I am having difficulty getting the BSEC (April release) to compile with BSEC code. The compiler output is below and the code is attached. Your insight would be greatly appreciated.
Kind regards,
Robert
Arduino: 1.8.13 (Windows 10), Board: "Adafruit Feather HUZZAH ESP8266, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, All Flash Contents, 115200"
C:\Arduino-1-8-13\arduino-builder -dump-prefs -logger=machine -hardware C:\Arduino-1-8-13\hardware -hardware C:\Users\michm\AppData\Local\Arduino15\packages -tools C:\Arduino-1-8-13\tools-builder -tools C:\Arduino-1-8-13\hardware\tools\avr -tools C:\Users\michm\AppData\Local\Arduino15\packages -built-in-libraries C:\Arduino-1-8-13\libraries -libraries C:\Users\michm\Documents\Arduino\libraries -fqbn=esp8266:esp8266:huzzah:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=all,baud=115200 -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\michm\AppData\Local\Temp\arduino_build_465003 -warnings=none -build-cache C:\Users\michm\AppData\Local\Temp\arduino_cache_582016 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\michm\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=C:\Users\michm\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.python3.path=C:\Users\michm\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\michm\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.mklittlefs.path=C:\Users\michm\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=C:\Users\michm\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\michm\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=C:\Users\michm\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -verbose C:\Users\michm\Documents\Arduino\libraries\BME--1\BME--1.ino
C:\Arduino-1-8-13\arduino-builder -compile -logger=machine -hardware C:\Arduino-1-8-13\hardware -hardware C:\Users\michm\AppData\Local\Arduino15\packages -tools C:\Arduino-1-8-13\tools-builder -tools C:\Arduino-1-8-13\hardware\tools\avr -tools C:\Users\michm\AppData\Local\Arduino15\packages -built-in-libraries C:\Arduino-1-8-13\libraries -libraries C:\Users\michm\Documents\Arduino\libraries -fqbn=esp8266:esp8266:huzzah:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=all,baud=115200 -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\michm\AppData\Local\Temp\arduino_build_465003 -warnings=none -build-cache C:\Users\michm\AppData\Local\Temp\arduino_cache_582016 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\michm\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=C:\Users\michm\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.python3.path=C:\Users\michm\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\michm\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.mklittlefs.path=C:\Users\michm\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=C:\Users\michm\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\michm\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=C:\Users\michm\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -verbose C:\Users\michm\Documents\Arduino\libraries\BME--1\BME--1.ino
Using board 'huzzah' from platform in folder: C:\Users\michm\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2
Using core 'esp8266' from platform in folder: C:\Users\michm\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2
Detecting libraries used...
"C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_ADAFRUIT_HUZZAH -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ADAFRUIT_HUZZAH\"" -DFLASHMODE_QIO -DESP8266 "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\adafruit" "C:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003\\sketch\\BME--1.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for EEPROM.h: [EEPROM@1.0]
ResolveLibrary(EEPROM.h)
-> candidates: [EEPROM@1.0]
"C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_ADAFRUIT_HUZZAH -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ADAFRUIT_HUZZAH\"" -DFLASHMODE_QIO -DESP8266 "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\adafruit" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "C:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003\\sketch\\BME--1.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
"C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_ADAFRUIT_HUZZAH -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ADAFRUIT_HUZZAH\"" -DFLASHMODE_QIO -DESP8266 "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\adafruit" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "C:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003\\sketch\\BME--1.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_ADAFRUIT_HUZZAH -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ADAFRUIT_HUZZAH\"" -DFLASHMODE_QIO -DESP8266 "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\adafruit" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "C:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003\\sketch\\BME--1.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for bsec.h: [BME--1]
ResolveLibrary(bsec.h)
-> candidates: [BME--1]
