Hello Sudeep,
Currently, I'm checking with HQ whether we can read and write i2c data in case i2c communication length is less than BME68x requires.
I will let you know, but possibly you can't use it.
Hello Minhwan,
Thanks for your valuable assistance. Once you check with HQ let me know. Your feedback is important to me.
Hi Sudeep1310,
I would recommend migrating to the newer version of the sensor API that supports both the BME680 and BME688. Given that your platform only supports 16 byte reads, you have to achieve longer reads by modifying your I2C read to perform consecutive reads to acheive longer transactions. It would look something like below
int8_t i2c_read(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
uint16_t max_len = 16; /* BlueNRG RX FIFO depth */
uint16_t bytes_left = len;
uint16_t len_to_read = 0;
uint16_t i = 0;
for(i = 0; (i < len) && (rslt == 0);)
bytes_left = len - i;
len_to_read = (bytes_left < max_len) ? bytes_left : max_len;
rslt = SdkEvalI2CRead(®_data[i], dev_id, reg_addr + i, len_to_read);
i += len_to_read;
return rslt;
Hello Kgoveas,
Thank you very much for your guidance. I will modify my I2C read function as per your suggestion and will give you feedback soon.
BR
Sudeep
Hello Kgoveas,
Thanks once again for your great suggestons. Your trick is working with my code. I getting forced example output as below,
1, 1000, 28.75, 94488.88, 35.88, 5825.59, 0xa0
2, 1000, 28.98, 94491.52, 35.91, 1831.92, 0xb0
3, 1000, 29.48, 94483.83, 35.98, 1680.24, 0xb0
4, 1000, 29.97, 94487.53, 36.05, 1686.79, 0xb0
5, 1000, 30.32, 94488.09, 36.12, 1692.28, 0xb0
6, 1000, 30.56, 94490.24, 36.14, 1724.87, 0xb0
7, 1000, 30.76, 94494.60, 36.15, 1746.91, 0xb0
8, 1000, 30.94, 94484.99, 36.14, 1765.91, 0xb0
9, 1000, 31.09, 94492.68, 36.11, 1779.22, 0xb0
10, 1000, 31.22, 94493.74, 36.07, 1806.44, 0xb0
As compared to my previous output of my register based code Temperature, Pressure, Humidity output looks same.
Look here,
Temperature: 27.299999
Humidity: 36.500977
Pressure: 947.539978 (in KPa)
Altitude: 561.994995
Gas: 0.000000
I have tested sensor intefaced with Arduino board and Gas resistance output is between 1800-2000 always whenever I was testing with Arduino board. Means Now after implemeted your trick the output of gas resistance I am getting is nearly about same. So I conclude that it is working.
I have one doubt, As I seen in output there is taken 10 samples and each time temperature is incremented by 1. So I am worried about this temperature value. Because I have refered with standard temperature monitor device and temperature here in testing room is 27.30 degree celcius. Please Guide on it. And tell me about Status value getting in Output (0xa0 and 0xb0)
BR
Sudeep
