    Explanation for sequence of numbers in BSXLite initialisation
    janakiram
    Hello, I see a sequence of bytes used for initialisation of BSX Lite....For example, i see
    BSX_U8 str_magsensorspec[]= {39,0,2,1,20,5,20,5,196,9,6,9,112,23,0,0,128,61,205,204,76,63,0,0,224,64,1,1,1,1,1,1,1,1,1,1,1,134,84};
    What do these numbers mean?   Is there a documentation that I can refer to?
    Tags (1)
    elrhoul
    Community Manager
    Re: Explanation for sequence of numbers in BSXLite initialisation
    As mentionned in the BSX library integration guide document (which is part of the BSX lite SW package available for download from our website: https://www.bosch-sensortec.com/bst/products/all_products/bsxlite). The sequences is a configuration string that contain sensors (e.g accelerometer, Magmetometer, gyroscope, ....) settings for the library.
    Regards
    janakiram
    Hello,  Thanks.   I have gone through the BSXLite material mentioned.     But, I am unable to find what each byte in the initialisation sequence mean?    Found only the part in the document mentioned which doesn't give much detail.   I understand that there is a specific sequence for each of the sensor.    Is it allowed to change the initialisation sequence?
    Or point me to document where this sequence is explained.
    janakiram
    Could you please help with this question.    Thanks.
