    Error reading BME680 with a NORDIC DK
    arnaud
    Hello everyone, I have an error when I read BME680 the values never change and humidity is at 100 % but the read fonction return a zero which means everything ok. I don't know why it's not working I guess it's in my read and write functions but I don't find my mistake.
    Here is my code : thank you for your time and have a good day.
    NB : NRF_LOG is used for display like Serial.print in arduino.
    err = nrf_drv_twi_rx(&m_twi, dev_id, tampon, len); : this function is like the Wire.request(tampon, len ) on arduino.
    nrf_drv_twi_tx(&m_twi, dev_id, reg, len+1, false); : this function is like the Wire.begintransmission(dev_id) then wire.write(reg);
     * Copyright (c) 2016 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
     * Redistribution and use in source and binary forms, with or without modification,
     * are permitted provided that the following conditions are met:
     * 1. Redistributions of source code must retain the above copyright notice, this
     *    list of conditions and the following disclaimer.
     * 2. Redistributions in binary form, except as embedded into a Nordic
     *    Semiconductor ASA integrated circuit in a product or a software update for
     *    such product, must reproduce the above copyright notice, this list of
     *    conditions and the following disclaimer in the documentation and/or other
     *    materials provided with the distribution.
     * 3. Neither the name of Nordic Semiconductor ASA nor the names of its
     *    contributors may be used to endorse or promote products derived from this
     *    software without specific prior written permission.
     * 4. This software, with or without modification, must only be used with a
     *    Nordic Semiconductor ASA integrated circuit.
     * 5. Any software provided in binary form under this license must not be reverse
     *    engineered, decompiled, modified and/or disassembled.
     * THIS SOFTWARE IS PROVIDED BY NORDIC SEMICONDUCTOR ASA "AS IS" AND ANY EXPRESS
     * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
     * OF MERCHANTABILITY, NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE ARE
     * DISCLAIMED. IN NO EVENT SHALL NORDIC SEMICONDUCTOR ASA OR CONTRIBUTORS BE
     * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
     * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
     * GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
     * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
     * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
     * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    /** @file
     * @defgroup tw_scanner main.c
     * @ingroup nrf_twi_example
     * @brief TWI Sensor Example main file.
     * This file contains the source code for a sample application using TWI.
    #include <stdio.h>
    #include "boards.h"
    #include "app_util_platform.h"
    #include "app_error.h"
    #include "nrf_drv_twi.h"
    #include "nrf_delay.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_log_default_backends.h"
    #include "bme680.h"
    struct bme680_dev gas_sensor;
    int8_t rslt = BME680_OK;
    /* TWI instance ID. */
    #if TWI0_ENABLED
    #define TWI_INSTANCE_ID     0
    #elif TWI1_ENABLED
    #define TWI_INSTANCE_ID     1
    #endif
    int compteur = 0;
    /* TWI instance. */
    static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
    int8_t user_i2c_read (uint8_t dev_id, uint8_t reg_addr, uint8_t *data, uint16_t len)
      ret_code_t err;
      uint8_t tampon[30]={0};
      NRF_LOG_INFO("read");
      NRF_LOG_FLUSH();
      int size=0, result = 0, j=0;
      uint8_t reg[1]={reg_addr};
      nrf_drv_twi_tx(&m_twi, dev_id, reg, 1,false);
      NRF_LOG_INFO("read : len %d :",len);
      NRF_LOG_FLUSH();
      if(err==0)
       {size=1;
     for(int i = 0 ;i<30;i++)
        if(tampon[i]!=0) size=i+1;
    //    NRF_LOG_INFO("tampon : %d",tampon[i]);
    //      NRF_LOG_FLUSH();
       else
       size=0;
    //       NRF_LOG_INFO("len %d",len);
    //    NRF_LOG_FLUSH();
    //    NRF_LOG_INFO("size %d",size);
    //    NRF_LOG_FLUSH();
    if(size >14  ) size=len;
    NRF_LOG_INFO("read : wire.available %d :",size);
      NRF_LOG_FLUSH();
      if(len<=size)
        { for (int i=0;i<len;i++)
          data[i]=tampon[i];
          NRF_LOG_INFO("%d",data[i]);
          NRF_LOG_FLUSH();
       else
       {result=5;}
    return result;
     * Write the content into the register targeted register for a specified device
     * Parameter :
     *    dev_id : the I2C adress of the device
     *    reg_addr : the adresse of the targeted register
     *    *data : pointer to the data to write
     *    len : number in byte of the data
     * Return:  Error code
    int8_t user_i2c_write (uint8_t dev_id, uint8_t reg_addr, uint8_t *data, uint16_t len)
    NRF_LOG_INFO("write");
      NRF_LOG_FLUSH();
        int result=0;
      uint8_t reg[]={reg_addr,*data};
      return result;
     * function to wait the time
     * Parameter :
     *    period : time that will be waited in millisecond
    void user_delay_ms (uint32_t period)
      nrf_delay_ms(period);
     * @brief TWI initialization.