"C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_ADAFRUIT_HUZZAH -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ADAFRUIT_HUZZAH\"" -DFLASHMODE_QIO -DESP8266 "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\adafruit" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\michm\\Documents\\Arduino\\libraries\\BME--1" "C:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003\\sketch\\BME--1.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_ADAFRUIT_HUZZAH -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ADAFRUIT_HUZZAH\"" -DFLASHMODE_QIO -DESP8266 "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\adafruit" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\michm\\Documents\\Arduino\\libraries\\BME--1" "C:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003\\sketch\\bme68x.c" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_ADAFRUIT_HUZZAH -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ADAFRUIT_HUZZAH\"" -DFLASHMODE_QIO -DESP8266 "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\adafruit" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\michm\\Documents\\Arduino\\libraries\\BME--1" "C:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003\\sketch\\bsec.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_ADAFRUIT_HUZZAH -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ADAFRUIT_HUZZAH\"" -DFLASHMODE_QIO -DESP8266 "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\adafruit" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\michm\\Documents\\Arduino\\libraries\\BME--1" "C:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003\\sketch\\bsec_serialized_configurations_iaq.c" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_ADAFRUIT_HUZZAH -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ADAFRUIT_HUZZAH\"" -DFLASHMODE_QIO -DESP8266 "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\adafruit" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\michm\\Documents\\Arduino\\libraries\\BME--1" "C:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003\\sketch\\bsec_serialized_configurations_selectivity.c" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_ADAFRUIT_HUZZAH -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ADAFRUIT_HUZZAH\"" -DFLASHMODE_QIO -DESP8266 "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\adafruit" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\michm\\Documents\\Arduino\\libraries\\BME--1" "C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM\\EEPROM.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_ADAFRUIT_HUZZAH -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ADAFRUIT_HUZZAH\"" -DFLASHMODE_QIO -DESP8266 "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\adafruit" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\michm\\Documents\\Arduino\\libraries\\BME--1" "C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire\\Wire.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_ADAFRUIT_HUZZAH -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ADAFRUIT_HUZZAH\"" -DFLASHMODE_QIO -DESP8266 "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\adafruit" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\michm\\Documents\\Arduino\\libraries\\BME--1" "C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI\\SPI.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_ADAFRUIT_HUZZAH -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ADAFRUIT_HUZZAH\"" -DFLASHMODE_QIO -DESP8266 "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\adafruit" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\michm\\Documents\\Arduino\\libraries\\BME--1" "C:\\Users\\michm\\Documents\\Arduino\\libraries\\BME--1\\bme68x.c" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_ADAFRUIT_HUZZAH -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ADAFRUIT_HUZZAH\"" -DFLASHMODE_QIO -DESP8266 "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\adafruit" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\michm\\Documents\\Arduino\\libraries\\BME--1" "C:\\Users\\michm\\Documents\\Arduino\\libraries\\BME--1\\bsec.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_ADAFRUIT_HUZZAH -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ADAFRUIT_HUZZAH\"" -DFLASHMODE_QIO -DESP8266 "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\adafruit" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\michm\\Documents\\Arduino\\libraries\\BME--1" "C:\\Users\\michm\\Documents\\Arduino\\libraries\\BME--1\\bsec_serialized_configurations_iaq.c" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_ADAFRUIT_HUZZAH -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ADAFRUIT_HUZZAH\"" -DFLASHMODE_QIO -DESP8266 "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\adafruit" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\michm\\Documents\\Arduino\\libraries\\BME--1" "C:\\Users\\michm\\Documents\\Arduino\\libraries\\BME--1\\bsec_serialized_configurations_selectivity.c" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
"C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_ADAFRUIT_HUZZAH -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ADAFRUIT_HUZZAH\"" -DFLASHMODE_QIO -DESP8266 "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\adafruit" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\michm\\Documents\\Arduino\\libraries\\BME--1" "C:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003\\sketch\\BME--1.ino.cpp" -o "C:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Arduino-1-8-13\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/signing.py" --mode header --publickey "C:\\Users\\michm\\Documents\\Arduino\\libraries\\BME--1/public.key" --out "C:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003/core/Updater_Signing.h"
