04-15-2020 01:16 PM
Hello ,
I have an customised board with imx6ul processor and I am able to get the BME680 sensor up and able to read the pressure,temperature value on the i2c bus line.But I am not able to get the Air quality values.After searching in the net I found the BSEC library for aurdino and different architecture.Now I want to cross compile the libraries to my environment and generate the libraries.I am running my board using imx digi yocto and I am using the toolchain as below:
export ARCH=arm
export CROSS_COMPILE=arm-dey-linux-gnueabi-
I downloaded the toolchain by following the link below:
https://www.digi.com/support/knowledge-base/cross-compiling-a-simple-c-program-in-digi-embedde
Can anyone help me to know how to compile the libraries to my environment and also how to integrate the source code in my user level application to communicate with the sensor.
Regards
Raguram.
04-24-2020 09:47 AM