    void twi_init (void)
        ret_code_t err_code;
        const nrf_drv_twi_config_t twi_config = {
           .scl                = ARDUINO_13_PIN ,
           .sda                = ARDUINO_12_PIN ,
           .frequency          = NRF_DRV_TWI_FREQ_100K,
           .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
           .clear_bus_init     = false
        err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
        APP_ERROR_CHECK(err_code);
        nrf_drv_twi_enable(&m_twi);
     * @brief Function for initialising bme 680 in forced mode.
    void init_bme (void)
        gas_sensor.gas_sett.heatr_temp = 320; /* degree Celsius */
        gas_sensor.gas_sett.heatr_dur = 150; /* milliseconds */
        /* Select the power mode */
        set_required_settings = BME680_OST_SEL | BME680_OSP_SEL | BME680_OSH_SEL | BME680_FILTER_SEL
            | BME680_GAS_SENSOR_SEL;
        rslt = bme680_set_sensor_settings(set_required_settings,&gas_sensor);
        /* Set the power mode */
     * @brief Function for main application entry.
    int main(void)
        APP_ERROR_CHECK(NRF_LOG_INIT(NULL));
        NRF_LOG_DEFAULT_BACKENDS_INIT();
        NRF_LOG_INFO("TWI scanner started.");
        NRF_LOG_FLUSH();
        twi_init();
        gas_sensor.dev_id = BME680_I2C_ADDR_SECONDARY;
        gas_sensor.read = user_i2c_read;
        gas_sensor.write = user_i2c_write;
        gas_sensor.delay_ms = user_delay_ms;
        gas_sensor.amb_temp = 25;
        init_bme();
        NRF_LOG_INFO("Rslt : %d",rslt);
        NRF_LOG_FLUSH();
        if(rslt!=0)
        NRF_LOG_INFO("no BME680 detected");
        NRF_LOG_FLUSH();
        while(1);
        while (true)
            // put your main code here, to run repeatedly:
      uint16_t meas_period;
      struct bme680_field_data data;
        while(1){
      nrf_delay_ms(meas_period);
      NRF_LOG_INFO("RSLT READ %d",rslt);
     NRF_LOG_FLUSH();
       NRF_LOG_INFO("%d",data.temperature);
     NRF_LOG_FLUSH();
     NRF_LOG_ERROR( "Température :  " NRF_LOG_FLOAT_MARKER "\r\n", NRF_LOG_FLOAT(data.temperature /100.0));
     NRF_LOG_FLUSH();
     NRF_LOG_ERROR( "Pression :  " NRF_LOG_FLOAT_MARKER "\r\n", NRF_LOG_FLOAT(data.pressure /100.0));
     NRF_LOG_FLUSH();
     NRF_LOG_ERROR( "Humidity :  " NRF_LOG_FLOAT_MARKER "\r\n", NRF_LOG_FLOAT(data.humidity /1000.0));
     NRF_LOG_FLUSH();
      /* Avoid using measurements from an unstable heating setup */
      if (data.status & BME680_GASM_VALID_MSK)
        NRF_LOG_INFO("G: ");
        NRF_LOG_INFO("%d",data.gas_resistance);
        NRF_LOG_INFO("Kohms");
        NRF_LOG_FLUSH();
      /* Trigger the next measurement if you would like to read data out continuously */
      if (gas_sensor.power_mode == BME680_FORCED_MODE) {
     while(1);
    9 REPLIES 9
    Vincent
    what is the chip_id read back from BME680 in the function BME680_init?
    Maybe you can also post a logic anayzer pattern for better understanding.
    hello thank you for your answer the chip select is 97 :
    below this is the information that I read on the serial for debugging. For this one I put a while(1) just after the init so I am not performing the read_data.
    <info> app: TWI scanner started.
