdcxx-verbose --enable-threads=posix --enable-gcov-custom-rtio --enable-libstdcxx-time=yes
    Thread model: posix
    gcc version 8.4.0 (crosstool-NG esp-2021r2)
    COMPILER_PATH=c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../libexec/gcc/xtensa-esp32-elf/8.4.0/;c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../libexec/gcc/;c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/
    LIBRARY_PATH=c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/no-rtti/;c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/lib/no-rtti/;c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/;c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/;c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/lib/
    COLLECT_GCC_OPTIONS='-LC:\Users\aruns\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.2/tools/sdk/esp32/lib' '-LC:\Users\aruns\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.2/tools/sdk/esp32/ld' '-T' 'esp32.rom.redefined.ld' '-T' 'memory.ld' '-T' 'sections.ld' '-T' 'esp32.rom.ld' '-T' 'esp32.rom.api.ld' '-T' 'esp32.rom.libgcc.ld' '-T' 'esp32.rom.newlib-data.ld' '-T' 'esp32.rom.syscalls.ld' '-T' 'esp32.peripherals.ld' '-mlongcalls' '-Wno-frame-address' '-fno-rtti' '-fno-lto' '-u' 'ld_include_hli_vectors_bt' '-u' '_Z5setupv' '-u' '_Z4loopv' '-u' 'esp_app_desc' '-u' 'pthread_include_pthread_impl' '-u' 'pthread_include_pthread_cond_impl' '-u' 'pthread_include_pthread_local_storage_impl' '-u' 'pthread_include_pthread_rwlock_impl' '-u' 'ld_include_highint_hdl' '-u' 'start_app' '-u' 'start_app_other_cores' '-u' '__ubsan_include' '-u' '__assert_func' '-u' 'vfs_include_syscalls_impl' '-u' 'app_main' '-u' 'newlib_include_heap_impl' '-u' 'newlib_include_syscalls_impl' '-u' 'newlib_include_pthread_impl' '-u' 'newlib_include_assert_impl' '-u' '__cxa_guard_dummy' '-v' '-D' 'ESP32' '-D' 'CORE_DEBUG_LEVEL=0' '-D' 'ARDUINO_USB_CDC_ON_BOOT=0' '-LD:\\Projects\\BME688_ESP32\\basic_config_state' '-o' 'C:\Users\aruns\AppData\Local\Temp\arduino_build_352374/basic_config_state.ino.elf'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../libexec/gcc/xtensa-esp32-elf/8.4.0/collect2.exe -fno-lto -o C:\Users\aruns\AppData\Local\Temp\arduino_build_352374/basic_config_state.ino.elf -u ld_include_hli_vectors_bt -u _Z5setupv -u _Z4loopv -u esp_app_desc -u pthread_include_pthread_impl -u pthread_include_pthread_cond_impl -u pthread_include_pthread_local_storage_impl -u pthread_include_pthread_rwlock_impl -u ld_include_highint_hdl -u start_app -u start_app_other_cores -u __ubsan_include -u __assert_func -u vfs_include_syscalls_impl -u app_main -u newlib_include_heap_impl -u newlib_include_syscalls_impl -u newlib_include_pthread_impl -u newlib_include_assert_impl -u __cxa_guard_dummy c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/lib/no-rtti/crt0.o c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/no-rtti/crti.o c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/no-rtti/crtbegin.o -LC:\Users\aruns\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.2/tools/sdk/esp32/lib -LC:\Users\aruns\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.2/tools/sdk/esp32/ld -LD:\\Projects\\BME688_ESP32\\basic_config_state -Lc:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/no-rtti -Lc:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/lib/no-rtti -Lc:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0 -Lc:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc -Lc:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/lib --Map=C:\Users\aruns\AppData\Local\Temp\arduino_build_352374/basic_config_state.ino.map --cref --gc-sections --wrap=longjmp --undefined=uxTopUsedPriority --start-group sketch\bsec_serialized_configurations_iaq.c.o sketch\bsec_serialized_configurations_selectivity.c.o sketch\basic_config_state.ino.cpp.o sketch\bsec.cpp.o sketch\commMux.cpp.o libraries\Wire\Wire.cpp.o libraries\SPI\SPI.cpp.o C:\Users\aruns\AppData\Local\Temp\arduino_cache_621254\core\core_55445baf5cdfa86bae1b4ef5cf296536.a -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lasio -lbt -lcbor -lunity -lcmock -lcoap -lnghttp -lesp-tls -lesp_adc_cal -lesp_hid -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lesp_lcd -lprotobuf-c -lprotocomm -lmdns -lesp_local_ctrl -lsdmmc -lesp_serial_slave_link -lesp_websocket_client -lexpat -lwear_levelling -lfatfs -lfreemodbus -ljsmn -ljson -llibsodium -lmqtt -lopenssl -lperfmon -lspiffs -lulp -lwifi_provisioning -lbutton -ljson_parser -ljson_generator -lesp_schedule -lesp_rainmaker -lqrcode -lws2812_led -lesp-dsp -lesp32-camera -lesp_littlefs -lfb_gfx -lasio -lcbor -lcmock -lunity -lcoap -lesp_lcd -lesp_local_ctrl -lesp_websocket_client -lexpat -lfreemodbus -ljsmn -llibsodium -lperfmon -lesp_adc_cal -lesp_hid -lfatfs -lwear_levelling -lopenssl -lspiffs -lesp_rainmaker -lmqtt -lwifi_provisioning -lprotocomm -lbt -lbtdm_app -lprotobuf-c -lmdns -ljson -ljson_parser -ljson_generator -lesp_schedule -lqrcode -lcat_face_detect -lhuman_face_detect -lcolor_detect -lmfn -ldl -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lphy -lrtc -lesp_phy -lphy -lrtc -lesp_phy -lphy -lrtc -lxt_hal -lnewlib -lstdc++ -lpthread -lgcc -lcxx -lapp_trace -lgcov -lapp_trace -lgcov -lalgobsec --end-group -EL -lstdc++ -lm -lc -lgcc -lc -lnosys -lc -lgcc c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/no-rtti/crtend.o c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/no-rtti/crtn.o -T esp32.rom.redefined.ld -T memory.ld -T sections.ld -T esp32.rom.ld -T esp32.rom.api.ld -T esp32.rom.libgcc.ld -T esp32.rom.newlib-data.ld -T esp32.rom.syscalls.ld -T esp32.peripherals.ld
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\basic_config_state.ino.cpp.o:(.literal._Z9loadStateR4Bsec+0x0): undefined reference to `EEPROM'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\basic_config_state.ino.cpp.o:(.literal._Z9loadStateR4Bsec+0xc): undefined reference to `EEPROMClass::read(int)'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\basic_config_state.ino.cpp.o:(.literal._Z9loadStateR4Bsec+0x10): undefined reference to `EEPROMClass::write(int, unsigned char)'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\basic_config_state.ino.cpp.o:(.literal._Z9loadStateR4Bsec+0x14): undefined reference to `EEPROMClass::commit()'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\basic_config_state.ino.cpp.o:(.literal._Z5setupv+0x3c): undefined reference to `EEPROMClass::begin(unsigned int)'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\basic_config_state.ino.cpp.o: in function `loadState(Bsec&)':
    D:\Projects\BME688_ESP32\basic_config_state/basic_config_state.ino:172: undefined reference to `EEPROMClass::read(int)'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:\Projects\BME688_ESP32\basic_config_state/basic_config_state.ino:174: undefined reference to `EEPROMClass::read(int)'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:\Projects\BME688_ESP32\basic_config_state/basic_config_state.ino:185: undefined reference to `EEPROMClass::write(int, unsigned char)'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:\Projects\BME688_ESP32\basic_config_state/basic_config_state.ino:188: undefined reference to `EEPROMClass::commit()'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\basic_config_state.ino.cpp.o: in function `setup()':
    D:\Projects\BME688_ESP32\basic_config_state/basic_config_state.ino:41: undefined reference to `EEPROMClass::begin(unsigned int)'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\basic_config_state.ino.cpp.o: in function `saveState(Bsec&)':
