01-24-2022 01:26 PM
I am trying to get compile bme680_init() function only and it interfaced with the BlueNRG-2 (BLE+MCU)module. I am using Keil compiller. Please look below for reference
struct bme680_dev gas_sensor;
/* You may assign a chip select identifier to be handled later */
gas_sensor.dev_id = BME680_I2C_ADDR_PRIMARY;
gas_sensor.read = i2c_read;
gas_sensor.write = i2c_write;
gas_sensor.delay_ms = delay_ms;
/* amb_temp can be set to 25 prior to configuring the gas sensor
* or by performing a few temperature readings without operating the gas sensor.
gas_sensor.amb_temp = 25;
int8_t rslt = BME680_OK;
printf("BME680 InIt Result: ");
if(rslt==0)
printf("Success");
else
printf("Error");
printf("\n");
But I am getting issue at rslt = bme680_get_regs(BME680_COEFF_ADDR1, coeff_array, BME680_COEFF_ADDR1_LEN, dev);
in get_calib_data () function. Here Program is stuck and getting error in I2C reading. But I am getting proper Chip ID 0x61 while reading chip ID . So I am assuming my I2C lines are working. Also tested with other sensor and confirm I2C line is working. I have also checked about BME680_COEFF_ADDR1 and that is 0x89 given in bme680_def.h file. But It is not mentioned anywhere in datasheet.
Can you please Guide me where I am doing wrong. Please Guide.
01-24-2022 06:52 PM
Hello Sudeep,
Could you share your whole application code related to BME680?
And, if you stuck that point, mean that no return value is availble right? If there is return value, what is it?
01-25-2022 05:37 AM
Here is my main code where I am just testing BME initialization function. Here I have got chip ID properly but gettng stuck in Calibration function. I want to just print success after bme680_init(&gas_sensor) function. My I2C function is working, I have tried BME280 also and it working properly but getting issue in BME680. As I have mentioned in last message I am stuck in calibration function where I am not getting any return value.
* File Name : I2C/Master_Polling/main.c
* Author : BCI Team
* Version : V1.0.0
* Date : Jan-2022
* Description : Code demostrating the I2C master functionality
/* Includes ------------------------------------------------------------------*/
#include "BlueNRG_x_device.h"
#include <stdio.h>
#include "BlueNRG1_conf.h"
#include "SDK_EVAL_Config.h"
#include "bme680.h"
#include "bme680_defs.h"
/** @addtogroup BlueNRG1_StdPeriph_Examples BlueNRG1 Standard Peripheral Examples
/** @addtogroup I2C_Examples I2C Examples
/** @addtogroup I2C_Master I2C Master
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
int status=0;
//uint16_t dev=0x52;
uint8_t id,id1;
uint8_t byteData[10], sensorState=0;
uint16_t wordData;
uint8_t ToFSensor = 1; // 0=Left, 1=Center(default), 2=Right
uint16_t Distance;
uint16_t SignalRate;
uint16_t AmbientRate;
uint16_t SpadNum;
uint8_t RangeStatus;
uint8_t dataReady;
volatile uint32_t lSystickCounter=0;
