I have connected the Application board 3.0 with my PC. The connection seems to be fine. But I can not receive any information from the Development Desktop 2.0 even I move the sensor around. It is always 0. What could be the reason?
After you install DD2.0 GUI SW on your PC, you can find BMI090L user manual at C:\Program Files\Bosch Sensortec\Development Desktop 2.0\DD2.0_BMI090L.pdf. I attach it here for your convenience. You need to enable the accelerometer and then click "STart Stream" button to see the data plotting in real time.
Please note that BMI090L has been discontinued. You should switch to BMI088 which is pin-to-pin compatible with BMI090L.