    <info> app: write
    <info> app: read
    <info> app: read : len 1 :
    <info> app: read : wire.available 1 :
    <info> app: 97
    <info> app: read
    <info> app: read : len 25 :
    <info> app: read : wire.available 25 :
    <info> app: 0
    <info> app: 129
    <info> app: 103
    <info> app: 3
    <info> app: 0
    <info> app: 55
    <info> app: 141
    <info> app: 42
    <info> app: 215
    <info> app: 88
    <info> app: 0
    <info> app: 92
    <info> app: 13
    <info> app: 228
    <info> app: 255
    <info> app: 23
    <info> app: 30
    <info> app: 0
    <info> app: 0
    <info> app: 214
    <info> app: 254
    <info> app: 25
    <info> app: 242
    <info> app: 30
    <info> app: 162
    <info> app: read
    <info> app: read : len 16 :
    <info> app: read : wire.available 16 :
    <info> app: 62
    <info> app: 202
    <info> app: 50
    <info> app: 0
    <info> app: 45
    <info> app: 20
    <info> app: 120
    <info> app: 156
    <info> app: 65
    <info> app: 103
    <info> app: 223
    <info> app: 249
    <info> app: 196
    <info> app: 18
    <info> app: 127
    <info> app: 0
    <info> app: read
    <info> app: 22
    <info> app: read
    <info> app: 51
    <info> app: read
    <info> app: 227
    <info> app: chip_id : 97 :
    <info> app: write
    <info> app: read
    <info> app: 0
    <info> app: read
    <info> app: 0
    <info> app: read
    <info> app: 0
    <info> app: read
    <info> app: 0
    <info> app: read
    <info> app: 0
    <info> app: write
    <info> app: read
    <info> app: 0
    <info> app: write
    <info> app: Rslt : 0
    When I read the data.status after a read it displays data.status = 128, But I have a code working with arduino which should be exactly the same display a data.status : 160.
    thank you
    Vincent
    In the log,  i can find following information:
    1.  bme680_init execute:
                    a. read chip_id register successfully as 0x61 (97)
                    b. read calibration parameter page 1 successfully (25 bytes)
                    c.  read calibration parameter page 2 successfully (16 bytes)
                    d.  print out the chip id in your code
    2.  a while (1) is put just after this funciton and you keep read back as 0.  which register you are reading here?
    3.  in our code,  data->status = buff[0] & BME680_NEW_DATA_MSK;  here BME680_NEW_DATA_MSK = 0x80.  this is new data indicate.  if status = 128, means there is new data available.   it is read from register 0x1d.  the value in 0x1d = 0xa0 (160) means new data available and measing is still going on.  So actually 128 from data->status is expected value.  And you should have value in corresponding data register.
    Here is all the serial screen when I perform init and one reading  :
    <info> app: write : register 224
    <info> app: read : reg addr : 208
    <info> app: 97
    <info> app: read : reg addr : 137
    <info> app: 0
    <info> app: 129
    <info> app: 103
    <info> app: 3
    <info> app: 0
    <info> app: 55
    <info> app: 141
    <info> app: 42
    <info> app: 215
    <info> app: 88
    <info> app: 0
    <info> app: 92
    <info> app: 13
    <info> app: 228
    <info> app: 255
    <info> app: 23
    <info> app: 30
    <info> app: 0
    <info> app: 0
    <info> app: 214
    <info> app: 254
    <info> app: 25
    <info> app: 242
    <info> app: 30
    <info> app: 162
    <info> app: read : reg addr : 225
    <info> app: 62
    <info> app: 202
    <info> app: 50
    <info> app: 0
    <info> app: 45
    <info> app: 20
    <info> app: 120
    <info> app: 156
    <info> app: 65
    <info> app: 103
    <info> app: 223
    <info> app: 249
    <info> app: 196
    <info> app: 18
    <info> app: 127
    <info> app: 0
    <info> app: 22
    <info> app: read : reg addr : 0
    <info> app: 51
    <info> app: read : reg addr : 4
    <info> app: 227
    <info> app: write : register 90
    <info> app: read : reg addr : 116
    <info> app: 0
    <info> app: read : reg addr : 117
    <info> app: 0
    <info> app: 0
    <info> app: read : reg addr : 114
    <info> app: 0
    <info> app: read : reg addr : 113
    <info> app: 0
    <info> app: write : register 117
    <info> app: 0
    <info> app: write : register 116
    <info> app: profil duration 183
    <info> app: read : reg addr : 29
    <info> app: read : len 15 :
    <info> app: read : wire.available 15 :
    <info> app: 128
    <info> app: 255
    <info> app: 128
    <info> app: 0
    <info> app: 0
    <info> app: 128
    <info> app: 0
    <info> app: 0
    <info> app: 128
    <info> app: 0
    <info> app: 128
    <info> app: 0
    <info> app: 0
    <info> app: 0
    <info> app: 4
    <info> app: RSLT READ 0
    <info> app: STATUS
    <info> app: 3202
    <error> app: Température :  32.02
    <error> app: Pression :  81990.00
    <error> app: Humidity :  100.00
    <info> app: 0