/* Private function prototypes -----------------------------------------------*/
void SdkDelayMs(volatile uint32_t lTimeMs);
void processCommand(void);
void processCommand1(void);
static int8_t i2c_write(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len);
static int8_t i2c_read(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len);
void delay_ms(uint32_t period);
//void helpMessage(void);
/* Private functions ---------------------------------------------------------*/
* @brief Main program code
* @param None
* @retval None
int main(void)
/* System initialization function */
SystemInit();
/* Identify BlueNRG1 platform */
SdkEvalIdentification();
/* UART initialization */
SdkEvalComUartInit(UART_BAUDRATE);
/* Enable the GPIO Clock */
SysCtrl_PeripheralClockCmd(CLOCK_PERIPH_GPIO, ENABLE);
GPIO_InitType GPIO_InitStructure;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
GPIO_InitStructure.GPIO_Mode = GPIO_Output;
GPIO_InitStructure.GPIO_Pull = DISABLE;
GPIO_InitStructure.GPIO_HighPwr = ENABLE;
GPIO_Init(&GPIO_InitStructure);
/* Put the LED off */
GPIO_WriteBit(GPIO_Pin_1,Bit_SET);
/* Configure SysTick to generate interrupt */
SysTick_Config(SYST_CLOCK/1000 - 1);
/* I2C initialization */
SdkEvalI2CInit(400000);
/* Infinite loop for process command */
processCommand1();
* @brief Process command code
* @param None
* @retval None
gas_sensor.dev_id = BME680_I2C_ADDR_PRIMARY; // 0x76
if(rslt==0)
printf("Success");
else
printf("Error");
printf("\n");
// while(1)
* @brief Delay function
* @param Delay in ms
* @retval None
uint32_t nWaitPeriod = ~lSystickCounter;
if(nWaitPeriod<lTimeMs)
while( lSystickCounter != 0xFFFFFFFF);
nWaitPeriod = lTimeMs-nWaitPeriod;
else
nWaitPeriod = lTimeMs+ ~nWaitPeriod;
while( lSystickCounter != nWaitPeriod ) ;
SdkDelayMs(period);
int8_t rslt = 0; /* Return 0 for Success, non-zero for failure */
uint8_t data;
rslt= SdkEvalI2CRead(&data, dev_id, reg_addr, len);
*reg_data = data;
return rslt;
uint8_t data;
rslt=SdkEvalI2CWrite(&data, dev_id, reg_addr, len);
*reg_data = data;
return rslt;
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
/******************* *****END OF FILE**************************************************************************************************/
01-25-2022 01:03 PM - edited 01-25-2022 01:47 PM
I have changed Internal Calibrartion function in bme680.c as like below,
static int8_t get_calib_data(struct bme680_dev *dev)
int8_t rslt;
//uint8_t coeff_array[BME680_COEFF_SIZE] = { 0 };
uint8_t coeff_array[41] = { 0 };
uint8_t temp_var = 0; /* Temporary variable */
/* Check for null pointer in the device structure*/
rslt = null_ptr_check(dev);
if (rslt == BME680_OK) {
// printf("Calibration In Test: \r");
//rslt = bme680_get_regs(BME680_COEFF_ADDR1, coeff_array, BME680_COEFF_ADDR1_LEN, dev);
rslt = bme680_get_regs(0x89, &coeff_array[0], 1, dev);
dev->delay_ms(1);
//printf("1 test: %d\r\n",rslt);
rslt = bme680_get_regs(0x8a, &coeff_array[1], 1, dev);
