    Error compiling BSEC on ESP8266 with Arduino IDE
    handytech
    Re: Error compiling BSEC on ESP8266 with Arduino IDE
    In the meantime, I have edited my previous post with hyperlinks to temporarily hosted files, I will attach them again here in the Community as soon as things have been figured out.
    Davide
    Thank you Handytech for your support.
    I have tried replacing the 2 files but unfortunately the error is still presents (exact the same).
    Can't understand which could be the problem...
    I also tried default Arduino-builder but same error...
    Maybe you use different libalgobsec library?
    I have also another doubt... why there are "bsec_datatypes.h" and "bsec_interface.h" files together with "libalgobsec.a" in generic release package?
    Should I replace them somewhere?
    handytech
    Since I did a fresh install of both the IDE and the the board support I am also running short on further ideas 😞 I also selected the "NodeMCU 1.0 (ESP-12E Module)" which compiles successfully (but I only have the Adafruit Feather HUZZAH to confirm that it actually runs as expected).
    The generic release package on our website is the official package for BSEC. The BSEC Arduino Library is a wrapper (intended) to ease the use/integration of the BSEC library in the Arduino environment. The current version of the BSEC Arduino Library is up-to-date to run/support the current latest official BSEC release package (v1.4.7.4), thefore these files should be identical with no need to manually replace anything manually.
    Davide
    Handytech, you did a fresh installation deleting before AppData\...\Arduino and Programs\...\Arduino folders?
    Could you try another PC with clean Windows installation?
    Because I did it on my PC last week (same for IDE) ... and retried today but same error again.
    How do you install the board? Manual o automated?
    Thank you again.
    Davide
    UPDATE: got it works! 😁
    I did fresh installation of IDE 1.8.11 and everythings works fine...
