    Consecutive BMI160 self-tests fail without delay
    Highlighted
    I am using BMI160_driver v3.7.7 to perform a self-test of the BMI160 gyroscope and accelerometer.  The following code makes two consecutive calls of bmi160_perform_self_test, the first is for the gyroscope, and the second is for the accelerometer.  This code is called repeatedly in a loop to log performance.  The result is that the self-tests will fail for 992 of 1000 iterations.
    // Perform gyroscope self-test
    if (bmi160_perform_self_test(BMI160_GYRO_ONLY, &bmi160) != BMI160_OK) {
        return false;
    // TODO: Delay here
    // Perform accelerometer self-test uint8_t data[] = {0x2C}; bmi160_set_regs(0x40, data, sizeof (data), &bmi160); // configure for self-test as per page 43 of datasheet if (bmi160_perform_self_test(BMI160_ACCEL_ONLY, &bmi160) != BMI160_OK) { return false; }
    I have found it is necessary to insert a delay between the two function calls.  This results in both self-tests passing 1000 of 1000 iterations.  I have found this to be the case for delays as short as 300 us.
    I have not been able to find any documentation for the requirement of this delay.  My test system uses an 10 MHz SPI+DMA interface with a host MCU running at 200 MHz; perhaps the delay is only necessary for faster systems.  I suggest that the API or documentation is updated.
    Tags (1)
    2 REPLIES 2
    Highlighted
    Re: Consecutive BMI160 self-tests fail without delay
    Update - Tests of >8000 iterations reveal that the above delay alone is not sufficient.
    The following code achieves successful self-tests for 100,000 iterations. It includes three delays: A, B, and C. All three delays are necessary. I have not determined if 10 ms is the minimum required delay.
    I am sharing this code so that others can replicated the issue. The code should be called in a loop. Removing the delays will demonstrate the fault. Tests were conducted using BMI160_driver v3.7.7 and a 10 MHz SPI interface.
    bool SelfTest() {
        // Initialise device
        bmi160_init(&bmi160);
        // Perform soft reset
        bmi160_soft_reset(&bmi160);
        // Configure device
        bmi160.accel_cfg.odr = BMI160_ACCEL_ODR_400HZ;
        bmi160.accel_cfg.range = BMI160_ACCEL_RANGE_16G;
        bmi160.accel_cfg.bw = BMI160_ACCEL_BW_NORMAL_AVG4;
        bmi160.accel_cfg.power = BMI160_ACCEL_NORMAL_MODE;
        bmi160.gyro_cfg.odr = BMI160_ACCEL_ODR_400HZ;
        bmi160.gyro_cfg.range = BMI160_GYRO_RANGE_2000_DPS;
        bmi160.gyro_cfg.bw = BMI160_GYRO_BW_NORMAL_MODE;
        bmi160.gyro_cfg.power = BMI160_GYRO_NORMAL_MODE;
        bmi160_set_sens_conf(&bmi160);
        // Delay A
        TimerDelay(10);
            return false;
        // Delay B
        TimerDelay(10);
            return false;
        // Delay C
        TimerDelay(10);
        // Self-test successful
        return true;
    Highlighted
    Hi sebmadgwick,
    Thanks for the hint. We will look into it and get back to you when we have an update.
    Regards,
    kgoveas
