    Esp32 and BMX160, change I2c Pins
    The_new_doctor
    Hi everyone,
    it's my first time with an Arduino-like device and I'm currently trying to connect an Imu BMX160 to the board in two different by from the default one, but i'm having a problem: I know that the Esp32 is able to use almost any pin for I2C as they show in this site in which they use an Adafruit sensor https://www.electrorules.com/esp32-i2c-communication-set-pinsmultiple-bus-interfaces-and-peripherals...
     But I don't know why it doesnt work with the one that I have. The code that I am using is the example, so I've tried to modify that like this
    #include <DFRobot_BMX160.h>
    #include <Wire.h>
    #define I2C_SDA 25
    #define I2C_SCL 26
    TwoWire I2C = TwoWire(0);
    DFRobot_BMX160 bmx160;
    void setup(){
      I2C.begin(I2C_SDA, I2C_SCL);
      bmx160.begin(&TwoWire);
      Serial.begin(115200);
      delay(100);
      //init the hardware bmx160
      if (bmx160.begin(&TwoWire) != true){
        Serial.println("not found");
        while(1);
    But obviously it doesn't work because the function .begin in the library doesn't ask for a variable  that define the position and instead it's in the constructor
    class DFRobot_BMX160{
      public:
        DFRobot_BMX160(TwoWire *pWire=&Wire);
         * @fn begin
         * @brief set the i2c addr and init the i2c.
         * @return returns the initialization status
         * @retval true Initialization succeeded
         * @retval false Initialization  failed
        bool begin();
    So my question is, how can I manage to change that?
    Thanks in advance
    Re: Esp32 and BMX160, change I2c Pins
    Hi The_new_doctor,
    We know little about Arduino code on ESP32. Suggest you refer more information on Arduino forum how to use I2C on ESP32.
