    Does Bosch hava a cyroscope chip with low power mode?
    qinxg
    such as ICM-20602 which has a low-power mode syroscope. thanks
    Hello qinxg,
    Yes, many bosch sensors had gyroscope with low power mode, like BMI270. You could see different power mode like this:
    Could we know what your end applicaiton?
    I use it on my smart door-lock PCB to detect the angle of door open/close. I tested BMI160 first and found the cyroscope can detect the accurate angle of door  panel only by x-axial( y & z are useless).  Then I put cyro to suspend power mode and use  any-motion interurpt to wakeup the cyro, but it's hard to find a fit value to the int_anym_th in register INT_MOTION because the door can move  very smoothly.
    So I need a cyroscope with low-power mode and the xyz axials can be enable/disable respectively.
    Hello qinxg,
    If your application could accept gyroscope power consumption under low power mode, you could use BMI270.
    Bosch had smart lock application with BHI160B integrated algorithm, user didn't need develop algorithm, and directly get door status. If you are interested, you can contact the local distributor first, and request BHI160B smart lock solution in your project.