dev->delay_ms(1);
//printf("2 test: %d\r\n",rslt);
rslt = bme680_get_regs(0x8b, &coeff_array[2], 1, dev);
dev->delay_ms(1);
//printf("3 test: %d\r\n",rslt);
rslt = bme680_get_regs(0x8c, &coeff_array[3], 1, dev);
dev->delay_ms(1);
//printf("4 test: %d\r\n",rslt);
rslt = bme680_get_regs(0x8d, &coeff_array[4], 1, dev);
dev->delay_ms(1);
//printf("5 test: %d\r\n",rslt);
rslt = bme680_get_regs(0x8e, &coeff_array[5], 1, dev);
dev->delay_ms(1);
//printf("6 test: %d\r\n",rslt);
rslt = bme680_get_regs(0x8f, &coeff_array[6], 1, dev);
dev->delay_ms(1);
//printf("7 test: %d\r\n",rslt);
rslt = bme680_get_regs(0x90, &coeff_array[7], 1, dev);
dev->delay_ms(1);
//printf("8 test: %d\r\n",rslt);
rslt = bme680_get_regs(0x91, &coeff_array[8], 1, dev);
dev->delay_ms(1);
//printf("9 test: %d\r\n",rslt);
rslt = bme680_get_regs(0x92, &coeff_array[9], 1, dev);
dev->delay_ms(1);
//printf("10 test: %d\r\n",rslt);
rslt = bme680_get_regs(0x93, &coeff_array[10], 1, dev);
dev->delay_ms(1);
//printf("11 test: %d\r\n",rslt);
rslt = bme680_get_regs(0x94, &coeff_array[11], 1, dev);
dev->delay_ms(1);
//printf("12 test: %d\r\n",rslt);
rslt = bme680_get_regs(0x95, &coeff_array[12], 1, dev);
dev->delay_ms(1);
//printf("13 test: %d\r\n",rslt);
rslt = bme680_get_regs(0x96, &coeff_array[13], 1, dev);
dev->delay_ms(1);
//printf("14 test: %d\r\n",rslt);
rslt = bme680_get_regs(0x97, &coeff_array[14], 1, dev);
dev->delay_ms(1);
//printf("15 test: %d\r\n",rslt);
rslt = bme680_get_regs(0x98, &coeff_array[15], 1, dev);
dev->delay_ms(1);
//printf("16 test: %d\r\n",rslt);
rslt = bme680_get_regs(0x99, &coeff_array[16], 1, dev);
dev->delay_ms(1);
//printf("17 test: %d\r\n",rslt);
rslt = bme680_get_regs(0x9a, &coeff_array[17], 1, dev);
dev->delay_ms(1);
//printf("18 test: %d\r\n",rslt);
rslt = bme680_get_regs(0x9b, &coeff_array[18], 1, dev);
dev->delay_ms(1);
//printf("19 test: %d\r\n",rslt);
rslt = bme680_get_regs(0x9c, &coeff_array[19], 1, dev);
dev->delay_ms(1);
//printf("20 test: %d\r\n",rslt);
rslt = bme680_get_regs(0x9d, &coeff_array[20], 1, dev);
dev->delay_ms(1);
//printf("21 test: %d\r\n",rslt);
rslt = bme680_get_regs(0x9e, &coeff_array[21], 1, dev);
dev->delay_ms(1);
//printf("22 test: %d\r\n",rslt);
rslt = bme680_get_regs(0x9f, &coeff_array[22], 1, dev);
dev->delay_ms(1);
//printf("23 test: %d\r\n",rslt);
rslt = bme680_get_regs(0xa0, &coeff_array[23], 1, dev);
dev->delay_ms(1);
//printf("24 test: %d\r\n",rslt);
rslt = bme680_get_regs(0xa2, &coeff_array[24], 1, dev);
dev->delay_ms(1);
//printf("25 test: %d\r\n",rslt);
// printf("first test: \r\n");
/* Append the second half in the same array */
// if (rslt == BME680_OK)
rslt = bme680_get_regs(0xe1, &coeff_array[25], 1, dev);
//printf("26 test: %d\r\n",rslt);
rslt = bme680_get_regs(0xe2, &coeff_array[26], 1, dev);
//printf("27 test: %d\r\n",rslt);
rslt = bme680_get_regs(0xe3, &coeff_array[27], 1, dev);
//printf("28 test: %d\r\n",rslt);
