Hello!
Based on my findings in this forum. If I want to calibrate the BHI260AP sensors, I need to do that with the Development Desktop 2.0 tool. Following this tutorial: https://www.youtube.com/watch?v=Bw0WuAyGsnY
When opening the Development Desktop 2.0 application, it requests a connection board. I expected that I can use the Nicla as connection board, but it seems not to work since I can not connect it "No response from the board. Please select correct port".
Am I wrong with this, or is there a way to create a calibration routine and use the BHY2 library to update the calibration?
Since I most likely need to have the board in an environment where I can not just flash the sensor, I would like to calibrate it based on the surroundings. I saw the "bhy2_set_calibration_profile" method in the BHY2-Sensor-API/bhy2.c file, but could not see it referenced somewhere else then here BHI260AB-calibration.
Thank You
Hi nerubjen,
Firstly, we would like to know is BHI260AP located on your own hardware board or Nicla Sense ME board when you would like to calibrate BHI260AP?
Hey! Thank you for coming back at me.
It's mounted on the Nicla Sense ME
Best
any infos about that? Or is a calibration not needed since its self-calibrating?