"C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003/core" -c -w -Werror=return-type -std=gnu17 -Os -g -free -fipa-pta -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_ADAFRUIT_HUZZAH -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ADAFRUIT_HUZZAH\"" -DFLASHMODE_QIO -DESP8266 "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\adafruit" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\michm\\Documents\\Arduino\\libraries\\BME--1" "C:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003\\sketch\\bsec_serialized_configurations_iaq.c" -o "C:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003\\sketch\\bsec_serialized_configurations_iaq.c.o"
"C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003/core" -c -w -Werror=return-type -std=gnu17 -Os -g -free -fipa-pta -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_ADAFRUIT_HUZZAH -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ADAFRUIT_HUZZAH\"" -DFLASHMODE_QIO -DESP8266 "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\adafruit" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\michm\\Documents\\Arduino\\libraries\\BME--1" "C:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003\\sketch\\bsec_serialized_configurations_selectivity.c" -o "C:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003\\sketch\\bsec_serialized_configurations_selectivity.c.o"
"C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003/core" -c -w -Werror=return-type -std=gnu17 -Os -g -free -fipa-pta -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_ADAFRUIT_HUZZAH -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ADAFRUIT_HUZZAH\"" -DFLASHMODE_QIO -DESP8266 "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\adafruit" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\michm\\Documents\\Arduino\\libraries\\BME--1" "C:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003\\sketch\\bme68x.c" -o "C:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003\\sketch\\bme68x.c.o"
"C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_ADAFRUIT_HUZZAH -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ADAFRUIT_HUZZAH\"" -DFLASHMODE_QIO -DESP8266 "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\adafruit" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\michm\\Documents\\Arduino\\libraries\\BME--1" "C:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003\\sketch\\BME--1.ino.cpp" -o "C:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003\\sketch\\BME--1.ino.cpp.o"
"C:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_ADAFRUIT_HUZZAH -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ADAFRUIT_HUZZAH\"" -DFLASHMODE_QIO -DESP8266 "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\adafruit" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Users\\michm\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\michm\\Documents\\Arduino\\libraries\\BME--1" "C:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003\\sketch\\bsec.cpp" -o "C:\\Users\\michm\\AppData\\Local\\Temp\\arduino_build_465003\\sketch\\bsec.cpp.o"
C:\Users\michm\Documents\Arduino\libraries\BME--1\BME--1.ino: In function 'void setup()':
BME--1:43:57: error: 'class Bsec' has no member named 'version'
43 | output = "\nBSEC library version " + String(iaqSensor.version.major) + "." + String(iaqSensor.version.minor) + "." + String(iaqSensor.version.major_bugfix) + "." + String(iaqSensor.version.minor_bugfix);
BME--1:43:97: error: 'class Bsec' has no member named 'version'
BME--1:43:137: error: 'class Bsec' has no member named 'version'
BME--1:43:184: error: 'class Bsec' has no member named 'version'
C:\Users\michm\Documents\Arduino\libraries\BME--1\BME--1.ino: In function 'void loop()':
BME--1:76:39: error: 'class Bsec' has no member named 'rawTemperature'
76 | output += ", " + String(iaqSensor.rawTemperature);
BME--1:77:39: error: 'class Bsec' has no member named 'pressure'
77 | output += ", " + String(iaqSensor.pressure);
BME--1:78:39: error: 'class Bsec' has no member named 'rawHumidity'
78 | output += ", " + String(iaqSensor.rawHumidity);
BME--1:79:39: error: 'class Bsec' has no member named 'gasResistance'
79 | output += ", " + String(iaqSensor.gasResistance);
BME--1:80:39: error: 'class Bsec' has no member named 'iaq'
80 | output += ", " + String(iaqSensor.iaq);
BME--1:81:39: error: 'class Bsec' has no member named 'iaqAccuracy'
81 | output += ", " + String(iaqSensor.iaqAccuracy);
BME--1:82:39: error: 'class Bsec' has no member named 'temperature'
82 | output += ", " + String(iaqSensor.temperature);
BME--1:83:39: error: 'class Bsec' has no member named 'humidity'
83 | output += ", " + String(iaqSensor.humidity);
C:\Users\michm\Documents\Arduino\libraries\BME--1\BME--1.ino: In function 'void checkIaqSensorStatus()':
BME--1:94:17: error: 'class Bsec' has no member named 'status'
94 | if (iaqSensor.status != BSEC_OK) {
BME--1:95:19: error: 'class Bsec' has no member named 'status'
95 | if (iaqSensor.status < BSEC_OK) {
BME--1:96:56: error: 'class Bsec' has no member named 'status'
96 | output = "BSEC error code : " + String(iaqSensor.status);
BME--1:101:58: error: 'class Bsec' has no member named 'status'
101 | output = "BSEC warning code : " + String(iaqSensor.status);
BME--1:106:17: error: 'class Bsec' has no member named 'bme680Status'; did you mean 'int8_t Bsec::_bme68x_status'? (accessible via 'int8_t Bsec::getBme68xStatus() const')
106 | if (iaqSensor.bme680Status != BME680_OK) {
| getBme68xStatus()
BME--1:106:33: error: 'BME680_OK' was not declared in this scope; did you mean 'BME68X_OK'?