rslt = bme680_get_regs(0xe4, &coeff_array[28], 1, dev);
//printf("29 test: %d\r\n",rslt);
rslt = bme680_get_regs(0xe5, &coeff_array[29], 1, dev);
//printf("30 test: %d\r\n",rslt);
rslt = bme680_get_regs(0xe6, &coeff_array[30], 1, dev);
//printf("31 test: %d\r\n",rslt);
rslt = bme680_get_regs(0xe7, &coeff_array[31], 1, dev);
//printf("32 test: %d\r\n",rslt);
rslt = bme680_get_regs(0xe8, &coeff_array[32], 1, dev);
//printf("33 test: %d\r\n",rslt);
rslt = bme680_get_regs(0xe9, &coeff_array[33], 1, dev);
//printf("34 test: %d\r\n",rslt);
rslt = bme680_get_regs(0xea, &coeff_array[34], 1, dev);
//printf("35 test: %d\r\n",rslt);
rslt = bme680_get_regs(0xeb, &coeff_array[35], 1, dev);
//printf("36 test: %d\r\n",rslt);
rslt = bme680_get_regs(0xec, &coeff_array[36], 1, dev);
//printf("37 test: %d\r\n",rslt);
rslt = bme680_get_regs(0xed, &coeff_array[37], 1, dev);
//printf("38 test: %d\r\n",rslt);
rslt = bme680_get_regs(0xee, &coeff_array[38], 1, dev);
//printf("39 test: %d\r\n",rslt);
rslt = bme680_get_regs(0xef, &coeff_array[39], 1, dev);
//printf("40 test: %d\r\n",rslt);
rslt = bme680_get_regs(0xf0, &coeff_array[40], 1, dev);
dev->delay_ms(1);
//printf("41 test: %d\r\n",rslt);
// printf("second test: \r\n");
//rslt = bme680_get_regs(BME680_COEFF_ADDR2, &coeff_array[BME680_COEFF_ADDR1_LEN], BME680_COEFF_ADDR2_LEN, dev);
/* Temperature related coefficients */
dev->calib.par_t1 = (uint16_t) (BME680_CONCAT_BYTES(coeff_array[BME680_T1_MSB_REG],
coeff_array[BME680_T1_LSB_REG]));
dev->calib.par_t2 = (int16_t) (BME680_CONCAT_BYTES(coeff_array[BME680_T2_MSB_REG],
coeff_array[BME680_T2_LSB_REG]));
dev->calib.par_t3 = (int8_t) (coeff_array[BME680_T3_REG]);
/* Pressure related coefficients */
dev->calib.par_p1 = (uint16_t) (BME680_CONCAT_BYTES(coeff_array[BME680_P1_MSB_REG],
coeff_array[BME680_P1_LSB_REG]));
dev->calib.par_p2 = (int16_t) (BME680_CONCAT_BYTES(coeff_array[BME680_P2_MSB_REG],
coeff_array[BME680_P2_LSB_REG]));
dev->calib.par_p3 = (int8_t) coeff_array[BME680_P3_REG];
dev->calib.par_p4 = (int16_t) (BME680_CONCAT_BYTES(coeff_array[BME680_P4_MSB_REG],
coeff_array[BME680_P4_LSB_REG]));
dev->calib.par_p5 = (int16_t) (BME680_CONCAT_BYTES(coeff_array[BME680_P5_MSB_REG],
coeff_array[BME680_P5_LSB_REG]));
dev->calib.par_p6 = (int8_t) (coeff_array[BME680_P6_REG]);
dev->calib.par_p7 = (int8_t) (coeff_array[BME680_P7_REG]);
dev->calib.par_p8 = (int16_t) (BME680_CONCAT_BYTES(coeff_array[BME680_P8_MSB_REG],
coeff_array[BME680_P8_LSB_REG]));
dev->calib.par_p9 = (int16_t) (BME680_CONCAT_BYTES(coeff_array[BME680_P9_MSB_REG],
coeff_array[BME680_P9_LSB_REG]));
dev->calib.par_p10 = (uint8_t) (coeff_array[BME680_P10_REG]);
/* Humidity related coefficients */
dev->calib.par_h1 = (uint16_t) (((uint16_t) coeff_array[BME680_H1_MSB_REG] << BME680_HUM_REG_SHIFT_VAL)
| (coeff_array[BME680_H1_LSB_REG] & BME680_BIT_H1_DATA_MSK));
dev->calib.par_h2 = (uint16_t) (((uint16_t) coeff_array[BME680_H2_MSB_REG] << BME680_HUM_REG_SHIFT_VAL)