    D:\Projects\BME688_ESP32\basic_config_state/basic_config_state.ino:205: undefined reference to `EEPROMClass::write(int, unsigned char)'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:\Projects\BME688_ESP32\basic_config_state/basic_config_state.ino:204: undefined reference to `EEPROMClass::write(int, unsigned char)'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:\Projects\BME688_ESP32\basic_config_state/basic_config_state.ino:209: undefined reference to `EEPROMClass::commit()'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\bsec.cpp.o:(.literal._ZN4Bsec18updateSubscriptionEP21bsec_virtual_sensor_thf+0x0): undefined reference to `bme68x_init'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\bsec.cpp.o:(.literal._ZN4Bsec21setBme68xConfigForcedEv+0x0): undefined reference to `bme68x_set_conf'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\bsec.cpp.o:(.literal._ZN4Bsec21setBme68xConfigForcedEv+0x4): undefined reference to `bme68x_set_heatr_conf'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\bsec.cpp.o:(.literal._ZN4Bsec21setBme68xConfigForcedEv+0x8): undefined reference to `bme68x_set_op_mode'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\bsec.cpp.o:(.literal._ZN4Bsec23setBme68xConfigParallelEv+0x4): undefined reference to `bme68x_get_meas_dur'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\bsec.cpp.o:(.literal._ZN4Bsec3runEv+0x0): undefined reference to `bme68x_get_data'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\bsec.cpp.o: in function `Bsec::updateSubscription(bsec_virtual_sensor_t*, unsigned char, float)':
    sketch/bsec.cpp:152: undefined reference to `bme68x_init'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\bsec.cpp.o: in function `Bsec::setBme68xConfigForced()':
    sketch/bsec.cpp:358: undefined reference to `bme68x_set_conf'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch/bsec.cpp:372: undefined reference to `bme68x_set_heatr_conf'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch/bsec.cpp:376: undefined reference to `bme68x_set_op_mode'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\bsec.cpp.o: in function `Bsec::setBme68xConfigSleep()':
    sketch/bsec.cpp:388: undefined reference to `bme68x_set_op_mode'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\bsec.cpp.o: in function `Bsec::setBme68xConfigParallel()':
    sketch/bsec.cpp:408: undefined reference to `bme68x_set_conf'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch/bsec.cpp:414: undefined reference to `bme68x_get_meas_dur'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch/bsec.cpp:422: undefined reference to `bme68x_set_heatr_conf'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch/bsec.cpp:426: undefined reference to `bme68x_set_op_mode'
    c:/users/aruns/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\bsec.cpp.o: in function `Bsec::run()':
    sketch/bsec.cpp:201: undefined reference to `bme68x_get_data'
    exit status 1
    Error compiling for board Adafruit ESP32 Feather.
    15 REPLIES 15
    Minhwan
    I'm wondering how you updated esp32 2.0.2?
    Since Arduino IDE currenlty only has 1.0.6.
    Could you downgrade and test again?
    Or, please let me know how to download esp32 2.0.2
    I will do from my side.
    Minhwan
    I'd like to mention clearly one more time just in case.
    BME688 dev kit 8 array doesn't work for BSEC2.
    Even after you can build correctly, you can't run on our board with bsec 2 example.
    But, I will help you until you can build successfully. Then, you can use other ESP32 board like ESP32 WROOM.
    I have teh floowing path in preferences in Arduino IDE:
    https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json
    I found ESP32 2.0.2 under board manager. snapshot below. However, I have removed 2.0.2 from my computer now and only use 1.0.6. I tested 1.0.6 as I still have the same failures from my last message. No change. Now I am trying to install from scratch on a different computer to test.
    Yes, I understand that. I won't  be using BME dev kit. I have a ESP32 feather board and BME688 adafruit board.
    https://www.adafruit.com/product/3405
    https://www.adafruit.com/product/5046
    Let me know if you see any issues in this.
    Minhwan
    Yes, please try it with 1.0.6.
    And could you let me know which bsec 2 version are you using it?
    Please let me know when is the bsec2.cpp date in bsec 2 library and share your platform.txt for 1.0.6.
