    Error compiling BSEC on ESP8266 with Arduino IDE
    Davide
    Hi everyone,
    I would kindly need support for compiling a script for the ESP8266 controller with Arduino IDE.
    I have a BME680 sensor connected to a NodeMCU 8266 controller and some time ago I already created a working script to read the air quality index (Arduino IDE 1.8.11 and I don't remember which version of BSEC).
    Today I tried to load the same script again with Arduino IDE 1.8.12 and BSEC 1.4.7.4, but there is no way to compile it, I always find the same error. Also trying with basic example provided with BSEC library.
    I read on the internet that there are problems with the IDE 1.8.12, so I tried to remove it completely (even doing folder cleaning) and to install version 1.8.9, but unfortunately without success.
    I state that I have applied exactly the indications for Arduino contained in the pdf present in the BSEC package.
    I replaced the arduino-builder-219.exe file, modified the platform.txt and eagle.app.v6.common.ld files as indicated and placed the libalgobsec.a files in the BSEC library folder (trying both the normal and light version).
    Despite this, I find the following error:
    Arduino:1.8.9 (Windows 10), Scheda:"NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
    c:/users/david/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\bsec\bsec.cpp.o: in function `Bsec::i2cRead(unsigned char, unsigned char, unsigned char*, unsigned short)':
    C:\Users\david\Documents\Arduino\libraries\bsec\src/bsec.cpp:442: undefined reference to `bsec_init'
    c:/users/david/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\david\Documents\Arduino\libraries\bsec\src/bsec.cpp:442: undefined reference to `bsec_get_version'
    c:/users/david/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\bsec\bsec.cpp.o: in function `Bsec::beginCommon()':
    C:\Users\david\Documents\Arduino\libraries\bsec\src/bsec.cpp:448: undefined reference to `bsec_init'
    c:/users/david/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\david\Documents\Arduino\libraries\bsec\src/bsec.cpp:133: undefined reference to `bsec_get_version'
    c:/users/david/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\bsec\bsec.cpp.o: in function `Bsec::begin(unsigned char, TwoWire&)':
    C:\Users\david\Documents\Arduino\libraries\bsec\src/bsec.cpp:104: undefined reference to `bsec_update_subscription'
    c:/users/david/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\bsec\bsec.cpp.o: in function `Bsec::updateSubscription(bsec_virtual_sensor_t*, unsigned char, float)':
    C:\Users\david\Documents\Arduino\libraries\bsec\src/bsec.cpp:155: undefined reference to `bsec_update_subscription'
    c:/users/david/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\bsec\bsec.cpp.o: in function `Bsec::Bsec()':
    C:\Users\david\Documents\Arduino\libraries\bsec\src/bsec.cpp:70: undefined reference to `bsec_do_steps'
    c:/users/david/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\bsec\bsec.cpp.o: in function `Bsec::readProcessData(long long, bsec_bme_settings_t)':
    C:\Users\david\Documents\Arduino\libraries\bsec\src/bsec.cpp:288: undefined reference to `bsec_do_steps'
    c:/users/david/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\bsec\bsec.cpp.o:(.text._ZN4Bsec3runEv+0x4): undefined reference to `bsec_sensor_control'
    c:/users/david/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\bsec\bsec.cpp.o: in function `Bsec::run()':
    C:\Users\david\Documents\Arduino\libraries\bsec\src/bsec.cpp:166: undefined reference to `bsec_sensor_control'
    exit status 1
    Could anyone kindly help me?
    Yours sincerely
    David
    16 REPLIES 16
    handytech
    I was running Arduino IDE 1.8.10 and ESP8266 core 2.6.3, but even after updating my setup to 1.8.11 and 2.7.1 respectively, I cannot reproduce your error yet.
    From your console log I can comment that:
    • "-lalgobsec" appears twice in the linker command, this is weird,
    • in the same command, the linker is not including "bsec.cpp.o" nor "bme680.c.o" which I believe is causing the "undefined reference" error.
    For example I would expect something more like this (changes in red) :
    "C:\\Users\\david\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-4-b40a506/bin/xtensa-lx106-elf-gcc" -fno-exceptions -Wl,-Map "-Wl,C:\\Users\\david\\AppData\\Local\\Temp\\arduino_build_524158/basic.ino.map" -g -w -Os -nostdlib -Wl,--no-check-sections -u app_entry -u _printf_float -u _scanf_float -Wl,-static "-LC:\\Users\\david\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.1/tools/sdk/lib" "-LC:\\Users\\david\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.1/tools/sdk/lib/NONOSDK22x_190703" "-LC:\\Users\\david\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.1/tools/sdk/ld" "-LC:\\Users\\david\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.1/tools/sdk/libc/xtensa-lx106-elf/lib" -Teagle.flash.4m2m.ld -Wl,--gc-sections -Wl,-wrap,system_restart_local -Wl,-wrap,spi_flash_read -o "C:\\Users\\david\\AppData\\Local\\Temp\\arduino_build_524158/basic.ino.elf" -Wl,--start-group "C:\\Users\\david\\AppData\\Local\\Temp\\arduino_build_524158\\sketch\\basic.ino.cpp.o" "C:\\Users\\david\\AppData\\Local\\Temp\\arduino_build_524158\\libraries\\BSEC_Software_Library\\bsec.cpp.o" "C:\\Users\\david\\AppData\\Local\\Temp\\arduino_build_524158\\libraries\\BSEC_Software_Library\\bme680\\bme680.c.o" "C:\\Users\\david\\AppData\\Local\\Temp\\arduino_build_524158\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\david\\AppData\\Local\\Temp\\arduino_build_524158\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\david\\AppData\\Local\\Temp\\arduino_build_524158\\core\\core.a" -lhal -lphy -lpp -lnet80211 -llwip2-536-feat -lwpa -lcrypto -lmain -lwps -lbearssl -laxtls -lespnow -lsmartconfig -lairkiss -lwpa2 -lstdc++ -lm -lc -lgcc "-LC:\\Users\\david\\Documents\\Arduino\\libraries\\BSEC-Arduino-library-1.5.1474\\src\\esp8266" -lalgobsec -lalgobsec -Wl,--end-group "-LC:\\Users\\david\\AppData\\Local\\Temp\\arduino_build_524158"
    Please, could you share your platform.txt and eagle...etc... files?
    Maybe replacing them I got it working... at least as regards the libalgobsec library.
    About linker that not include "bsec.cpp.o" and "bme680.c.o" what can I do?
    handytech
    Please find attached the files used in my setup, respectively found under "C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\platform.txt" and "C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\tools\sdk\ld\eagle.app.v6.common.ld.h" by default.
    Thank you handytech.
    But I can't find the files... it's my problem or on the forum the files attached to the messages do not appear?
    Even the logs that I tried to attach in the previous message are not in the discussion...
    handytech
    I just realized my attachment went missing too, I started investigating.
