    Error compiling BSEC on ESP8266 with Arduino IDE
    handytech
    Re: Error compiling BSEC on ESP8266 with Arduino IDE
    I was running Arduino IDE 1.8.10 and ESP8266 core 2.6.3, but even after updating my setup to 1.8.11 and 2.7.1 respectively, I cannot reproduce your error yet.
    From your console log I can comment that:
    • "-lalgobsec" appears twice in the linker command, this is weird,
    • in the same command, the linker is not including "bsec.cpp.o" nor "bme680.c.o" which I believe is causing the "undefined reference" error.
    For example I would expect something more like this (changes in red) :
    "C:\\Users\\david\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-4-b40a506/bin/xtensa-lx106-elf-gcc" -fno-exceptions -Wl,-Map "-Wl,C:\\Users\\david\\AppData\\Local\\Temp\\arduino_build_524158/basic.ino.map" -g -w -Os -nostdlib -Wl,--no-check-sections -u app_entry -u _printf_float -u _scanf_float -Wl,-static "-LC:\\Users\\david\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.1/tools/sdk/lib" "-LC:\\Users\\david\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.1/tools/sdk/lib/NONOSDK22x_190703" "-LC:\\Users\\david\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.1/tools/sdk/ld" "-LC:\\Users\\david\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.1/tools/sdk/libc/xtensa-lx106-elf/lib" -Teagle.flash.4m2m.ld -Wl,--gc-sections -Wl,-wrap,system_restart_local -Wl,-wrap,spi_flash_read -o "C:\\Users\\david\\AppData\\Local\\Temp\\arduino_build_524158/basic.ino.elf" -Wl,--start-group "C:\\Users\\david\\AppData\\Local\\Temp\\arduino_build_524158\\sketch\\basic.ino.cpp.o" "C:\\Users\\david\\AppData\\Local\\Temp\\arduino_build_524158\\libraries\\BSEC_Software_Library\\bsec.cpp.o" "C:\\Users\\david\\AppData\\Local\\Temp\\arduino_build_524158\\libraries\\BSEC_Software_Library\\bme680\\bme680.c.o" "C:\\Users\\david\\AppData\\Local\\Temp\\arduino_build_524158\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\david\\AppData\\Local\\Temp\\arduino_build_524158\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\david\\AppData\\Local\\Temp\\arduino_build_524158\\core\\core.a" -lhal -lphy -lpp -lnet80211 -llwip2-536-feat -lwpa -lcrypto -lmain -lwps -lbearssl -laxtls -lespnow -lsmartconfig -lairkiss -lwpa2 -lstdc++ -lm -lc -lgcc "-LC:\\Users\\david\\Documents\\Arduino\\libraries\\BSEC-Arduino-library-1.5.1474\\src\\esp8266" -lalgobsec -lalgobsec -Wl,--end-group "-LC:\\Users\\david\\AppData\\Local\\Temp\\arduino_build_524158"
    Davide
    Please, could you share your platform.txt and eagle...etc... files?
    Maybe replacing them I got it working... at least as regards the libalgobsec library.
    About linker that not include "bsec.cpp.o" and "bme680.c.o" what can I do?
    handytech
    Please find attached the files used in my setup, respectively found under "C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\platform.txt" and "C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\tools\sdk\ld\eagle.app.v6.common.ld.h" by default.
    Davide
    Thank you handytech.
    But I can't find the files... it's my problem or on the forum the files attached to the messages do not appear?
    Even the logs that I tried to attach in the previous message are not in the discussion...
    handytech
    I just realized my attachment went missing too, I started investigating.