| BME68X_OK
BME--1:107:19: error: 'class Bsec' has no member named 'bme680Status'; did you mean 'int8_t Bsec::_bme68x_status'? (accessible via 'int8_t Bsec::getBme68xStatus() const')
107 | if (iaqSensor.bme680Status < BME680_OK) {
| getBme68xStatus()
BME--1:108:58: error: 'class Bsec' has no member named 'bme680Status'; did you mean '_bme68x_status'?
108 | output = "BME680 error code : " + String(iaqSensor.bme680Status);
| _bme68x_status
BME--1:108:58: error: 'int8_t Bsec::_bme68x_status' is private within this context
In file included from C:\Users\michm\Documents\Arduino\libraries\BME--1\BME--1.ino:2:
C:\Users\michm\AppData\Local\Temp\arduino_build_465003\sketch\bsec.h:294:9: note: declared private here
294 | int8_t _bme68x_status; // Placeholder for the BME68x driver's error codes
BME--1:113:60: error: 'class Bsec' has no member named 'bme680Status'; did you mean '_bme68x_status'?
113 | output = "BME680 warning code : " + String(iaqSensor.bme680Status);
| _bme68x_status
BME--1:113:60: error: 'int8_t Bsec::_bme68x_status' is private within this context
BME--1:117:13: error: 'class Bsec' has no member named 'status'
117 | iaqSensor.status = BSEC_OK;
C:\Users\michm\Documents\Arduino\libraries\BME--1\BME--1.ino: In function 'void updateState()':
BME--1:158:19: error: 'class Bsec' has no member named 'iaqAccuracy'
158 | if (iaqSensor.iaqAccuracy >= 3) {
C:\Users\michm\Documents\Arduino\libraries\BME--1\basic_config_state.ino: At global scope:
basic_config_state:19:6: error: redefinition of 'void setup()'
19 | void setup(void)
C:\Users\michm\Documents\Arduino\libraries\BME--1\BME--1.ino:36:6: note: 'void setup()' previously defined here
36 | void setup(void)
C:\Users\michm\Documents\Arduino\libraries\BME--1\basic_config_state.ino: In function 'void setup()':
basic_config_state:40:26: error: 'bsec_config_selectivity' was not declared in this scope
40 | !bsecInst.setConfig(bsec_config_selectivity) ||
basic_config_state:50:6: error: redefinition of 'void loop()'
50 | void loop(void)
C:\Users\michm\Documents\Arduino\libraries\BME--1\BME--1.ino:71:6: note: 'void loop()' previously defined here
71 | void loop(void)
basic_config_state:56:6: error: redefinition of 'void errLeds()'
56 | void errLeds(void)
C:\Users\michm\Documents\Arduino\libraries\BME--1\BME--1.ino:120:6: note: 'void errLeds()' previously defined here
120 | void errLeds(void)
Using library EEPROM at version 1.0 in folder: C:\Users\michm\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\EEPROM
Using library Wire at version 1.0 in folder: C:\Users\michm\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\Wire
Using library SPI at version 1.0 in folder: C:\Users\michm\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SPI
Using library BME--1 in folder: C:\Users\michm\Documents\Arduino\libraries\BME--1 (legacy)
exit status 1
The code......
