02-16-2022 10:59 AM
I am using BMA490L which having configuration file size of 1.3KB, But if I want to use BMA456 which having cofiguration file size of 6.1 KB approximate which is more compare to BMA490L.
Is there any other file having reduced size for BMA456 ?
OR
How can we reduce size of Confiuration file?
Please guide.
Best Regards
Yashvant
02-16-2022 04:15 PM
Hello ychavhan,
BMA490L had little feature than BMA456 feature which was implemented by configuration file, so the configuration file size was smaller than BMA456 configuration file size.
BMA490L feature:
BMA456 feature:
02-17-2022 12:33 PM
Thanks for your reply,
I have gone through datasheets of both BMA Chips. My doubt is that, conguration file of BMA456 having Size greater than configuration file of BMA490L. Can I modify conguration file of BMA456? if Yes then How? let me know proceess/steps for same. Also how Configuration file is generated?
Thanks Regards
Yashvant Chavhan
02-18-2022 10:30 AM
Hello ychavhan,
The firmware haven't supported to be modified by yourself.