| ((coeff_array[BME680_H2_LSB_REG]) >> BME680_HUM_REG_SHIFT_VAL));
dev->calib.par_h3 = (int8_t) coeff_array[BME680_H3_REG];
dev->calib.par_h4 = (int8_t) coeff_array[BME680_H4_REG];
dev->calib.par_h5 = (int8_t) coeff_array[BME680_H5_REG];
dev->calib.par_h6 = (uint8_t) coeff_array[BME680_H6_REG];
dev->calib.par_h7 = (int8_t) coeff_array[BME680_H7_REG];
/* Gas heater related coefficients */
dev->calib.par_gh1 = (int8_t) coeff_array[BME680_GH1_REG];
dev->calib.par_gh2 = (int16_t) (BME680_CONCAT_BYTES(coeff_array[BME680_GH2_MSB_REG],
coeff_array[BME680_GH2_LSB_REG]));
dev->calib.par_gh3 = (int8_t) coeff_array[BME680_GH3_REG];
/* Other coefficients */
rslt = bme680_get_regs(BME680_ADDR_RES_HEAT_RANGE_ADDR, &temp_var, 1, dev);
dev->calib.res_heat_range = ((temp_var & BME680_RHRANGE_MSK) / 16);
rslt = bme680_get_regs(BME680_ADDR_RES_HEAT_VAL_ADDR, &temp_var, 1, dev);
dev->calib.res_heat_val = (int8_t) temp_var;
rslt = bme680_get_regs(BME680_ADDR_RANGE_SW_ERR_ADDR, &temp_var, 1, dev);
dev->calib.range_sw_err = ((int8_t) temp_var & (int8_t) BME680_RSERROR_MSK) / 16;
return rslt;
and changed function of read field data as like below,
static int8_t read_field_data(struct bme680_field_data *data, struct bme680_dev *dev)
int8_t rslt;
//uint8_t buff[BME680_FIELD_LENGTH] = { 0 };
uint8_t buff[15] = { 0 };
uint8_t gas_range;
uint32_t adc_temp;
uint32_t adc_pres;
uint16_t adc_hum;
uint16_t adc_gas_res;
uint8_t tries = 10;
do {
//rslt = bme680_get_regs(((uint8_t) (BME680_FIELD0_ADDR)), buff, (uint16_t) BME680_FIELD_LENGTH, dev);
rslt = bme680_get_regs( 0x1d, &buff[0], 1, dev);
dev->delay_ms(1);
rslt = bme680_get_regs( 0x1e, &buff[1], 1, dev);
dev->delay_ms(1);
rslt = bme680_get_regs( 0x1f, &buff[2], 1, dev);
dev->delay_ms(1);
rslt = bme680_get_regs( 0x20, &buff[3], 1, dev);
dev->delay_ms(1);
rslt = bme680_get_regs( 0x21, &buff[4], 1, dev);
dev->delay_ms(1);
rslt = bme680_get_regs( 0x22, &buff[5], 1, dev);
dev->delay_ms(1);
rslt = bme680_get_regs( 0x23, &buff[6], 1, dev);
dev->delay_ms(1);
rslt = bme680_get_regs( 0x24, &buff[7], 1, dev);
dev->delay_ms(1);
rslt = bme680_get_regs( 0x25, &buff[8], 1, dev);
dev->delay_ms(1);
rslt = bme680_get_regs( 0x26, &buff[9], 1, dev);
dev->delay_ms(1);
rslt = bme680_get_regs( 0x27, &buff[10], 1, dev);
dev->delay_ms(1);
rslt = bme680_get_regs( 0x28, &buff[11], 1, dev);
dev->delay_ms(1);
rslt = bme680_get_regs( 0x29, &buff[12], 1, dev);
dev->delay_ms(1);
rslt = bme680_get_regs( 0x2a, &buff[13], 1, dev);
dev->delay_ms(1);
rslt = bme680_get_regs( 0x2b, &buff[14], 1, dev);
dev->delay_ms(1);
//printf("Test1\n");
data->status = buff[0] & BME680_NEW_DATA_MSK;
data->gas_index = buff[0] & BME680_GAS_INDEX_MSK;
data->meas_index = buff[1];
/* read the raw data from the sensor */
adc_pres = (uint32_t) (((uint32_t) buff[2] * 4096) | ((uint32_t) buff[3] * 16)
| ((uint32_t) buff[4] / 16));
adc_temp = (uint32_t) (((uint32_t) buff[5] * 4096) | ((uint32_t) buff[6] * 16)