include <EEPROM.h>
#include "bsec.h"
/* Configure the BSEC library with information about the sensor
18v/33v = Voltage at Vdd. 1.8V or 3.3V
3s/300s = BSEC operating mode, BSEC_SAMPLE_RATE_LP or BSEC_SAMPLE_RATE_ULP
4d/28d = Operating age of the sensor in days
generic_18v_3s_4d
generic_18v_3s_28d
generic_18v_300s_4d
generic_18v_300s_28d
generic_33v_3s_4d
generic_33v_3s_28d
generic_33v_300s_4d
generic_33v_300s_28d
const uint8_t bsec_config_iaq[] = {
//#include "config/generic_33v_3s_4d/bsec_iaq.txt"
#define STATE_SAVE_PERIOD UINT32_C(360 * 60 * 1000) // 360 minutes - 4 times a day
// Helper functions declarations
void checkIaqSensorStatus(void);
void errLeds(void);
void loadState(void);
void updateState(void);
// Create an object of the class Bsec
Bsec iaqSensor;
uint8_t bsecState[BSEC_MAX_STATE_BLOB_SIZE] = {0};
uint16_t stateUpdateCounter = 0;
String output;
// Entry point for the example
void setup(void)
EEPROM.begin(BSEC_MAX_STATE_BLOB_SIZE + 1); // 1st address for the length
Serial.begin(115200);
Wire.begin();
iaqSensor.begin(BME68X_I2C_ADDR_LOW, Wire);
Serial.println(output);
checkIaqSensorStatus();
iaqSensor.setConfig(bsec_config_iaq);
loadState();
bsec_virtual_sensor_t sensorList[7] = {
BSEC_OUTPUT_RAW_TEMPERATURE,
BSEC_OUTPUT_RAW_PRESSURE,
BSEC_OUTPUT_RAW_HUMIDITY,
BSEC_OUTPUT_RAW_GAS,
BSEC_OUTPUT_IAQ,
iaqSensor.updateSubscription(sensorList, 7, BSEC_SAMPLE_RATE_LP);
// Print the header
output = "Timestamp [ms], raw temperature [°C], pressure [hPa], raw relative humidity [%], gas [Ohm], IAQ, IAQ accuracy, temperature [°C], relative humidity [%]";
// Function that is looped forever
void loop(void)
unsigned long time_trigger = millis();
if (iaqSensor.run()) { // If new data is available
output = String(time_trigger);
updateState();
} else {
// Helper function definitions
for (;;)
errLeds(); /* Halt in case of failure */
} else {
for (;;)
} else {
void errLeds(void)
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH);
delay(100);
digitalWrite(LED_BUILTIN, LOW);
delay(100);
if (EEPROM.read(0) == BSEC_MAX_STATE_BLOB_SIZE) {
// Existing state in EEPROM
Serial.println("Reading state from EEPROM");
for (uint8_t i = 0; i < BSEC_MAX_STATE_BLOB_SIZE; i++) {
bsecState[i] = EEPROM.read(i + 1);
Serial.println(bsecState[i], HEX);
iaqSensor.setState(bsecState);
} else {
// Erase the EEPROM with zeroes
Serial.println("Erasing EEPROM");
for (uint8_t i = 0; i < BSEC_MAX_STATE_BLOB_SIZE + 1; i++)
EEPROM.write(i, 0);
EEPROM.commit();
bool update = false;
/* Set a trigger to save the state. Here, the state is saved every STATE_SAVE_PERIOD with the first state being saved once the algorithm achieves full calibration, i.e. iaqAccuracy = 3 */
if (stateUpdateCounter == 0) {
update = true;
stateUpdateCounter++;
} else {
/* Update every STATE_SAVE_PERIOD milliseconds */
if ((stateUpdateCounter * STATE_SAVE_PERIOD) < millis()) {
update = true;
if (update) {
iaqSensor.getState(bsecState);
Serial.println("Writing state to EEPROM");
for (uint8_t i = 0; i < BSEC_MAX_STATE_BLOB_SIZE ; i++) {
EEPROM.write(i + 1, bsecState[i]);
EEPROM.write(0, BSEC_MAX_STATE_BLOB_SIZE);
EEPROM.commit();
Hello BobEChuck,
Which BSEC version you used?
Normally, it had example code in BSEC package, could you run example first?
Hello BobEChuck,
ESP8266 was supported.
It seems to have something to do with your Arduino environment. Have you compiled any Arduino projects successfully?