| ((uint32_t) buff[7] / 16));
adc_hum = (uint16_t) (((uint32_t) buff[8] * 256) | (uint32_t) buff[9]);
adc_gas_res = (uint16_t) ((uint32_t) buff[13] * 4 | (((uint32_t) buff[14]) / 64));
gas_range = buff[14] & BME680_GAS_RANGE_MSK;
data->status |= buff[14] & BME680_GASM_VALID_MSK;
data->status |= buff[14] & BME680_HEAT_STAB_MSK;
if (data->status & BME680_NEW_DATA_MSK) {
data->temperature = calc_temperature(adc_temp, dev);
data->pressure = calc_pressure(adc_pres, dev);
data->humidity = calc_humidity(adc_hum, dev);
data->gas_resistance = calc_gas_resistance(adc_gas_res, gas_range, dev);
break;
/* Delay to poll the data */
dev->delay_ms(BME680_POLL_PERIOD_MS);
tries--;
} while (tries);
if (!tries)
rslt = BME680_W_NO_NEW_DATA;
return rslt;
Now I am getting reading but it is wrong and constant each time as like below,
T: 35.30 degC, P: 655.58 hPa, H 100.00 %rH
Here
if(data.status & BME680_GASM_VALID_MSK)
condition is not verified so not printing Gas Value, Here I am giving my main code again as below,
* Author : BCI Team
* Version : V1.0.0
* Date : Jan-2022
#include <stdio.h>
#include "bme680.h"
uint16_t meas_period;
int status=0;
uint8_t id,id1;
uint16_t wordData;
uint16_t Distance;
uint16_t SpadNum;
uint8_t dataReady;
* @param None
* @retval None
int main(void)
SystemInit();
processCommand1();
* @param None
* @retval None
if(rslt==0)
printf("Success");
else
printf("Error");
delay_ms(5);
printf("\n");
/* Select the power mode */
| BME680_GAS_SENSOR_SEL;
rslt = bme680_set_sensor_settings(set_required_settings,&gas_sensor);
/* Set the power mode */
printf("Configuration Success\n");
delay_ms(5);
//delay_ms(5);
while(1)
delay_ms(meas_period); /* Delay till the measurement is ready */
delay_ms(5);
printf("T: %.2f degC, P: %.2f hPa, H %.2f %%rH ", data.temperature / 100.0f,
data.pressure / 100.0f, data.humidity / 1000.0f );
// delay_ms(5);
/* Avoid using measurements from an unstable heating setup */
printf(", G: %d ohms", data.gas_resistance);
// delay_ms(5);
printf("\r\n");
// delay_ms(5);
/* Trigger the next measurement if you would like to read data out continuously */
if (gas_sensor.power_mode == BME680_FORCED_MODE) {
// delay_ms(5);
* @retval None
else
SdkDelayMs(period);
uint8_t data;
*reg_data = data;
return rslt;
uint8_t data;
*reg_data = data;
return rslt;
/* Infinite loop */
while (1)
#endif
/******************* *****END OF FILE*******************************************************/
Please Suggest where I am doing wrong. In current code I am reading separate register instead of multiple reading so don't know whether it is right or wrong. Please Guide.
01-25-2022 09:21 PM
I'm confused, so please be clear.
1) I saw your temperature and humidity is okay, but why you changed our code? It's okay to add delay function, but use the others.
2) Do you want to check gas resistance? Are you using bsec library? If yes, which example?
